Also see: Power Windows
Ventilation
1972 USA Owners manual (see page 7 for ventilation -- opening of the windows: door window, ventilator glass, and Quarter Window):
Driving Safety and Comfort
Windshield/Windscreen
- Sedan/Truck/Van windshields differ from Coupe windshield
Trix fitted a bakkie windscreen to his 1200 coupe:
Replacement
For a discussion of how to replace the windshield glass, see 1200 ute windsceen install
SEDAN
- 72613-H1902, 72613-H1901 GLASS-WINDSHIELD PL (clear) T=6.6 2-dr SEDAN USA
- 72613-H1903, 72613-H1900 GLASS-WINDSHIELD PLT (tinted) T=6.6 OP 2-dr SEDAN USA
- 72613-H1003 GLASS-windshield from '70 Aug S-Std JDM replaces 72613-H1002
- 72613-H1103 GLASS-windshield from '70 Aug S-DX, S-GL, 4GX JDM replaces 72613-H1102
- 76210-H1001 WEATHERSTRIP-windshield from '70 Aug Sedan, Van replaces 76210-H1000
COUPE
- 72613-H1910,72613-H1913 GLASS-WINDSHIELD (tinted) T=6.6 Coupe USA
- 72613-H1802 GLASS-windshield Coupe from '70 Aug JDM replaces 72613-H1801
- 76210-H1801 WEATHERSTRIP-windshield from '70 Aug Coupe replaces 76210-H1800
TRUCK
- 72613-H1102 GLASS-WINDSHIELD all 7510-8611
- 72613-G1900 GLASS-WINDSHIELD all 8611-
- 72610-G1000 WEATHERSTRIP-WINDSHIELD all 7510-
VAN
- 72613-H1003 GLASS-windshield, front from '70 Aug V-Std replaces 72613-H1002 VS, VP
- 72613-H1103 GLASS-windshield, front from '70 Aug V-Dx, V-P replaces 72613-H1102
- 76210-H1001 WEATHERSTRIP-windshield Sedan, Van
Rubber Seals
- 72610-H1001,72610-H1000 WEATHERSTRIP-WINDSHIELD 2-dr SEDAN $95.37 USD
- 72610-H1800,72610-H1801 WEATHERSTRIP-WINDSHIELD Coupe
Moulding Trim Sedan & Van
S-DX, S-GL, 4-GX, Van-Dx
Early style: single upper piece
- 72810-H1100 SET-MOULDING, windshield
- 72812-H1100 MOULDING-windshield, upper
- 72814-H1100 MOULDING-windshield, side (R.H.)
- 72815-H1100 MOULDING-windshield, side (L.H.)
- 72813-H1100 MOULDING-windshield, lower
From '70 June: tree-piece upper
The SET replaces the earlier SET, but not vice-versa
- 72810-H1101 SET-MOULDING, windshield S-DX, S-GL, 4-GX, V-DX, V-P
- 72811-H1101 MOULDING-windshield, upper (R.H.)
- 72812-H1101 MOULDING-windshield, upper (L.H.)
- 72814-13600 CLIP-moulding
- 72814-H1101 MOULDING-windshield, side (R.H.)
- 72815-H1101 MOULDING-windshield, side (L.H.)
Moulding Trim Coupe
- 72810-H1800 SET-MOULDING, windshield
- 72812-H1800 MOULDING-windshield, upper
- 72814-H1800 MOULDING-windshield, side (R.H.)
- 72815-H1800 MOULDING-windshield, side (L.H.)
- 72813-H1800 MOULDING-windshield, lower
- 72810-H1801 SET-MOULDING, windshield S-DX, S-GL, 4-GX
- 72811-H1801 MOULDING-windshield, upper (R.H.)
- 72812-H1801 MOULDING-windshield, upper (L.H.)
- 72814-H1801 MOULDING-windshield, side (R.H.)
- 72815-H1801 MOULDING-windshield, side (L.H.)
Moulding Trim Truck
74-up Truck uses 8-piece molding set. Has L-shaped pieces in the corners.
- 72810-G1000 MOULDING SET-WINDSHIELD all 7510-
Door Glass
- 2-dr Coupe Door glass differs from 2-dr Sedan glass
- 2-dr and 4-dr glass differs
- 4-dr van and 4-dr sedan are the same
Wing Window
The wing window is officially named the Door Ventilator.
- 80244-H1001 GLASS-door ventilator (R.H.) 2 std
- 80245-H1001 GLASS-door ventilator (L.H.) 2 std
- 80244-H1101 GLASS-door ventilator (R.H.) 2 DX, 2 GL
- 80245-H1101 GLASS-door ventilator (L.H.) 2 DX, 2 GL
- 80244-H8000 GLASS-door ventilator (R.H.) Coupe
- 80245-H8000 GLASS-door ventilator (L.H.) Coupe
- 80250-H1001 CHANNEL ASS'Y-door ventilator (R.H.) 2 door [pivoting bottom-channel]
- 80251-H1001 CHANNEL ASS'Y-door ventilator (L.H.) 2 door [pivoting bottom-channel]
- 80250-H1800 CHANNEL ASS'Y-door ventilator (R.H.) Coupe [pivoting bottom-channel]
- 80251-H1800 CHANNEL ASS'Y-door ventilator (L.H.) Coupe [pivoting bottom-channel]
- 80270-H1001 FRAME ASS'Y-door ventilator (R.H.) 2 door
- 80271-H1001 FRAME ASS'Y-door ventilator (L.H.) 2 door
2-door sedan and Pickup
- 80282-H1001 WEATHERSTRIP-FRONT DOOR VENTILATOR, RH $13.69
- 80283-H1001 WEATHERSTRIP-FRONT DOOR VENTILATOR, LH $13.69
- 80246-H1000 RUBBER-glazing, door ventilator (2) 2 door, Coupe
- [holds glass in the pivoting bottom-channel]
- 80238-H1001 BRACKET-PIVOT TOP LOW $10.50 USD
- 80234-H1000 WASHER-BRACKET PIVOT $5.83 USD
- 80284-H1000 WASHER-RUBBER A $0.62 USD
- 80285-H1000 WASHER-RUBBER B $0.62 USD
- 08330-41020 SCREW-MACHINE M4 $0.80 USD
- 80292-73000 RIVET-SPECIAL [CLIP-TUBULAR] NLA
Coupe
- 80282-H1800 WEATHERSTRIP-front door ventilator (R.H.)
- 80283-H1800 WEATHERSTRIP-front door ventilator (L.H.)
4-door Sedan
- 82242-H1000 RH
- 82243-H1000 LH
Rubber Seals
- 80335-H1202 RUBBER-GLASS RUN"A" SEDAN 2DR NLA
- formerly 80335-H1200, 80335-H1201
- 80336-H1801 RUBBER-GLASS RUN SEDAN 2DR NLA
- formerly 80336-H1000, 80336-H1001, 80336-H1800
- 80316-H1200 RUBBER-GLEZING SEDAN 2DR $5.61 USD
Door Glass
- 80336-H1001 RUBBER-glass run "B" (2) 4 door, 2 door
- 80302-H1001 RUBBER-glass run "A" (2) 4 door
- 80302-H1202 RUBBER-glass run "A" (2) 2 door
- 80830-H1001 WEATHERSTRIP ASS'Y-front door (R.H.) 4 door
- 80831-H1001 WEATHERSTRIP ASS'Y-front door (R.H.) 4 door
- 80830-H1202 WEATHERSTRIP ASS'Y-front door (R.H.) 2-dr Sedan, Coupe
- 80831-H1202 WEATHERSTRIP ASS'Y-front door (R.H.) 2-dr Sedan, Coupe
- 80836-H1000 WEATHERSTRIP ASS'Y-door inside (R.H.) 4 door
- 80837-H1000 WEATHERSTRIP ASS'Y-door inside (L.H.) 4 door
- 80836-H1200 WEATHERSTRIP ASS'Y-door inside (R.H.) 2-dr Sedan, Coupe, Coupe (L.H.)
- 80837-H1200 WEATHERSTRIP ASS'Y-door inside (L.H.) 2-dr Sedan
Window Winders
Black: 1970-1977
Brown shade 1: 1978
Brown shade 2: 1979-1989
Gray: Oct 1989-
- 80675-H1000 WASHER-SEATING
- 08330-51220 SCREW
- 80760-H1000 HANDLE ASSY-DOOR WINDOW REGULATOR BLACK
- 80760-G1060 HANDLE ASSY-DOOR WINDOW REGULATOR BROWN 7804-7907
- 80760-G1660 HANDLE ASSY-DOOR WINDOW REGULATOR BROWN 7908-8910
- 80760-95W00 HANDLE ASSY-DOOR WINDOW REGULATOR [GRAY] 8910-
ドア ウインドー レギュレーター ハンドル
Window Regulator
Top: 2-dr Coupe
Bottom: 2-dr Sedan
- 80700-H1202 or 80700-H1201 REGULATOR ASS'Y-door window (2) Sedan-2D
- replaced 80700-H1200 only works up to '70 Oct.
- 80700-H1800 REGULATOR ASS'Y-door window (R.H.) Coupe
- 80701-H1800 REGULATOR ASS'Y-door window (L.H.) Coupe
4-dr Sedan & Wagon
- 80700-H1002 or 80700-H1001 or 80700-H1000 REGULATOR ASS'Y-door window (2)
- 82700-H1001 or 82700-H1000 REGULATOR ASSY-rear door window, RH
- 82701-H1001 or 82701-H1000 REGULATOR ASSY-rear door window, LH
- 80700-H1002 REGULATOR ASSY-DOOR WINDOW, RH
- 80701-H1002 REGULATOR ASSY-DOOR WINDOW, LH
2-dr door regulators have longer pivot arms (pivot point to roller) while the shorter 4-door front door regulators are likewise shorter.
Rear Glass
Rubber Sources
See Rubber Parts
Glass Sources
- eBay
- Wrecking Yards
- Datsun1200.com Classifieds forum
- USA:
- Pilkington Classics 1-800-848-1351
- PPG Vintage 1-877-855-8100
