B210 Gauges
Revision as of 07:38, 14 February 2024; view current revision
Speedometer (スピード メーター), Tachometer, Clock, etc. for Datsun B210 Sunny.
Most B210 models used a square-gauge dash, which was considered "modern" at the time.
JDM GL Sedan:
8508.jpgAlbum 8508 3953.jpgAlbum 3953 10874.jpgAlbum 10874
High-line round-gauge dash (GX Sedan and all JDM Coupes):
11371.jpgAlbum 11371 174_65cc5dd09a926.jpgPost 498276
GX featured 180km speedometer, while all others used 160km unit.
The Round gauge cluster was quite similar to the B110 Cluster Gauge, except fitted with sloping glass lenses for anti-glare characteristics.
Lesser B210s used rectangular gauges
174_59bdcaa67aab5.jpgPost 486111
A digital "Calendar Kit" could be purchased for late B210.
B210 featured illuminated Knobs as first seen on the PB110 Sunny Excellent. They are slightly different than the green knobs seen on the 1973 Datsun 1200s.
Dash frame
Round vs Rectangular
Japan-market B210 GX came with round gauges, as did all JDM Coupes (including DX Coupe)
3656.jpgAlbum 3656 17491.jpgAlbum 17491 17492.jpgAlbum 17492 17493.jpgAlbum 17493 17494.jpgAlbum 17494
GL Coupe 160kph
25297.jpgAlbum 25297
GX Coupe - 180kph with tach
26897.jpgAlbum 26897 26898.jpgAlbum 26898
Common gauge set was rectangular (Sedan STD, Sedan DX and Sedan GL and all Van). Most export countries also used rectangle meters — even on GX models.
2862.jpgAlbum 2862 3148.jpgAlbum 3148 3585.jpgAlbum 3585 20415.jpgAlbum 20415 4c27e836.jpg 25298.jpgAlbum 25298
PB210 ditto:
* PB210 Sedan DX and Sedan GL used square gauges.
* PB210 Sedan GX and all Coupes used the sport instrument cluster with individual guages
11371.jpgAlbum 11371 11449.jpgAlbum 11449 19069.jpgAlbum 19069
GX | 160Z
21038.jpgAlbum 21038
Index
Round (maru) type
174_65cc5de7c61e4.pngPost 498276 26896.jpgAlbum 26896
Auxiliary Meters
Square Gauges: Three large, plus one small next to radio
Round Gauges:  Three large, plus three small over radio
OPTION: small gauges could be fitted to the console.
Small Round
B210 Round Cluster was flanked by three small gauges (Clock, AMP, OILP) above the radio. Clock was standard on GX, optional for the others. Voltmeter replaced the AMP gauge for B211 (after 1975 October).
early: Clock |  AMP  | OILP
late:  Clock | Volts | OILP
For early B210, the GL grade came with OIL.P and AMP moved to the console
174_65cc5db438b15.jpgconsole
For late JDM B210, the OIL and Volts could be moved to the Console, and then Calendar and Altimeter fitted to the dash.
Small Square
B210 rectangle dash had space for one small gauge (Clock or Calender). If no options were fitted, an 'S' or 'D' blanking plate was attached.
#Small Clock was OPTION
11137.jpgAlbum 11137
#Calendar was OPTION (late B210)
27256.jpgAlbum 27256
Types
Ammeter + Oil Pressure
Early: Fitted to GX sedan and all Coupe dashes, or to the GL long console
  • dash: Sedan.GX, all Coupe
  • console: Excellent GL
  • OPTION console for all
174_65cc5db438b15.jpgOPTION Catalog
24845-H5500 METER ASS'Y-ampere
24870-H5500 GAUGE ASS'Y-oil pressure
08510-51242 SCREW-Tapping screw, Pan head 5x12mm 4
25070-89901 UNIT-oil pressure gauge
OIL.P + AMP KANTO SEIKI TOKYO
174_65cc5d3097fd2.jpgPost 498276 174_65cc5d4413995.jpgPost 498276
AMP -30 to 30 amperes
174_65cc5d50eadf3.jpgPost 498276 174_65cc5d6782860.jpgPost 498276
OIL.P 0 to 6 kg-cm
174_65cc5d7782fae.jpgPost 498276 174_65cc5d8e489cf.jpgPost 498276
Voltmeter
Voltmeter replaced the tachometer. B211 GX used a small voltmeter
Econometer
For Japan, after '75-10 and Econometer (vacuum gauge) was fitted to the tachometer spot (round or square). Tachometer was only standard on GX.
Calendar
A digital "Calendar Kit" could be purchased for late B210 (round & square versions were available).
Speedometer
3266.jpgAlbum 3266
100 MPH
early 120Y came with 100mph
120 MPH
North America came with 120mph
11560.jpgAlbum 11560
Canada late came with dual-scale KPH/mph
USA late came with dual-scale MPH/kph
160 KPH
B210 & HB210 came with 160 kph
2447.jpgAlbum 2447 3953.jpgAlbum 3953 13915.jpgAlbum 13915 3267.jpgAlbum 3267
180 KPH
GX were fitted with 180 kph speedometer
B210 GX sedan
B210 GX coupe
PB210 ALL
* PB210 square Sedan DX, GL
* PB210 round Sedan GX, all Coupe
17422.jpgAlbum 17422
180kph speedo can be retrofitted to regular B210s
26915.jpgAlbum 26915
Clock
Small Clock
11137.jpgAlbum 11137 174_6154f54e13d07.jpgPost 495921
Large Clock
Clock Mask (delete blank) 'DATSUN'
Because of the curved B210 dashboard design, RHD and LHD clocks angled differently.
LHD
RHD
Cluster Meter
BRAKE lamp or no brake lamp
174_57f5861dc7d6f.jpgPost 481636 174_57f589fee8038.jpgPost 481636
Tachometer
RHD vs LHD
For rectangle gauge dash, the large meters (clock, tachometer and speedometer) differ RHD vs LHD. They are almost the same but mount at slight angles, so the cases differ. Discussion: 120y b210 factory tacho meter (US LHD model)
The small gauges (e.g. small clock) are same RHD and LHD.
LHD
c0ae7659.jpg Tachometer_B210_rear.jpg 15705.jpgAlbum 15705 12134.jpgAlbum 12134 12133.jpgAlbum 12133
Overhead Console
From early B210 Japan Optional Parts. Includes bracket, internal temperature gauge and (?)external temperature gauge.
オーバーヘッド コンソール ブラケット 内温度計
73980-H5025 Overhead Console 灰色 ash color [grey]
73980-H5026 Overhead Console 茶色 light brown color
174_58337e5ec78e1.jpgPost 482423
SQUARE SPEEDOMETER ASSY
early
 24850-H5000 (Max 160km, Red zone 140km) SMDX, V.STD
 24850-H5001 (Max 160km, Red zone 140km) (from '75-4) SMDX, V.STD
 24850-H5010 (Max 160km, Red zone 140km) (trip meter) S.DX,GL V.DX,SPDX
 24850-H5011 (Max 160km, Red zone 140km) (trip meter) (from '75-4)
late
 24850-H5001 V.SMDX
 24850-H5011 V.DX,SPDX
 24850-H7400 STR [STD 4-speed 2-dr]
 24850-H7405 S.A12.DX,GL S.A14.GL.MT
 24850-H7905 S.L16.GL S.A14.AT
ROUND SPEEDOMETER ASSY
early
 24850-H5500 (Max 160km, Red zone 140km) K.DX,GL
 24850-H5501 (Max 160km, Red zone 140km) (from '75-4) K.DX,GL
 24850-H5700 (Max 180km, Red zone 150km) GX
 24850-H5701 (Max 180km, Red zone 150km) (from '75-4) GX
 * H57 also used by PB210 S.GX and all PB210 coupes
late
 24850-H7415 S.A14.GX K.A12,A14.MT
 24850-H7905 L16(except Sedan GL) K.A14.AT
NOTE: GB211 is L16-powered B210
ECONOMETER ASSY
 24895-H7400 SQUARE S.A14,L16.GL *S.A12
 24895-H7410 ROUND K.A14S,L16.GL *S.KA12S
North America
24855-H6200 ASSY-TACHOMETER OP -0775
24855-H7200 ASSY-TACHOMETER OP 0875-
25007-H6100 MASK-TACHOMETER
#Small Clock - OPTION - H50 types same as JDM
 27380-H7211 ASSY-CLOCK,SMALL TYPE (K.S.) FOR SERVICE OP 0875-
 27380-H5016 ASSY-CLOCK,SMALL TYPE (K.S.) <> 27380-H5015
 27380-H5001 ASSY-CLOCK,SMALL TYPE (JECO)
 25005-H5015 MASK-CLOCK,SMALL TYPE
 24043-H7400 CABLE-CLOCK,SMALL TYPE 0875-
#Large Clock - OPTION
 27380-H7206 ASSY-CLOCK,LARGE TYPE (K.S.) FOR SERVICE 0875-
 27380-H7200 ASSY-CLOCK,LARGE TYPE (CITIZEN) 0875-
 27380-H6100 ASSY-CLOCK,LARGE TYPE (JECO)
 27380-H6110 ASSY-CLOCK,LARGE TYPE (CITIZEN)
 27380-H6115 ASSY-CLOCK,LARGE TYPE (K.S.)
PB210
174_5dacd39d69356.jpgPost 492908 174_5dacd35876984.jpgPost 492908
174_5dacd380b5f51.jpgPost 492908
GX (180kph) Kanto Seiki speedometer
174_5dacd36ca81b4.jpgPost 492908 174_5dacd37364013.jpgPost click for topic
Round
round gauge (maru 丸 型) - Sedan GX, Coupe DX, Coupe GL, Coupe GX
* GX: full gauges
* GL: Clock instead of tachometer
* DX: blanking plates
1973-1975 GX gauge set (small gauges were OPTION on DX and GL)
174_5d3df7a384903.jpgPost 492004
174_5d3df80e600be.pngPost 492004
24850-H5700 SPEEDOMETER ASS'Y (Max 180 km, Red zone 150km)
24850-H5701 SPEEDOMETER ASS'Y (Max 180 km, Red zone 150km)(from '75-4)
* H57 also used by B210 GX
24850-H7915 SPEEDOMETER ASS'Y (Max 180 km, Red zone 150km)(from '75-10) Coupe GX
27380-H5600 CLOCK ASS'Y-A (JECO ジエコー) Coupe GL, OP Coupe DX <> 27380-H5610
27380-H5610 CLOCK ASS'Y-A (Citizen シチズン) (from '73-10) Coupe GL, OP Coupe DX
27380-H5615 CLOCK ASS'Y-A (from '75-10) Coupe GX
27380-H5700 CLOCK ASS'Y-B [small type] (JECO) GX, OP Coupe DX, Coupe GL
27380-H5715 CLOCK ASS'Y-B [small type] (from '73-10) <> 27380-H5700
27380-H5716 CLOCK ASS'Y-B [small type] (from '75-11) <> 27380-H5715
25005-H5500 MASK-clock [small type] Coupe DX,GL
24855-H5700 TACHOMETER GX
24855-H5500 TACHOMETER OP Coupe DX,GL
24855-H7410 TACHOMETER (from '75-10) OP Coupe GX
25007-H5500 MASK-tachometer Coupe DX
1975.10 OPTION: Calendar or Altimeter. AMP changed to VOLT
27481.pngAlbum 27481
25031-H7400 VOLT METER (from '75-10) Coupe GX
25510-H5600 KIT CALENDAR (from '75-10) OP Coupe GX
25035-H5600 KIT ALTIMETER (from '75-10) OP Coupe GX
Rectangle
rectangle gauge (kaku 角型) - Sedan DX, Sedan GL
24850-H5800 SPEEDOMETER ASS'Y (Max 180 km, Red zone 150km)(trip meter)
24850-H5801 SPEEDOMETER ASS'Y (Max 180 km, Red zone 150km)(trip meter)(from '75-4)
27380-H5100 CLOCK ASS'Y-A [large type] (JECO) Sedan GL, OP DX
27380-H5110 CLOCK ASS'Y-A [large type] (JECO) (from '73-10) <> 27380-H5100
27380-H5115 CLOCK ASS'Y-A [large type] (JECO) (from '75-10)
27380-H5001 CLOCK ASS'Y-B [small type] (JECO) OP DX, GL
27380-H5011 CLOCK ASS'Y-B [small type] (from '73-10) <> 27380-H5001
27380-H5016 CLOCK ASS'Y-B [small type] (from '75-11) <> 27380-H5011
25005-H5000 MASK-clock [small type,'S' (clock delete)]
24855-H5000 TACHOMETER OP DX,GL
24800-H5000 TACHOMETER OP DX,GL
25031-H5101 VOLT METER (from '75-10) OP GX
25511-H5100 CALENDAR (from '75-10) OP GX
24855-H7400 TACHOMETER (from '75-10) OP GX
25007-H5000 MASK-tachometer 'SUNNY' DX
H51 calendar
Swapping Round Gauges
The dash for round gauges differs from the standard dash.
Using Round gauges in Rectangular dash can be achieved with some cutting of the dash frame and modifications to the gauges.
Discussion: POST B210 Round Gauge Dash Electrics
Custom
Color dash
3880.jpgAlbum 3880
1975 Dodge Colt (Galant) dash fitted to B210
17069.jpgAlbum 17069
