They're really something
Revision as of 06:34, 30 March 2025; view current revision
Category: Documentation
<-- back to USA brochures
Title: they're really something DATSUN 1200'S [white cover with small inset photo of man and woman faces]
1971 07 1200s B110
Format:French-fold (single sheet, 8 panels) Size:9x9" Publication Number:Form No. 601/GP1MM/7/70
Comments? Questions? More photos or info? Reply to main forum: POST Brochures wanted
27584.jpg#outside 27582.jpg#inside
Sheet Outside
27581.jpg#cover 29119.jpg#back 27583.jpg#Li'l 29118.jpg#Special
27584.jpgAlbum 27584
Cover
DATSUN 1200'S
27581.jpgAlbum 27581
Back
29119.jpgAlbum 29119
Datsun 1200 Specifications
  Something Special    Li'l Something
  2-Door Coupe         2-Door Sedan
Dimensions
Wheel Base  90.6"
Length  152.0"   152.6"
Width   59.6"     58.9"
Height  53.1"     54.7"
Weight  1609 lb 1587 1b.
Performance
Max. Speed 94 mph
Min. Turning Diameter 27 ft
Engine  High-Cam, Water-cooled, OHV, 5-Main-Bearing
Displacement 71.5 cu. in.
Horsepower 69 at 6000 RPM
No. Cylinders 4
Compression ratio 9.0 to 1
Bore & Stroke 2.87 x 2.76
Wheels & Tires Steel disc wheels;
tire size: 600-12 tubeless, whitewalls.
Brakes Hydraulic brakes with tandem
type master cylinder. Front; disc brakes.
Rear: Drum, leading and trailing type.
Parking brake mechanically operated on rear wheels.
Electrical System 12 volts, 50AH battery, 33A alternator.
Steering Recirculating ball type.
Gear ratio: 15 to 1.
Clutch Single dry disc with diaphragm type, hydraulic control.
Transmission All-synchromesh 4-speed, manual floor shift.
 Gear ratios: 1st 3.76, 2nd 2.17, 3rd 1.40, Top 1.00. Rev. 3.64.
Fuel System Two-barrel, down-draft type carburetor,
mechanical type diaphragm fuel pump. Paper element
type air cleaner with hot air system, fuel tank capacity
10.0 gal. (Coupe), 10.6 gal. (Sedan).
Emission Control' Engine modification system (no air pump).
Cooling System Pressurized radiator, belt drive fan and
centrifugal water pump with thermostat.
Front Suspension Independent strut type with coil springs,
tension rods, telescopic shock absorbers with stabilizer.
Rear Suspension & Axle Semi-elliptic leaf springs with shock
absorbers, semi-floating rear axle, hypoid type final gear.
Gear ratio: 3.90:1.
Instruments and Controls Speedometer. Combined water
temperature gauge, fuel gauge, oil pressure warning light, Ignition
warning and parking brake warning lights. Turn signal lights. Wiper
and washer switch. Choke knob, cigarette lighter. Light switch, turn
signal and dimmer switch, 4-way flasher
switch. Ignition key with steering lock, heater control knobs, glove box.
Body and Interior All steel unibody construction. Tinted safety glass
(Coupe). Safety glass (Sedan). Carpet on tunnel. Vinyl floor mat. Seat
belts, reclining front bucket seats (Coupe), bucket seats (Sedan). Fold-
down type rear seat (Coupe). Two speed anti-lift wipers with washers.
Ash trays front/back. Sun visors, arm rests, coat hanger. Inside rear
view mirror, outside door mirror. Heater/defroster. Dual horns. Locking
gas cap.
Optional Equipment (At Dealer) 155SR-12 radial tires, console box,
rear assist strap, carpet, radio, radio with stereo, clock, tachometer,
exhaust tube finisher, heel mat, roof rack, ski rack, fancy wheel covers
(Sedan). Continuing advances in Datsun design and engineering
technology require that specifications and prices be subject to change
without notice.
Drive a Datsun, then decide.
[image: 'DATSUN 1200' Coupe rear badge]
Sedan
The Li'l Something 2-Door Sedan
27583.jpgAlbum 27583
A good looking, highly functional piece of machinery. A car you feel good about owning, good about driving.
The inside is man-sized for Americans. More head, leg and knee room than you'd expect. All-vinyl bucket seats, ash trays front and back. A lot of little extras — all wrapped in a steel unibody for solid protection.
We simply took the ugly out of economy and put the performance in.
The Li'l Something's responsive high-cam engine revs quiet and easy. Enjoy it at every green light, on every on-ramp.
Front disc brakes deliver the safest kind of stopping.
Do yourself a small favor. Drive the sporty Sedan with the practical trunk. It'll turn you on with big car features. And it'll turn you around in just 27 feet! Thirty miles per gallon economy. And a very small price.
Li'l Something, A step down in cost — a step up in value.
Coupe
The Something Special 2-Door Coupe
29118.jpgAlbum 29118
Same photo was used in the "ugly out/performance in" advertisement
18.jpgAdvert
Wind tunnel tested to do an honest 94 MPH. And resist cross winds that bug most small cars.
Now it does Its bit for Urban Renewal. For Ecology. For Mobile America.
Cross-town or cross-country, the Something Special is agile, handsome, tough. Zooms to 60 in just 14.8 seconds. Turns In a tight 27 feet.
The front buckets recline. Back seat folds down. You can load from two wide-swinging doors Or flip up the trunk lid and slide your matched set of clubs in from the rear.
Versatility? It's a Shopping Cart. An Overnighter. A Baby Buggy and a Carry-All. A Commuter. It's a Multi-Car — something special for just about everybody.
Shape up your budget, your driving fun. The Something Special costs just a little more than the Li'l Something. A lot less than you'd guess.
Sheet Inside
29120.jpg#Really 29121.jpg#Sunflower 29122.jpg#2door
27582.jpgAlbum 27582
Features
See Ads#27 which uses same tag line
The Datsun 1200s are really something!
29120.jpgAlbum 29120
All That Class-All That Economy
How in the World Does Datsun Do It? With extra engineering. Artful styling. And long, long experience. Nearly 40 years designing and building nothing
but rugged, potent, economical cars.
About 1 HP Per Cubic Inch
[image: engine]
The 1200's hyper-efficient high-cam engine gets its 69 horses from just 71.5 cubic inches. It's internally modified for maximum emission control. Happy and responsive past 6,000 RPM. Strong on hills and freeway ramps. So easy on gas you can cruise up to 300 miles on ten gallons. The torque comes on at 3,600 RPM—traffic power! And just 23 pounds of car weight per horsepower means easy running, low maintenance, and great performance.
Stop It!
[image: disc brake]
Front disc brakes—up where 80-85% of the braking action is. From freeway speeds these mighty binders stop the Sedan and Coupe straight and sure. Repeatedly without fade. And they're puddle-proof, immune to water and soggy brake pedal. Coupled with rear drums and tandem type master cylinder, they call the quickest halt with the greatest margin of safety.
Sporty and Practical
[image: 4-speed shift knob]
That's what the Li'l Something Sedan and Something Special Coupe are. Likewise their buttery-smooth 4-speed stick shift. Its racing heritage shows in its short, precise throws. In its perfect matching with the engine's perky torque curve. All-synchromesh, it "snicks" in gear quick and sure. Puts you in complete charge with a flick of the wrist.
Datsun Dashes
[image: round-gauge dashboard]
As in all Datsuns, the dashboard proves that functional can also be beautiful. Handsome instruments communicate fast (tach optional). Safety engineered controls, including those for the heater/defroster, 2-speed wipers and washers, and optional radio, are an easy reach. Of course there's a steering wheel lock on the safety collapsible steering column. A persistent buzzer warns you not to leave your keys in the car.
No Fueling Around
[image: fuel door]
At up to 30 miles to the gallon you won't use your locking gas cap often. Without your knowledge, no one else is likely to either. It's a luxury touch like whitewalls, back seat ash tray, bumper guards, and the Coupe's deep pile carpet. Another little something extra you get as standard equipment.
Easy Rider
[image: front suspension]
The 1200's suspension-independent strut type up front; semi-elliptic rear leaf springs. Ideal for multi-purpose machines this size and weight. Stable, sure-tracking for comfort and roadability.
Tender Loving Care
[image: couple]
The 1200's—four years in development. Three million miles of testing. Datsun builds experienced cars. Over-achievers that set a new standard in the lowest priced field. Parts and service everywhere. Over 1000 dealers in the U.S. and Canada.
Sunflower Coupe
Colors#931
29121.jpgAlbum 29121
Red 2-Door
colors#932
29122.jpgAlbum 29122
