Unlike the B110 foglamps, fog lights for the B210 bolt into the grille.
NOTE: North American B210s used the grille lamps for the indicators (instead of for fog lamps).
B110-style fog lamps can be fitted to the B210
Early 1973-1975
Late 1976-1978
Late B210 was from late 1975 to 1978. The B210 facelift variant (B211) was produced 1976-1977 in Japan.
- triangular brackets with top bolt offset
- sloping lens with 'NISSAN' in center
- 30W bulb
Late Sedan JDM (B211) & ADM 120Y (B210)
#Type H79 L16-powered (GB211)
Type H79
The Sunny 1600 was the L16 engine-powered version (GB211).
26150-H7926 FOG LAMP KIT for OKINAWA
GX grille came with fog lamps pre-installed
Foglamp bracket top bolt goes into the core support, and also doubles as one of the grille bolts.
EARLY -1975 * ROUND 26150-H5527 K-GX K-DX,K-GL OPTION > 26150-H5525 <> 26150-H5526 * RECTANGLE S,V OPTION 26150-H5027 LAMP KIT-fog > 26150-H5025 <> 26150-H5026 25160-H6001 SWITCH COMP.-lighting with fog * top bolt centered 25160-H5827 PB210 GX (op.)DX,GL > 25160-H5825 <> 26150-H5826
LATE 1976- LAMP KIT-FOG 30W bulbs (3-bolt type, sloping lens) * top bolt offset 26250-H7525 S.A14.GX *S.A12,A14-GX *V 26250-H7526 K.A14.GX *K.DX,GL-L16 26250-H7427 *S,V F/OKINAWA [lens differs from non-OKINAWA] 26250-H7428 *K F/OKINAWA 26250-H7925 L16.GX *L16.GL 26250-H7926 *L16 F/OKINAWA
25160-H6001 SWITCH ASSY-LIGHTING W/FOG 25160-H5201 SWITCH ASSY-LIGHTING W/FOG&ILLUMI 25160-H5800 SWITCH COMP.-lighting with fog PB210 GX (op.)DX,GL
フォグ ランプ
