Datsun 1200 came standard with #rubber mats covering the floor — and with carpet covering the transmission tunnel in the front seat area. Optional was full carpeting.
Contents[hide] |
Full Carpeting
Full carpet was option but rare in USA (most only seen on some coupes).
It is a four-piece set:
1. Right Front Floor
2. Tunnel Carpet
3. Left Front floor
4. Rear floor
The rear piece stretches across the car and over the rear portion of the tunnel.
USA Catalog COUPE, SEDAN 74902-H2031 CARPET-FLOOR FRONT RH OP 74904 see #Tunnnel Carpet 74903-H2031 CARPET-FLOOR FRONT LH OP COUPE, SEDAN.MANUAL 74903-H2025 CARPET-FLOOR FRONT LH OP SEDAN.AUTOMATIC 74907-H1102 CARPET-FLOOR REAR COUPE <> 74907-H1101 74907-H2011 CARPET-FLOOR REAR OP
Each floor piece is secured by a hook in all corners. The tunnel piece is neither glued down nor hooked.
61140-0502P HOOK (12) 08530-52512 SCREW-TAPPING (12)
Colors
The carpet cloth is houndstoothᵂ pattern.
blue/black yellow/black gray/black
Tunnel Carpet
Except for Standard 1200s, all 1200s were fitted with a piece of carpet covering the tunnel forward of the front seats. Standards came with a #rubber mat covering the tunnel.
USA Catalog COUPE, SEDAN 74904-H2025 CARPET-FLOOR TUNNEL AUTOMATIC 74904-H2031 CARPET-FLOOR TUNNEL 4-SPEED H20 designed for 1200 GL
The tunnel piece has a cutout for the shifter hole
Upscale GL and GX models had a 'foot patch' on the tunnel carpet next to the clutch pedal. All USA cars were fitted with the GL-type tunnel carpet but in a unique blue color.
Floor Mats
Rubber mats cover the floor of most 1200s, except for the rare full-carpeted car.
The three floor mats, plus red aftermarket tunnel carpet piece
1. Right Front floor mat 2. Left Front floor mat 3. Rear Floor Mat
Additionally, Standard cars had a mat covering the tunnel (all others had #Tunnel Carpet).
74904-H1001 MAT-floor, tunnel S-Std. 3-speed * no shifter hole 74904-H1011 MAT-floor, tunnel S-Std. 4-speed * floor shift, so the mat has a hole
Floor mats differ USA vs Japan.
USA Catalog COUPE, SEDAN 74902-H1605 MAT-FLOOR FRONT RH [passenger] 74903-H1605 MAT-FLOOR FRONT LH SEDAN.MANUAL, COUPE.ALL 74903-H1725 MAT-FLOOR FRONT LH SEDAN.AUTOMATIC 74903-H1005 MAT-FLOOR FRONT LH SEDAN.MANUAL 74907-H1105 MAT-FLOOR REAR
JPN Catalog Standard only SEDAN 74902-H1001 MAT-floor, front (R.H.) 3 speed 74902-H1011 MAT-floor, front (R.H.) 4 speed 74903-H1001 MAT-floor, front (L.H.) [assistant] 74907-H1001 MAT-floor, rear
Floor Shift manual transmission
Ute
It is glued, it goes to the lip which aligns with the base of the tray. This helps reduce Roadnoise, as from factory would only cover floor.
Parts
Tunnel carpet is NLA (No Longer Available) from Nissan in the USA, Canada and Japan.
AUS: Knox carpetᴳ fits the automatic tunnel, is a bit large for the standard manual transmission tunnel and will gather about the gathers at the sides near the doors. Fitting an extra layer of insulation will help.
AUS: Trufitᴳ
USA: Mail Order custom carpet from ACCᴳ in Alabama
Insulation
From the factory, only the tunnel had insulation, a jute type. Additionally, there are some asbestos heat shields on the floor which also have some noise-dampening characteristics.
Factory jute insulation was glued to the tunnel
Fitting carpet insulation will significantly quiet the 1200 cabin — even under the factory rubber mats.
The Coin Trays will finish off the installation
