Datsun 1200 sedans have a regular trunk (boot) at the rear of the car. Coupes, being fastbacks but not hatchbacks, have a teensy-weensy trunk lid at the back. The sedan trunk is very roomy for a car this size, and can hold about eight grocery bags, or luggage for five people. The lids are secured with a key lock.
Contents[hide] |
In sedans, the Fuel tank is inside the trunk, next to the rear Seat, hidden behind a finisher panel.
Standard Equipment
The trunk came factory equipped with:
- Scissor Jack
- S-shaped Jack Handle
- Wheel Wrench in black Bag
- Spare Tyre
For more details, see: Jack![]()
Locks
Sedan
84300-H1000 ASSY-TRUNK LID SEDAN B110/PB110 84830-H1000 BUMPER-trunk lid (2)
All parts are same B110 & PB110 — lock, lid, hinges, jack equipment, mat, etc. — except for the finisher board.
Bumper
80833-78500 RUBBER-BUMPER (2) SEDAN
diameter 14mm (at widest part) height 16mm (cylindrical portion, not counting the tab)
Moulding
Option: trunk lid trim "handle" (cosmetic finisher) is 44cm long
Also used on PB110
Per the catalog, is not specific to any specific trim
84820-H1000 HANDLE-TRUNK SEDAN 84821-H1000 WASHER-TRUNK LID HANDLE SEDAN 84832-H1000 SPACER-TRUNK LID SEDAN (*) 08310-50812 SCREW (3) 08915-13510 WASHER (3)
* 1971 catalog shows small piece and specifies 3 spacers
1973 catalog (for same part number) shows one large spacer
トランク モール
Finishing Panels
The trunk finishing panels are made out of pressboard:
Panel hides the fuel tank and fuel lines
84910-H1000 FINISHER-trunk room (head board) <> 84910-H2800 84910-H1900 FINISH-TRUNK ROOM T=2.5 SEDAN USA 84910-H2800 FINISHER-trunk room B110 (from C/#B110-174795), 1972, PB110 S-DX 84910-H2900 FINISHER-trunk room PB110 S-GL,S-GX
H19 VS H10 differs slightly in the region of the fuel filler hose cutout.
Hinges
84520-H1001 HINGE-TRUNK LID RH SEDAN 84521-H1001 HINGE-TRUNK LID LH SEDAN
Coupe
Coupe has a small trunk lid.
84300-H1800 ASSY-TRUNK LID COUPE B110/PB110
Coupe boot lid has a stylish ridge down the centre
Of course, you can always fill the boot with speakers
Fitting
The 1200 coupe has interior plastic covers inside -- lots 'o plastic. There is plastic on the bottom side of the trunk lid too.
Trunk Lid Finish panel 84911-H1800 FINISH-TRUNK LID T=1.5 84905-H1800 STOPPER-TRIM TRUNK FLOOR
Rear Floor
- 08510-51612 SCREW-TAPPING M5 FIX TRIM (16)
- 08963-20540 NUT-SPRING TYPE A M5 FIX TRIM (16)
- 08915-43510 WASHER-PLAIN M5 FIX TRIM (16)
- 84902-H2500 TRIM-TRUNK FLOOR CENTER
- 84902-H7100 TRIM-TRUNK FLOOR CENTER (BLUE,LB-211
- 84902-H7101 TRIM-TRUNK FLOOR CENTER (BEIGE,LH-20
- 84902-H7102 TRIM-TRUNK FLOOR CENTER (BLACK,LG-13
- 84902-H1800 TRIM-TRUNK FLOOR CENTER
Rear Side
- 01553-00291 CLIP-TRIM (14)
- 66919-H1099 CLIP-TRIM (15)
- 84921-H1800 FINISH-TRUNK SIDE RH T=1.5
- 84921-H1900 FINISH-TRUNK SIDE RH T=2
- 84921-H2500 FINISH-TRUNK SIDE RH T=1,5
- 84922-H1800 FINISH-TRUNK SIDE LH T=1.5
- 84922-H2500 FINISH-TRUNK SIDE LH T=1.5
Rear
- 01553-00291 CLAMP (24)
- 84931-H1800 FINISH-TRUNK REAR T=2
- 84931-H1801 FINISH-TRUNK REAR T=2
- 84931-H2501 FINISH-TRUNK REAR T=2
Floor trim panels are fastened by the typical B110 sheet screws (B210 changed to bolts/machine screws).
Plastic Panel Fasteners
- 01553-00291 CLAMP/CLIP
- superseded 66919-H1001 CLIP-TRIM
76983-68400 LOCK-MALE 76982-68400 ASSY-LOCK FEMALE 08410-41210 SCREW-TAPPING 08915-43410 WASHER-PLAIN 08915-13410 WASHER-LOCK
84932-H1800 MASK-REAR LAMP T=2 84932-H2500 MASK-REAR LAMP T=2 84941-H1800 COVER-TRUNK LID HINGE 84939-H1800 WELT-TRUNK FINISH
Carpet
Floor Fitting
- 32021-35000 PLUG-INSPECTION HOLE 55D USA
- 74891-H2500 ASSY-COVER INSPECTION HOLE
- 08510-61212 SCREW (6)
Truck
Weatherstrip
84810-H1001 WEATHERSTRIP-TRUNK LID Sedan $53.73 USD * superseded 84810-H1800 WEAHERSTRIP-TRUNK LID Coupe
Boot (trunk) seal is same material as 510. Possibly 510 part will fit with trimming for length.
84806-A4600 Weatherstrip 510 $60.75 USD
510 Trunk Weather Strip 84810-21001
Trunk Opener
B210 had an option of electric trunk opener. Possibly could be retrofitted to 1200?
FRP
1200 boot lid, 4.5kg, $220 AUD
