60-Series Transmission
Revision as of 05:52, 10 April 2009; view current revision
Categories: Transmission | Drivetrain Modifications
The 60-series 5-speed is a beefier model than the stock Datsun 1200 GX-5's 56-Series Transmission. The 60-series can handle the torque from A14 and A15 engines. They came in two varieties:
  • 60L for A-series engine (1979 B310 Sunny, manufactured through 1979 September)
  • 60A for A-series engine (1980-up Sunnys)
Note that this series may be available for other engine types, so make sure you get one to match the A-series engine.
Swap Into Datsun 1200
(A special note of thanks to Davo1200 who started this section originally in the old Tech Section)
How do I install a 5 speed Sunny box?
60a 5-speed swap Notes
Pitroad says the South Africa Datsun Bakkie (B140) had a FS5W60A 5-speed, and that the trans crossmember might work for a B110.
  • the 60a 4-speed and 60a 5-speeds are the same length as the stock Datsun 1200 transmission, and the shifter is in the same spot
  • There are two different types of 60A rear engine mounts (transmission mounts).
    6946.jpg rear engine mounts
    8131.jpg custom engine mounts <li>The stock Datsun 1200 driveshaft should be used. While the B310 driveshaft is the same length, it has the larger H150-style rear flange.
    7474.jpg pic
  • The reverse-light switch is right where the Datsun 1200 chassis x-member mount is. You can remove the switch and plug the hole. A spare A12 engine-block drain plug fits (from the side of the engine block). Some say you can beat the chassis out to make room
  • The stock Datsun 1200 flywheel and clutch can be used
Vanette Transmission
4650.jpg FS5W60A vs RS5W60A 5-speed comparo
Parts
Part Number prefixes:
  • H90xx B310 unique to F5W60L
  • 180xx B10 56-series
  • H73xx B210 60-series
Case Comparo
B210 F4W60A
  • 32100-H7300 ASSY-CASE,TRANSMISSION B210 F4W60A 0974-0776
  • 32100-H7302 ASSY-CASE,TRANSMISSION B210 F4W60A 0876-0377
  • 32100-H8902 ASSY-CASE,TRANSMISSION B210 F4W60A 0477-
B310 F4W60
  • 32100-H8902 CASE COMP-TRANSMISSION B310 F4W60 CANADA
  • 32100-H8903 CASE COMP-TRANSMISSION B310 F4W60 0879- USA
  • 32100-H9301 CASE COMP-TRANSMISSION B310 F4W60 0879- USA (supercedes 32100-H8903)
B310 FS5W60A
  • 32100-H9001 CASE COMP-TRANSMISSION B310 FS5W60A -0779 [FS5W60L, dogleg]
  • 32100-H9300 CASE COMP-TRANSMISSION B310 FS5W60A 0879- CAN (supercedes 32100-H9001)
  • 32100-H9301 CASE COMP-TRANSMISSION B310 FS5W60A 0879- FED, CAL (supercedes 32100-H9001)
F4W60L
rally cross of F4W60L Gear ratio
  • 1st: 3.19
  • 2nd: 2.38
  • 3rd: 1.89
  • 4th: 1.00
FS5W60L
Gearset
  • 32241-H9001 SHAFT-MAIN 1
  • 32264-H7300 BEARING-NEEDLE MAIN SHAFT 2
  • 32260-H9000 GEAR ASSY-3RD 27T 1
  • 32604-H9000 RING-BAULK 4
  • 32603-18000 RING-SYNCHRONIZER 4
  • 32609-18000 INSERT-SHIFTING 6
  • 32601-H9001 HUB SYNCHRONIZER-2ND & 3RD 1
  • 32606-18000 SLEEVE-COUPLING 2
  • 32250-H9000 GEAR ASSY-2ND 1
  • 32253-H7300 BUSH-1ST GEAR (MAIN SHAFT) 2
  • 32246-H7300 WASHER-THRUST 1
  • 32273-H7300 BEARING-(BALL,) MAIN SHAFT 1
  • 32246-H9000 WASHER-THRUST MAIN SHAFT 1
  • 32267-H7300 BEARING-(NEEDLE,) MAIN SHAFT 1
  • 32230-H9000 GEAR ASSY-1ST 1
  • 32602-32200 SPRING-SHIFTING INSERT (SYNCHRONIZER INSERT) 3 unique to F5W60L
  • 32608-H9000 INSERT-SHIFTING 9
  • 32258-H9001 HUB SYNCHRONIZER-1ST & REVERSE 1
  • 32245-H9000 GEAR-REVERSE, MAIN SHAFT
  • 32234-H9000 RETAINER SHIFTING INSERT 1 Catalog is incorrect
  • 32354-H9000 NUT-HEX (M25 X 1.0) 1
  • 32228-H9000 RING-SNAP OVERDRIVE BEARING 1 ? Or 00922-12200?
  • 00922-12200 RING-SNAP (T=1.2)? Or 32228-H9000?
  • 32227-H9000 BEARING-(BALL,) MAIN SHAFT END 1
  • 32228-H9000 RING-SNAP,MAIN SHAFT END BEARING 1? Or 00922-12200?
  • 32204-H7300 RING-SNAP MAIN DRIVE GEAR SELECT T=1.34-1.40 1 Select only one 32204
  • 32204-H7301 RING-SNAP MAIN DRIVE GEAR SELECT T=1.40-1.46
  • 32204-H7302 RING-SNAP MAIN DRIVE GEAR SELECT T=1.46-1.52
  • 32204-H7303 RING-SNAP MAIN DRIVE GEAR SELECT T=1.52-1.58
  • 32204-H7304 RING-SNAP MAIN DRIVE GEAR SELECT T=1.58-1.64
  • 32204-H7305 RING-SNAP MAIN DRIVE GEAR SELECT T=1.64-1.70
  • 32204-H7306 RING-SNAP MAIN DRIVE GEAR SELECT T=1.70-1.76
  • 32209-H7300 SPACER-BEARING MAIN DRIVE GEAR 1
  • 32214-H7300 RING-MAIN BEARING 2
  • 32203-H7300 BEARING-MAIN DRIVE 1
  • 32200-H7300 GEAR ASSY-MAIN DRIVE 1
  • 32272-H7300 BEARING-PILOT MAIN SHAFT 1 1 of 3
  • 32268-H9000 RING-SNAP SELECT T=1.60 1 Select only one 32263
  • 32268-H9001 RING-SNAP SELECT T=1.65 Select only one 32263
  • 32268-H9002 RING-SNAP SELECT T=1.70 Select only one 32263
  • 32601-H9000-HUB SYNCHRONIZER-4TH & 5TH 1 Also F560A
  • 32340-H9000 GEAR ASSY-OVERDRIVE 1
  • 32345-H9000 BEARING-OVERDRIVE GEAR (NEEDLE MAIN SHAFT) 1
  • 32219-H9000 BEARING-COUNTER SHAFT 1 Also F460A 7812-
  • 32224-H7200 WASHER-THRUST COUNTER SHAFT FRONT SELECT T=2.30-2.35 1 Select only one 32224
  • 32224-H7201 WASHER-THRUST COUNTER SHAFT FRONT SELECT T=2.35-2.40
  • 32224-H7202 WASHER-THRUST COUNTER SHAFT FRONT SELECT T=2.40-2.45
  • 32224-H7203 WASHER-THRUST COUNTER SHAFT FRONT SELECT T=2.45-2.50
  • 32224-H7204 WASHER-THRUST COUNTER SHAFT FRONT SELECT T=2.50-2.55
  • 32224-H7205 WASHER-THRUST COUNTER SHAFT FRONT SELECT T=2.55-2.60
  • 32224-H7206 WASHER-THRUST COUNTER SHAFT FRONT SELECT T=2.25-2.30
  • 32224-H7207 WASHER-THRUST COUNTER SHAFT FRONT SELECT T=2.20-2.25
  • 32210-H9000 GEAR-COUNTER ASSY 1
  • 32219-H9010 BEARING-COUNTER SHAFT 1
  • 32220-H9000 GEAR-REVERSE COUNTER 1
  • 32222-H9003 RING-SNAP COUNTER SHAFT SELECT T=1.3 1 Select only one 32222
  • 32222-H9004 RING-SNAP COUNTER SHAFT SELECT T=1.4
  • 32284-H9000 WASHER-THRUST COUNTER SHAFT REAR 1 Mistake? See 32285N
  • 32282-H9000 GEAR-REVERSE IDLER 1
  • 32272-H7300 BEARING-REVERSE IDLER GEAR 2 2 of 3
  • 32285-H9000 SPACER-REVERSE IDLER GEAR 1
  • 32292-14600 PIN-RETAINING 1 Also F560A
  • 32281-H9000 SHAFT-REVERSE IDLER 1
  • 32284-N9000 WASHER-THRUST REVERSE IDLER 2
FS5W60A
  • 32136-H5000 OIL SEAL-REAR EXTENSION
  • 32160- many EXTENSION ASSY-REAR
Factory Service Manual says: If rear extension bushing is worn or cracked, replace it as an assembly of bushing and rear extension
