Gas Station Information
 USA 1972 Owners manual (see page 43 for details):  |
Opening the hood (bonnet):
- Brake Cylinders: Fill to top line (do not fill to the top of the reservior)
 - Clutch Master Cylinder: Fill to top line (do not fill to the top of the reservior)
 -  Radiator: Fill to 1 inch (2.5 mm) below filler cap with Coolant
- With heater: 5-3/16 US quarts (4-15/16 Imperial qts) or 4.9 liter
 - W/o heater: 4-7/16 US quarts (3-11/16 Imperial qts)
 - Windshield washer tank (windscreen washer)
 USA 1972 Owners manual (see page 25 for details):  |
-  Engine Oil: Recommend Oil Viscosity Number varies by ambient temperature range of your climate.
- Oil pan capacity: 2-7/8 US qts (2-3/8 Imp. qts) or 2.7 liter
 - Oil filter: 1-1/8 US pints (1 Imp. pint) or 0.54 liter
 - See Oil Specifications for more details.
 - Battery: fill each cell to about 0.2 inch (5 mm) above the plates. Most batteries have a fill indicator. Do not overfill.
 USA 1972 Owners manual (see page 24 for details):
 It is normal to add some engine oil between the 3,000 mile (5,000 km) oil changes.  |
- Transmission Gear Oil:
 - Differential Gear Oil:
 - Automatic Transmission Fluid: ATF
 - Multipurpose grease: For "lube and filter" job and other Lubrication uses
 - Brake Fluid:
 - Clutch Fluid:
 - Antifreeze for radiator: Coolant
 During freezing weather...  |
- Petrol: 9 Imperial gallons
 - Gasoline: 10 US gallons
 - 87 R+M/2, or 90 RON equivalent. See Fuel Requirements
 USA 1972 Owners manual (see page 22 for details):
