B310 Console
Revision as of 06:11, 27 September 2025; view current revision
Category: Interior
<-- back to Console
Datsun B310 Sunny/210 consoles came in short or long versions. They are the same, except the long one goes further back under the emergency brake handle, and the short one has one rear mounting screw.
174_68d717170786c.jpgPost 499057 174_68d70bd6ad569.jpgPost 499056
22307.jpgAlbum 22307 6951.jpgAlbum 6951
Canada brochure
174_5d81e267e1e7f.jpgbrochure
Console box with #armrest (SGL/SGX trim)
174_5d81707e886a8.jpgPost 492627
Small console
The short console is relatively rare, only applying the DX models. It came in Black or Brown.
Uses the same mounting bracket as the large console.
174_68d70bcf960e1.jpgPost 499056 174_68d70be7a0a75.jpgPost 499056 174_68d70bd6ad569.jpgPost 499056
174_68d70bee72ae4.jpgPost 499056 174_68d70c0c3378a.jpgPost 499056
Large Console
Uses the same mounting bracket as the small console.
174_68d717170786c.jpgPost 499057 174_68d7171e3c3cc.jpgPost 499057 174_68d71728559f2.jpgPost 499057 174_68d717622e267.jpgPost 499057
Bracket (same as short console)
174_68d7768942f8d.jpgPost 499060
Tray bottom markings
174_68d7769b3f6bb.jpgPost 499060
N-P
クロ 96910-H8560 [black]
チヤ 96910-H8561 [charcoal]
アオ 96910-H9100 [blue]
In Datsun 510
174_68d776710df0e.jpgPost 499060
Armrest
For the SGL and SGX trims, optional for Van Super Deluxe. Remove the large console bolt cover, then bolt on this box armest using longer screws.
174_68d7764d694c8.jpgPost 499060 174_68d7761688d78.jpgPost 499060 174_68d77627522ed.jpgPost 499060 174_68d77635d805e.jpgPost 499060
The lid hinge appears to be plastic and often breaks. Some replace it with an external metal hinge
174_68d7756e0a9a8.jpgPost 499060
174_68d77cc7a7153.jpgPost 499060
CONSOLE BOX LID for SGL and SGX
96920-H7825 BLACK
96920-H7826 BROWN
* Sunny California GL
08513-62597 SCREW (2) [front]  Tapping screw, Pan head M3.5 x 25mm
08513-61697 SCREW (2) [center] Tapping screw, Pan head M3.5 x 16mm
96931 COVER-FINISHER ARM REST [for armrest front screws]
      96910-H9110 COUPE.ES BLACK F/INDICATOR
      96910-H9111 COUPE.ES BROWN F/INDICATOR
      96910-H9113 COUPE.ES 8011- BLUE
      96926-H8901 OPTIONAL VAN.STD 8011- BLACK F/STEREO
      96926-H8902 OPTIONAL VAN.STD 8011- BROWN
      96927-H8560 BLACK
      96927-H8561 BROWN
      96927-H8920 OPTIONAL 8011- 2S.A13.DX, 4S.GL, 4S.A15.GX-A15S.F4
96932 COVER [for armrest center screws]
      96928-H8560 BLACK
      96928-H8561 BROWN
Brown can be repainted black
174_68d775ae26812.jpgPost 499060 174_68d775baefa4c.jpgPost 499060 174_68d775cf591c9.jpgPost 499060 174_68d775f6de1b5.jpgPost 499060
Parts
JDM all years
* large console box ALL trims except Standard and Deluxe
* small console box SEDAN and COUPE Deluxe
* no console box - Standard models and Deluxe Van
SMALL CONSOLE BOX - Deluxe SEDAN and COUPE
174_68d70dfb4d6b3.jpgPost 499056
LARGE CONSOLE BOX - ALL trims except Standard and Deluxe
174_68d71975ba838.jpgPost 499057
Reference: B310 parts catalog C-403 Figure H63-09 version 1983-09
96953 FRONT CONSOLE POCKET
      96925-H8560 BLACK
      96925-H8561 BROWN
96960 96917-H8560 FINISH-CONSOLE BLACK
      96917-H8561 FINISH-CONSOLE BROWN
      96929-H8920 8011- TV TUNER
      96929-H8921 8011- SPEAKER BAL
      96929-H8922 8011- BASS-TRE CONT
      96929-H8923 8011- SPEAKER BAL+BASS-TRE CONT
08513-61697 SCREW [rear] Tapping screw, Pan head M3.5 x 16mm
96986 COVER 8011- OPTION Coupe.GS,GX A15E
      96926-H8901 BLACK
      96926-H8902 BROWN
96991 96970-H8560 BRACKET-CONSOLE
08513-61697 SCREW (4) Tapping screw, Pan head M3.5 x 16mm
#Pocket bottom markings
174_68d77693951f7.jpgPost 499060
クロ 96925 8500 [black]
チヤ H8561 [charcoal]
アオ H8562 [blue]
Parking Brake Lever Cover
The brake cover is a complement to the console.
74980Y COVER ASSEMBLY-PARKING BRAKE LEVER
74965-H8502 BLACK
74965-H8503 BROWN
08513-61697 SCREW (2) Tapping screw, Pan head M3.5 x 16mm
174_68d71733c2787.jpgPost 499057 174_68d717441c5ce.jpgPost 499057 174_68d7174c923b1.jpgPost 499057
Shift Boot
B310 uses larger shifter boot than the one fitted to the B110 shifter boot. It has bolt holes for fastening, unlike the B110 boot.
Sold by Bprojects
174_68d7075073eb3.jpgPost 499055 174_68d707478d76b.jpgPost 499055
174_68d7074118e80.jpgPost 499055
96935-H8500 BOOT (BLACK)(G) <> 96935-H8560 $35.58 USD
96935-H9160 BOOT (BLUE) 0879- $32.62 USD
96935-H9100 BOOT (BLUE) -0779 $30.12 USD
96935-H8561 BOOT (BROWN) $35.58 USD
センターコンソール center console
Web Search: サニー310 コンソール ボックス SUNNY 310 CONSOLE BOX
