Battery
Revision as of 08:10, 29 March 2025; view current revision
Note that the Battery from most cars interchange with the Datsun 1200 -- even large batteries. The A12 does not need a high-power battery and often a worn battery that can no longer start a V8 will work fine in your 1200 for another year or two. The 1200 can take quite large batteries, although newer very small batteries will save weight thus gaining "free" horsepower. In Japan, 1200s came with very small batteries.
Also see Battery Maintenance and Cable Cleaning.
Datsun 1200 stock large battery (big enough for a V8) is good if you want to use the stock hold-down and tray. Otherwise fit a smaller battery. One with half the weight is plenty for the A-series engine.
POST Gary_P said:
I've been running the Odyssey PC680MJT batteries in both 1200's. One has been in use for a year, the other has been in 2 years. 220 CCA, very small, and 15# [pounds]. http://www.summitracing.com/parts/ODY-PC680MJT/
Note that GM batteries with side-mounted terminals won't work unless you change the battery cable terminals to match.
Australia
What size battery was standard for Datsun 1200 in Australia?
In Japan, the 1200s come with a very small battery, (tall, but small).
JDM battery, takes up only a portion of the battery tray. This is powering a street/race A14
16698.jpgAlbum 16698
Type: 38B19L
specifications
* Height: 20.4 mm (7-7/8 inch)
* Width: 18.8 mm (7-3/8 inch)
* Depth: 12.8 mm (4-7/8 inch)
* Weight with acid: 9.7 kg (21.4 pounds)
* CCA: 274
* Capacity @ 20 Ah: 33-35
* Reserve Capacity Minutes: 52
B110
* Battery: 40B19R
* Length: 19.7 cm
* Width: 12.9 cm
* Height: 20.0 cm
* modern spec: TH: 222 Capacity 5hrs (Ah) 28 Ah
20872.jpgAlbum 20872
* Tray
  * Length: 20.5 cm
  * Width: 13.5 cm
Battery Tray - 20.5 x 13.5 cm
25016.jpgAlbum 25016 25017.jpgAlbum 25017
keywords: バッテリ バッテリートレー
Also see Battery Part Numbers
B120 8910-
* 24420-M7000 FRAME-BATTERY FIX $8.29 USD
  24420-J0600 F/COLD ZONE $11.15 USD
* 24422-18001 ROD-BATTERY FIX LONG
* 24422-G1600 ROD-BATTERY FIX F/50A
* 24422-H1000 ROD-BATTERY FIX SHORT
Battery 8910-
* B441M-3B197
* B441M-3B201
* B441M-5D237
* 24428-89900 TRAY-BATTERY -8910
* 24428-89920 TRAY-BATTERY 8910- $24.61 USD
  F/COLD ZONE -8910
Body Sheet Metal
The battery platform/box/frame is spot-welded to the right hoodledge (inner fender, see Hoodledge).
Angled: early 1200s
24426-H1001 BRACKET-BATTERY SUPPORT
24427-H1000 STAY-BATTERY BRACKET SEDAN <> 24427-H1001
North-south: late 1200s 64135
24426-G1600 BRACKET-BATTERY SUPPORT 8504-8901 24421-G1900 2 0
22421-G1900 BRACKET-BATTERY SUPPORT 8901-
Angled: early 1200s
174_67e7aa2118398.jpgPost 498832 EngineBay-002.jpg 312678_2014973619590_1401316972_31824478_1483769309_n-1.jpg
DSCN0487.jpg 2973.jpgAlbum 2973
The best fit is with the Positive terminal on the right side of the battery top.
USA models originally used a large full-size battery (Group 24). With today's better batteries, a much smaller battery is all you need.
* Group 24: 41 pounds. 6.75 wide, 8.75 in Tall, 10.87 long
* Group 25: 36 pounds. 6.75 wide, 8.75 in Tall, 9.69 long
* Group 26: 31 pounds. 6.75 wide, 7.81 in Tall, 8.75 long
A Group 26 battery is a lot lighter and more powerful than the original specification. But it doesn't fit very well using the original hold-down as you can see in this photo:
15362.jpgAlbum 15362
Group 24 battery
* CCA: 525
*  Reserve Capacity: 90
Group 25 battery
* CCA: 525
*  Reserve Capacity: 85
Group 26 Battery
* CCA: 525
* Reserve Capacity: 80
Reserve Capacity (RC) is the number of minutes a fully charged battery at 80° F (26.7° C) can be discharged at 25 amps until the voltage falls below 10.5 volts. More RC is better in every case. To convert Reserve Capacity to approximate Ampere-Hours, multiple RC by 0.4.
small battery
14768_4d450868dfd1d.jpgUpload click to view
Small Advanced Battery
21819.jpgAlbum 21819
Odyssey Battery PC680MJT
* $160
* 15 pounds
* 220 CCA
* Top Post
* Reserve Capacity  24 minutes
* Length (in)  7.250 in.
* Width (in)  3.000 in.
* Height (in)  6.650 in.
http://www.braillebattery.com/index.php/batteries/b106/
Six pounds, $140USD
B106
8618_4b10ecdd34a11.jpgPost 293208
Odyssey ER30
* CCA: 450
* Capacity (Ah): 34
* Reserve Capacity: 60
* Weight (Kgs): 9.5
* price: $290 USD
* Length: 9.8"
* Width: 3.8"
* Height: 6.1"
Battery Hold-down
The genuine battery hold-down:
* 24420-J0600
  For batteries 6.75 wide, 8.75 in Tall, 10.87 long (Group 24 size)
15373.jpgAlbum 15373
Factory J-Hook 24424-H5000 (9.25" 235mm)
Cable
North America 24110-H1900 ASS'Y-CABLE, battery (+) North America{searchPart|24110-H1650}} 24110-H1005 24110-H1605
Japan cable fit smaller battery terminals
B122 (+) cable is a single wire with a tab connector mid-way along the length.
Negative Cable: black with large wire to engine, small wire to body earth point
Positive Cable: black with large wire to starter, small white wire to Fusible Link
30134.jpgAlbum 30134 30135.jpgAlbum 30135
24110-H1650
1991 cables
30136.jpgAlbum 30136
Web Search:サニー1200バッテリーケーブル
Cable Routing
The Negative battery cable (black cable) bolts to the timing cover bolt. It is important to have the engine grounded like this, and not the body — because the starter uses the most power, the cable needs to go directly to the engine block.
See also: Battery Wiring
Be sure the big and little wires are attached correctly
21177.jpgWiring
Factory Photo
ddgonzal's 1972 1200
The positive cable is bolted directly to the starter solenoid:
15374.jpgAlbum 15374
Voltage & Amps
Battery Relocation
