Reduction gear starter
Revision as of 00:40, 17 July 2019; view current revision
Category: Engine Electrical System
There are two types of Reduction gear starting motor for A-series engines -- Hitachi or Mitsubishi. Reduction gearing means the starter turns slower, but applies the same horsepower. This means increased torque, which is especially suitable for cold weather starting.
Pitroad Reduction Starter for 1971-1973
Bprojects Reduction Starter (1.2Kw)
For 1974-up ute crossmembers, cut a bit of the right-side tower like this:
Hitachi Reduction Starter
23300-H9100
20811.jpgAlbum 20811 19103.jpgAlbum 19103
1977 Canada models and 1978-up USA models used an optional reduction gear starting motor with increase torque for easy starting in sub-zero temperatures. This is also a good upgrade for high-compression engines. It was used in Japan market too.
20503.jpgAlbum 20503 20504.jpgAlbum 20504 20505.jpgAlbum 20505
The Hitachi can be identified by the thin end plate. By contrast, the Mitsubishi reduction starter uses a thick pressed steel end plate which looks like a standard starter.
20825.jpgAlbum 20825 20826.jpgAlbum 20826
Details on fitting this to a Datsun 1200 are needed. Can it be done? On the B210 it requires a different right-side engine mount. Reportedly it does fit the B110 and B310 crossmembers.
Mitsubishi Reduction Starter
The Mitsubishi reduction starter motor was used in Japan market B310s. It was not used USA market. This motor has a thick drive gear casting and a thin sandwich section in the middle (the Hitachi is made the other way: Thick sandwich with thin drive gear casting).
13253.jpgAlbum 13253 20820.jpgAlbum 20820 20821.jpgAlbum 20821
