A-series head bolts are designed to be reused; they are not Torque-To-Yield (TTY) bolts.
Maintenance Schedule
Retighten cylinder head bolts every 24 months or 24000 miles whichever comes first.
1972 USA Owners manual (Page 32 ... 32):
24 months/24000 miles
600 mile service 24 months/24000 miles
See Changing Head Gasket for torque specifications and procedure.
BOLT-FIXING CYLINDER HEAD SHORT [9 needed, 97 mm length] 11056-18001 36 lb ft [Original use: A10 & A12] 11056-H1000 43 lb ft [original use: A12] 11056-H2301 58 lb ft [original use: A12GX]
BOLT-CYLINDER HEAD, TO OIL GALLERY [1 needed] 11057-18000 ' 11057-H1000 'T' 11057-H2300 '13' for 1967-1973 engines [97 mm length] 11057-H5700 '13' for 1974-up engines [111 mm length]
Bolts are the same for A12/A14/A15, but:
Strengthened Cylinder Head Bolts
1973 A12 (early engine, upgraded H1000 bolts) Torque: 40-43 ft-lb CENTER BOLT: 8 mm central portion (head marked 'T') OTHER BOLTS: 9 mm![]()
Note 'T' bolt for center of early A12 engine. This is a low-torque bolt. The center bolt is thinner to allow oil to flow around it up to the rocker shaft.
Better to use the GX '13' center bolt, which is high-tensile chromoly V steel
"13" bolts were first used on the twin-carb A12GX Engine, as opposed to single-carb engine bolts. "13" bolts can be used with any early engine (they are simply stronger than the earliest bolts).
Note that A12/A12A/A13/A14/A15 all may use the '13' bolts, but the center bolt differs between early engines and late engines.
Center bolt 11057-H5000 and 11057-H5700 are interchangeable
Original Lo-torque bolts (B10 & early B110 -1172) - 36 ft-lb * 11056-18001 BOLT-FIXING CYLINDER HEAD SHORT * 11057-18000 BOLT-FIXING CYLINDER HEAD LONG * 11058-18000WASHER-LOCK FIXING CYLINDER HEAD
Newer medium torque bolts (1272-) - 43 ft-lb * 11056-H1000 BOLT-FIXING CYLINDER HEAD SHORT (9 needed) $2.90 * BOLT-FIXING CYLINDER HEAD LONG [Center bolt] $2.51 superceded by 11057-H5000/11057-H5010 * 11058-H1000 WASHER-LOCK FIXING CYLINDER HEAD $2.28
A12GX, A12T, A12S, A13, A14, A15, A12A - 58 ft-lbs * 11056-H2301 HEAD BOLT SHORT (9 needed) $3.96 Also used by Z16/Z18/Z20/Z22 (10 per engine) NOTE Some newer lo-power (round port) A12S are spec'd for 11056-H1000 * 11057-H2301 BOLT-CYLINDER HEAD LONG, TO OIL GALLERY (TO 6/73) $3.88 one needed * 11057-H5700 BOLT-CYLINDER HEAD LONG, TO OIL GALLERY (FROM 7/73) $4.03 one needed Also used by Z24, KA24E, NA20P (10 per engine) replaced 11057-H5000 (lo-torque version) * used by 1988- D21/WD21/C22 Z24 engine
A12: Long middle bolt marked 'T' (low-torque)
A14: Long middle bolt marked '13' (hi-torque)
Hi-torque bolts marked "13" on the head. Remove the valve cover to verify.
head bolts Cro-Mo-V steel 13T
Lock Washer * 11058-H1000 WASHER-LOCK FIXING CYLINDER HEAD -8504 $2.28 * 11058-21002 Washer Cyl Head 8504- $2.57
KA24E - 1989-1993 Nissan 240SX 11057-H5010 10 needed * Same as Datsun 1200 center bolt
KA24E - 1994-1998 Nissan 240SX 11056-F3F01 10 needed. TTY bolts, do not reuse * reportedly shorter than Datsun 1200/KA24E SOHC
Z20/Z22 Datsun 720 11056-H2301 10 needed * Same as Datsun 1200 (9 needed)
Z24 Datsun 720 11057-H5000 10 needed * Same as late Datsun 1200 (center bolt)
