Floor Part Numbers
Revision as of 00:28, 24 November 2021; view current revision
Categories: Body | Catalog
<-- back to Part Numbers Index
Also see: Main articless for usage, photos, cross-reference
Floor
Trunk (boot)
Jack
Front Floor
FRONT FLOOR PANEL USA/JAPAN, COUPE/SEDAN/VAN
41 FRONT FLOOR
   74300-H1000 3 SPEED
   74300-H1010 4 SPEED
   74300-H1021 AUTOMATIC
42   74310-H1000 CROSS MEMBER-FRONT SEAT RH
43   74311-H1000 CROSS MEMBER-FRONT SEAT LH
     74311-H1400 Van RHD
44   74314-H1001 BRACKET-FRONT SEAT INSIDE RH
45   74315-H1000 BRACKET-FRONT SEAT INSIDE LH
46   74316-H1000 BRACKET-FRONT SEAT OUTSIDE RH
47   74317-H1000 BRACKET-FRONT SEAT OUTSIDE LH
48   74320-H1000 FLOOR SIDE RH
49   74321-H1000 FLOOR SIDE LH
50 74810-H1001 ASSY-MEMBER SIDE FRONT RH
51 74811-H1001 ASSY-MEMBER SIDE FRONT LH
52   54532-H1001 BRACKET-TENSION ROD RH
53   54533-H1001 BRACKET-TENSION ROD LH
54 74800-H1000 ASSY-MEMBER CROSS FRONT
Rear Floor Coupe
REAR FLOOR PANEL (COUPE)
54 74500-H1801 FLOOR ASS'Y-rear
   74500-H1800 to '70-Dec <x> 74500-H1801
55   84122-H1800 BRACKET-rear seat side 2
56   74860-H1000 CROSS MEMBER, rear seat, lower
57   74870-H1800 CROSS MEMBER, shock absorber
58   74882-H1800 CROSS MEMBER, rear end
59   74850-H2501 SIDE MEMBER, rear RH <> 74850-H1800
60   74851-H1800 SIDE MEMBER, rear LH
61   55208-H1000 BRACKET, shackle 2
62   84106-H1800 BRACKET, trunk trim, side rear 2
63   74528-H1800 REINFORCEMENT-bumper stay, rear 2
Truck
FLOOR PANEL
41 74300 FRONT FLOOR
   74300-G1401 7510-7803
   74300-G1160 7804-8808
   74300-G1950 8809-8910
   74300-95W00 8910-
42 74340 MEMBER-FRONT SEAT MOUNTING RH
     74310-H1000 7510-8904
     74330-95W00 8904-
43 74341 MEMBER-FRONT SEAT MOUNTING LH
     74311-H1000 7510-8904
     74331-95W00 8904-
   74515 BRACKET-JACK MOUNTING
     99602-H1400
44 74352M BRACKET-FRONT SEAT MOUNING, INNER RH
     74314-H1001 8910-
45 74353M BRACKET-FRONT SEAT MOUNTING, INNER LH
     74315-H1000 8910-
46 74352 BRACKET-FRONT SEAT MOUNTING, OUTER RH
     74316-H1000 8910-
47 754353 BRACKET-FRONT SEAT MOUNTING, OUTER LH
     74317-H1000 8910-
48 74320-G1000 INNER SILL RH
49 74321-G1000 INNER SILL LH
50 74802 MEMBER-SIDE, FRONT RH
   74810-G1600 7510-7803 <x> 74810-G1601
   74810-G1601 7804-8910
   74810-G1900 8910-
51 74803 MEMBER-SIDE, FRONT LH
   74811-G1601 7510-8503 <> 74811-H1001
   74811-H1001 8504-8910
   74811-G1900 8910-
52 74830 BRACKET-SUSPENSION ROD RH
   54532-H1001
53 74831 BRACKET-SUSPENSION ROD LH
   54533-H1001
54 74820 MEMBER-CROSS, FRONT
   74800-H1000
74823 HOOK-FRONT RH
   62682-H7000 7510-8503
   62632-G1200 8504-
74824 HOOK-FRONT LH
   62683-H7000 7510-8503
   62633-G1200 8504-
8910- ONLY
   74301A 74398-95W00 BOLT-PLATE 2
   74301J 74354-95W00 REINFORCE-HAND BRAKE & SEAT BELT
   74318 74306-G1001 REINFORCE BODY MOUNTING RH
   74319 74307-G1001 REINFORCE BODY MOUNTING LH
   74347 BRACKET-REAR ENGINE MOUNTING
     74331-H1000 LEFT
     74362-95W00 RIGHT
   74510E 01551-00063 CLIP 2
   74514A 74352-H1000 PLATE-BOLT
74810 BOARD-SPLASH SHIELD
   62611-H1000 7510-8004 <2,0> F2611-H1000
   F2611-H1000 8005-8503
   62611-H1000 8504-8910
   08630-61226 SCREW 4
FRONT FLOOR TRIMMING
SPARE WHEEL HANGER - see Spare_Wheel_Hanger_Part_Numbers#Truck
Sedan
1 74300-H1021 ASSY-FLOOR FRONT SEDAN AUTOMATIC
1 74300-H1010 ASSY-FLOOR FRONT SEDAN 4 SPEED
2 74310-H1000 ASSY-MEMBER CROSS FRONT SEATRH SEDAN
3 74311-H1000 ASSY-MEMBER CROSS FRONT SEATLH SEDAN
4 74314-H1000 BRACKET-FRONT SEAT INSIDE RH SEDAN
4 74314-H1001 BRACKET-FRONT SEAT INSIDE RH SEDAN
5 74315-H1000 BRACKET-FRONT SEAT INSIDE LH SEDAN
6 74316-H1000 BRACKET-FRONT SEAT OUTSIDE RH SEDAN
7 74317-H1000 BRACKET-FRONT SEAT OUTSIDE LH SEDAN
8 74320-H1000 ASSY-FLOOR SIDE RH SEDAN
9 74321-H1000 ASSY-FLOOR SIDE LH SEDAN
10 74500-H7000 ASSY-FLOOR REAR SEDAN 0772-
10 74500-H1000 ASSY-FLOOR REAR SEDAN
10 74500-H2800 ASSY-FLOOR REAR SEDAN
11 74528-H1000 REINFORCEMENT-BUMPER STAY REAR SEDAN
11 74528-H7000 REINFORCEMENT-BUMPER STAY REAR SEDAN 0772-
12 74860-H1000 ASSY-MEMBER CROSS REAR SEAT LOW SEDAN
13 74850-H1000 ASSY-MEMBER SIDE REAR RH SEDAN
14 74851-H1000 ASSY-MEMBER SIDE REAR LH SEDAN
15 55208-H1000 ASSY-BRACKET SHACKLE SEDAN
16 74810-H1001 ASSY-MEMBER SIDE FRONT RH SEDAN
17 74811-H1001 ASSY-MEMBER SIDE FRONT LH SEDAN
18 54532-H1001 ASSY-BRACKET TENSION ROD RH SEDAN
19 54533-H1001 ASSY-BRACKET TENSION ROD LH SEDAN
20 74800-H1000 ASSY-MEMBER CROSS FRONT SEDAN
21 74933-H1000 INSULATOR-TUNNEL FRONT SEDAN MANUAL
22 74933-H1020 INSULATOR-FLOOR COVER SEDAN AUTO
23 74931-H1000 INSULATOR-FLOOR FRONT RH SEDAN
24 74932-H1000 INSULATOR-FLOOR FRONT LH SEDAN
25 74934-H1000 INSULATOR-FLOOR,REAR,RH (2) SEDAN (DX)
26 74934-H1025 SET-INSULATOR FLOOR REAR RH SEDAN (DX) 0570-
 G5930-89902 INSULATOR-FLOOR FRONT LH SEDAN
27 74937-H1000 INSULATOR-TUNNEL REAR SEDAN (DX)
28 74965-H1000 BOOTS-HAND BRAKE SEDAN (DX)
28 74965-H7300 BOOTS-HAND BRAKE SEDAN (DX)
29 74936-H1000 INSULATOR-REAR SEAT LOWER SEDAN(DX)
29 G5930-89902 INSULATOR-REAR SEAT LOWER SEDAN(DX)
30 01658-00041 PLUG-RUBBER 39 (4) SEDAN
30 01658-00021 PLUG-RUBBER 25 FRONT FLOOR HOLE (4) SEDAN
31 57210-18000 HANDLE-SPARE WHEEL CLAMP SEDAN
31 74630-21002 HANDLE-SPARE WHEEL CLAMP SEDAN 0171-
32 84905-H1900 ASSY-COVER SPARE TIRE OP SEDAN 1270-
32 84905-H7000 ASSY-COVER SPARE TIPE SEDAN 0772-
33 74365-73000 PLUG-ANCHURAGE HOLE (4) SEDAN
34 74963-20900 BOOT-CONTROL LEVER SEDAN 4 SPEED
35 32021-35000 PLUG-INSPECTION HOLE SEDAN
36 74882-H1000 MEMBER-CROSS READ END SEDAN
Coupe
1 74300-H1021 ASSY-FLOOR,FRONT COUPE,AUTOMATIC
1 74300-H1010 ASSY-FLOOR FRONT COUPE,MANUAL
2 74310-H1000 ASSY-MEMBER CROSS FRONT SEATRH COUPE
3 74311-H1000 ASSY-MEMBER CROSS FRONT SEATLH COUPE
4 74314-H1000 BRACKET-FRONT SEAT INSIDE RH COUPE
4 74314-H1001 BRACKET-FRONT SEAT INSIDE RH COUPE 2 74314-H1000
5 74315-H1000 BRACKET-FRONT SEAT INSIDE LH COUPE
6 74316-H1000 BRACKET-FRONT SEAT OUTSIDE RH COUPE
7 74317-H1000 BRACKET-FRONT SEAT OUTSIDE LH COUPE
8 74320-H1000 ASSY-FLOOR SIDE RH COUPE
9 74321-H1000 ASSY-FLOOR SIDE LH COUPE
10 74500-H1800 ASSY-FLOOR REAR COUPE
10 74500-H1905 ASSY-FLOOR REAR COUPE 0171-
10 74500-H1906 ASSY-FLOOK REAR COUPE 2 74500-H1905
10 74500-H7100 ASSY-FLOOR REAR COUPE 0772- 0 74500-H1906
11 74528-H1800 REINFORCEMENT-BUMPER STAY REAR (2) COUPE
12 84122-H1800 BRACKET-SEAT REAR SIDE (2) COUPE
13 74860-H1000 ASSY-MEMBER CROSS REAR SEAT LOWER COUPE
14 74870-H1800 ASSY-MEMBER CROSS SHOCK ABSORBER COUPE
15 74882-H1800 MEMBER-CROSS REAR END COUPE
16 74850-H1800 ASSY-MEMBER SIDE REAR RH COUPE
16 74850-H2501 ASSY-MEMBER SIDE REAR RH COUPE 2 74850-H1800
17 74851-H1800 ASSY-MEMBER SIDE REAR LH COUPE
18 55208-H1000 ASSY-BRACKET SHACKLE RH COUPE
19 55208-H1800 ASSY-BRACKET SHACKLE LH COUPE
20 84106-H1800 BRACKET-TRUNK ROOM TRIM REARSIDE (2) COUPE
21 74810-H1001 ASSY-MEMBER SIDE FRONT RH COUPE
22 74811-H1001 ASSY-MEMBER SIDE FRONT LH COUPE
23 54532-H1001 ASSY-BRACKET TENSION ROD RH COUPE
24 54533-H1001 ASSY-BRACKET TENSION ROD LH COUPE
25 74800-H1000 ASSY-MEMBER CROSS FRONT COUPE
26 74933-H1000 INSULATOR-TUNNEL FRONT COUPE,MANUAL
26 74933-H1020 INSULATOR-TUNNEL,FRONT COUPE,AUTOMATIC
27 74931-H1000 INSULATOR-FLOOR FRONT RH COUPE
28 74932-H1000 INSULATOR-FLOOR FRONT LH COUPE
29 74934-H1000 INSULATOR-FLOOR REAR (2) COUPE
30 74934-H1025 SET-INSULATOR FLOOR REAR RH COUPE 0570- 2 74934-H1000
31 74937-H1000 INSULATOR-TUNNEL REAR COUPE
32 74965-H1000 BOOT-HAND BRAKE COUPE
33 74936-H1000 INSULATOR-REAR SEAL LOWER COUPE
34 84124-H1801 BRACKET-FUEL TANK MOUNTING RH COUPE
35 01658-00021 PLUG-RUBBER 25D (4) COUPE
35 01658-00041 PLUG-RUBBER 39D (4) COUPE 0 01658-00021
36 57210-18000 HANDLE-SPARE WHEEL CLAMP COUPE
36 74630-21002 HANDLE-SPARE WHEEL CLAMP COUPE 0171- 0 57210-18000
37 99606-H1800 CLAMP-JACK HANDLE (2) COUPE
38 74962-H1905 PROTECTOR-BREATHER TUBE COUPE
39 74365-73000 PLUG-ANCHORAGE (2) COUPE
40 74963-20900 BOOT-CONTROL LEVER COUPE
41 32021-35000 PLUG-INSPECTION HOLE 55D COUPE
42 74891-H2500 ASSY-COVER INSPECTION HOLE COUPE
43 08510-61212 SCREW (6) COUPE
