Door cards (door interior trim panels) — which Nissan calls "door finishers" — for Datsun 1200 were available in different styles.
Contents[hide] |
Coupe door panels will fit on a 2dr sedan with some very minor mods. The panel may sit a bit higher than the original panel but basically its just a matter of enlarging the window winder hole. Oh, and its harder to fit but it works.
Early Truck door cards are the same as 4-dr sedan.
The factory visqueen protects the door cards from moisture. The original door panels are made out of MDF-like fibreboard, the doors have polyethylene sheet applied with sealer before the door cards are fitted.
The black bead of rubber sealant is similar to RTV
Details
Ute Mid-model (1978-1989) Brown
Ute Late-model (1989-)
Gray
Do not confuse with B210 door cards, such as this early KB210 | late B211 Sedan
Coupe
Coupe finishers cover the entire door (sedan finishers do not cover the top of the door)
FINISHER ASS'Y-door 80900 RH 80901 LH
JAPAN & North America 80900-H1800 RH BLACK #1742 80900-H1801 RH YELLOW 黄 (DX for JAPAN)
North American 1973 flame resistant 80900-H7101 RH BEIGE,LH-20 COUPE 0772- 80900-H7102 RH BLACK,LG-13 COUPE 0173- 80900-H7100 RH BLUE COUPE 0772-
Body Side Finisher 76900-H1800 DX/GL Black 76900-H1801 DX/GL Yellow
1973 North America 76900-H7000 BLUE 0772- 76900-H7001 BEIGE,LH-20 0772- 76900-H7002 BLACK,LG-13 0173-
Coupe PB110
Datsun PB110 Sunny Excellent 1400
Coupe DX * Same as B110 above (choice of black or yellow) PB110 Colors#Interior![]()
GL/GX double sweep with kicking plate 80900-H2600 RH BLACK PB110 80900-H2601 RH BROWN PB110 GX 80900-H2602 RH BLUE PB110 GL
Coupe 1972
80900-H4000 Black 89000-H4001 Yellow
Facelift finishers have a swoosh design
GX5
Body Side Finisher 76900-H4000 Black 76900-H4001 DX Yellow
Sedan
4-door 80900-H1000 STD black 5-rib style 80900-H1100 DX/GL/GX black chrome insert 80900-H1101 DX yellow
DX/GL/GX with chrome accent insert
Rear Door Finisher 82900-H1000 STD Black 82900-H1100 DX/GL/GX Black 82900-H1101 DX Yellow
Sedan 2-door
2-door 80900-H1200 STD black 80900-H1300 DX/GL black Japan 80900-H1301 DX yellow (USA: 1270-) 80900-H1900 DX black North America
North American 1973 flame resistant 80900-H7000 BLUE,LB-211 0772- 80900-H7001 BEIGE,LH-20 0772- 80900-H7002 BLACK,LG-13 0173-
80900-H1900 2-door North America
Body Side Finisher 76900-H1200 STD Black #1742 76900-H1300 DX/GL Black 76900-H1301 DX/GL Yellow
1973 North America 76900-H7000 BLUE,LB-211 0772- 76900-H7001 BEIGE,LH-20 0772- 76900-H7002 BLACK,LG-13 0173-
Body Side Finisher 76901-H1300 DX/GL, Black
Rear Side card has a distinctive upward sweep
Sedan PB110
Kicking Plate on bottom of door 80911-H2900 Sedan PB110 Sedan DX * Same as B110 DX above (choice of black or yellow)
GL/GX 80900-H2900 RH BLACK PB110 80900-H2901 RH BROWN PB110 GX 80900-H2902 RH BLUE PB110 GL
Sedan 1972
4-door 80900-H3100 1972 STD black 80900-H3200 1972 DX black 80900-H3201 1972 DX yellow
2-door 80900-H3600 1972 STD black 80900-H3700 1972 DX black 80900-H3701 1972 DX yellow
Truck
Sunny Truck door finishers came in two patterns:
- 1971 sedan STD simple 5-rib pattern
- 1972-1994 sedan facelift spear pattern
FINISHER ASS'Y-door 80900-H1000 -7111 BLACK same as early sedan 80900-H3100 7112-7803 BLACK same as 1972 sedan 80900-G1060 7804-7907 DARK BROWN 80900-G1660 7908-8104 BROWN 80900-G1901 8105-8910 BROWN 80900-95W00 9810- GRAY
Dec 1971 - Apr 1978: Facelift Black
7804-7907 DARK BROWN spear pattern
7908-8104 BROWN sweep pattern
8105-8109 BROWN
8110-8910 BROWN with pocket (driver's side only)
Door Pocket
80801 POCKET-DOOR 80912-G1900 BROWN RH 8110-8910 80912-95W00 GRAY RH 8910-
ドア ポケット
Clips
Clips to hold the finishers in place
Custom
Roll-cage simulating interior door panel. Color matched.
Fibreglass
Also See: Speakers
Click any thumbnail to see it full size in our Club Photo Album. Read details or post a comment!ドア フィニッシャー
