Vehicles
JAPAN MARKET E-Series vehicles B11: 8110-8701 Sunny E15 M10: 8208-8701 Prairie E15S N12: 8205-8701 Pulsar E15S+E15E N12: 8305-8701 Pulsar E15T VB11: 8210-8701 AD Van E15S
USA MARKET B11: 0282-0882 Sentra E15S B11: 0882-0187 Sentra E15S+E16S N10: 1081- 310 E15S N12: 0882- Pulsar E16S N12: 0283-0784 Pulsar E15ET
ER MARKET (worldwide, non-Japan, RHD market) B11 EUR 0382- E15S B11 EUR 0385-0187 E16S M10 EUR 0982-0187 E15S N10 EUR 1081- E15S N12 EUR 0482- E15S N12 EUR 0682- E15ET N12 EUR 0685- E16S
Swaps for A-engine
See E15 Electronic Distributor Swap
Types
D4P
D4P no visible ignition parts, no vacuum advance E15ET E16I
See main article: Hitachi D4P Distributor.
ROUND
ROUND TYPE IGNITION (on some E15E)![]()
Fitted to Mitsubishi T4T distributors
* Nissan 22020-15M10 ** Standard Motor Product SMP LX117 ** Chrysler Mitsubishi 1981-1987 ** GM ** Mazda 1986-1993 2.0/2.2 626, MX-6, B2000, B2200 ** Ford Probe 1989-1990 2.2 [Mazda-engined]
Pickup Set* Standard Motor Products LX610 * Mazda F20118V15 Mazda 626 1988, 1989, 1990, 1991, 1992 Mazda B2000 1986, 1987 Mazda B2200 1987, 1988, 1989, 1990, 1991, 1992, 1993 Mazda B2600 1987, 1988, 1989, 1990, 1991, 1992, 1993 Mazda MX-6 1988, 1989, 1990, 1991, 1992
Vehicles 22100-15M11 B11 JDM 8110-8502 E15E.MT MITSUBISHI 22100-15M13 B11 JDM 8502- E15E.MT MITSUBISHI 22100-16M10 B11 JDM 8110- E15E.AT MITSUBISHI 22100-15M11 N12 JDM 8205-8609 E15E.MT MITSUBISHI T4T83671 22100-16M10 N12 JDM 8205-8609 E15E.AT MITSUBISHI T4T83574
EI
Also used by 22100-95W10 Sunny Truck Distributor
EI TYPE IGNITIONIgnitor/HEI Transistor * Nissan 22020-G5111 from Vanette Distributor ** FORD E8BZ212A297A/E92Z12A297A/F0212A297A ** MAZDA F82918V20 *** Mazda 626 & MX-6 1988,1989 ** MITSUBISHI J007X00671/J007X00871 ** MOTORCRAFT DYE524/DYE539
Pickup Set -- same as Round TypeSee Round section above.
EI 2
One-piece Ignitor & Pickup
Hitachi D4R type dizzy e.g. from N12 Pulsar
- Nissan 22020-15M00, 22020-15M20
MATCHBOX
MATCHBOX TYPE IGNITION - bolts to outside of distributor body![]()
See main article: Hitachi D4K Distributor
E-series Vehicles:
B11 JDM 8110-[8608] E15S.(GL,LT).F5 N12 JDM 8205-[8610] E15S.5F.(TS,D,FC)
Unknown Type
Mitsubishi with top-mounted centrifugal advance:
Distributor Numbers
22100-17M01 B11 JDM 8209-8310 E15ET HITACHI 22100-17M02 B11 JDM 8310- E15ET HITACHI 22100-15M11 B11 JDM 8110-8502 E15E.MT MITSUBISHI ROUND 22100-15M13 B11 JDM 8502- E15E.MT MITSUBISHI ROUND 22100-16M10 B11 JDM 8110- E15E.AT MITSUBISHI ROUND 22100-11M00 B11 JDM 8110-8502 E15S.MT-(GL,LT).F5 HITACHI EI 22100-11M02 B11 JDM 8502-8612 E15S.MT-(GL,LT).F5 HITACHI EI 22100-11M03 B11 JDM 8612- E15S.MT-(GL,LT).F5 HITACHI EI 22100-11M00 B11 JDM 8110-8502 E15S.A5 HITACHI EI 22100-11M02 B11 JDM 8502-8612 E15S.A5 HITACHI EI 22100-11M03 B11 JDM 8612- E15S.A5 HITACHI EI 22100-13M00 B11 JDM 8110-[8608] E15S.(GL,LT).F5 HITACHI MATCHBOX 22100-01M01 B11 JDM 8110-8111 E13S HITACHI POINTS 22100-01M11 B11 JDM 8110-8310 E13S MITSUBISHI POINTS 22100-01M12 B11 JDM 8310-8506 E13S MITSUBISHI POINTS 22100-01M14 B11 JDM 8506- E13S MITSUBISHI POINTS 22100-11M00 M10 JDM 8208-8501 S.E15S HITACHI EI 22100-11M02 M10 JDM 8501-8612 S.E15S HITACHI EI 22100-11M03 M10 JDM 8612-8712 S.E15S HITACHI EI 22100-11M05 M10 JDM 8712-8812 S.E15S HITACHI EI 22100-11M06 M10 JDM 8812- S.E15S HITACHI EI 22100-19M01 M10 JDM 8208-8606 V.E15S HITACHI POINTS 22100-19M03 M10 JDM 8606- V.E15S HITACHI POINTS 22100-17M01 N12 JDM 8305-8403 E15T HITACHI D4P82-02 アル コネクタ 22100-17M02 N12 JDM 8403-8507 E15T HITACHI D4P83-02 カク コネクタ 22100-17M04 N12 JDM 8507-8508 E15T HITACHI D4P83-02(A) カク コネクタ 22100-17M06 N12 JDM 8508- E15T HITACHI D4P83-02(B) カク コネクタ [bolt-on connector] 22100-17M14 N12 JDM 8507-8508 E15T MITSUBISHI 22100-17M16 N12 JDM 8508-8609 E15T MITSUBISHI T4T84473 カク コネクタ 22100-17M17 N12 JDM 8609- E15T MITSUBISHI 22100-15M11 N12 JDM 8205-8609 E15E.MT MITSUBISHI T4T83671 ROUND 22020-15M10 22100-15M13 N12 JDM 8609- E15E.MT MITSUBISHI T4T83671B 22100-16M10 N12 JDM 8205-8609 E15E.AT MITSUBISHI T4T83574 ROUND 22100-16M12 N12 JDM 8609- E15E.AT MITSUBISHI T4T83574B 22020-G5110 22100-11M00 N12 JDM 8205-8502 E15S.MT-5F.(TS,D,FC) HITACHI D4R80-08 EI 22100-11M02 N12 JDM 8502-8612 E15S.MT-5F.(TS,D,FC) HITACHI D4R80-08 EI 22100-11M03 N12 JDM 8612- E15S.MT-5F.(TS,D,FC) HITACHI D4R80-08 EI 22100-12M00 N12 JDM 8205-8502 E15S.AT HITACHI D4R80-11 EI 22100-12M02 N12 JDM 8502-8612 E15S.AT HITACHI D4R80-11 EI 22100-12M03 N12 JDM 8612- E15S.AT HITACHI D4R80-11 EI 22100-13M00 N12 JDM 8205-[8610] E15S.5F.(TS,D,FC) HITACHI D4K80-09 MATCHBOX 22100-01M15 N12 JDM E13S MITSUBISHI POINTS 22100-19M01 VB11 JDM 8210-8604 E15S.MT HITACHI POINTS 22100-19M03 VB11 JDM 8604-8805 E15S.MT HITACHI POINTS 22100-19M05 VB11 JDM 8210-8604 E15S.AT HITACHI POINTS 22100-19M06 VB11 JDM 8604-8805 E15S.AT HITACHI D4A86-04 POINTS 22100-52A02 VB11 JDM 8805-8812 E15S.MT HITACHI D4R85-06 EI 22100-52A03 VB11 JDM 8812- E15S.MT HITACHI EI 22100-52A07 VB11 JDM 8805-8812 E15S.AT HITACHI D4R85-07 EI 22100-52A08 VB11 JDM 8812- E15S.AT HITACHI EI 22100-09M12 VB11 JDM 8210-8506 E13S MITSUBISHI T3T20976 POINTS CLIP-ON 22100-09M14 VB11 JDM 8506-8604 E13S MITSUBISHI T3T21476 POINTS 22100-09M15 VB11 JDM 8604-8805 E13S MITSUBISHI T3T21476 POINTS SCREW-ON 22100-75A10 VB11 JDM 8805- E13S.MT MITSUBISHI T4T8409 22020-G5111 22100-75A15 VB11 JDM 8805- E13S.AT MITSUBISHI T4T8409 22020-G5111
22100-21M00 N10 USA 0881- CAL.2HB.E15S.MT.F4 +(CAL.2HB+CAL.4HB+CAL.C).E15S.MT.F5 HITACHI D4R80-14 22100-22M00 N10 USA 1181- (CAL.2HB+CAL.4HB+CAL.C).E15S.AT HITACHI [D4R] 22100-22M00 N10 USA 0881- FED.2HB.E15S.MT.F4 +(FED.2HB+FED.4HB+FED.C).E15S.MT.F5 HITACHI D4R80-13 22100-24M00 N10 USA 1181- (FED.2HB+FED.FED+FED.C).E15S.AT HITACHI [D4R] 22100-21M00 B11 USA 0282-0881 (CAL.2S+CAL.4S+CAL.C+CAL.W).E15S.MT.F5 EI 22100-22M00 B11 USA 0282-0882 (CAL.2S+CAL.4S+CAL.C+CAL.W).E15S.AT EI 22100-23M05 B11 USA 0282-0882 FED.NMPG.E15S.MT EI 22100-23M06 B11 USA 0282-0882 MPG.E15S EI 22100-24M00 B11 USA 0282-0882 (FED.2S+FED.4S+FED.C+FED.W).E15S.AT EI 22100-23M07 B11 USA 0982-0983 E15S EI 22100-32M01 B11 USA 0882-0285 (CAL.2S+CAL.4S+CAL.C+CAL.W).E16S.AT EI 22100-32M02 B11 USA 0285-0588 (CAL.2S+CAL.4S+CAL.C+CAL.W).E16S.AT EI 22100-33M01 B11 USA 0983-0285 (CAL.2S+CAL.4S+CAL.C+CAL.W).E16S.MT.F5 EI 22100-33M01 B11 USA 0882-0983 E16S.(MT.F4+M5.F5) EI 22100-33M02 B11 USA 0882-1286 (CAL.2S+CAL.4S+CAL.C+CAL.W).E16S.MT.F5 EI 22100-33M03 B11 USA 1286-0588 (CAL.2S+CAL.4S+CAL.C+CAL.W).E16S.MT.F5 EI 22100-34M00 B11 USA 0882-0983 (FED.2S+FED.4S+FED.C+FED.W).E16S.AT EI 22100-36A00 B11 USA 0983-0885 E16S.MT.F4 +(FED.2S+FED.4S+FED.C+FED.W).E16S.(MT.F5+AT) D4P 22100-36A01 B11 USA 0885-0186 E16S.MT.F4 +(FED.2S+FED.4S+FED.C+FED.W).E16S.(MT.F5+AT) D4P 22100-36A02 B11 USA 0186-0588 E16S.MT.F4 +(FED.2S+FED.4S+FED.C+FED.W).E16S.(MT.F5+AT) D4P 22100-32M01 N12 USA 0882-0285 (CAL.C+CAL.3HB+CAL.5HB).E16S.AT HITACHI D4R82-24 22100-32M02 N12 USA 0285-0986 (CAL.C+CAL.3HB+CAL.5HB).E16S.AT HITACHI D4R82-24 22100-32M03 N12 USA 0986- (CAL.C+CAL.3HB+CAL.5HB).E16S.AT HITACHI D4R82-24 W/VENT 22100-33M01 N12 USA 0882-0983 (FED.C+FED.3HB+FED.5HB).E16S.MT.F5 HITACHI D4R82-12 22100-33M01 N12 USA 0882-0285 (CAL.C+CAL.3HB+CAL.5HB).E16S.MT.F5 HITACHI D4R82-12 22100-33M02 N12 USA 0882-0983 (FED.C+FED.3HB+FED.5HB).E16S.MT.F5 HITACHI D4R82-12 22100-33M02 N12 USA 0285-0986 (CAL.C+CAL.3HB+CAL.5HB).E16S.MT.F5 HITACHI D4R82-12 22100-33M03 N12 USA 0882-0983 (FED.C+FED.3HB+FED.5HB).E16S.MT.F5 HITACHI D4R82-12 W/VENT 22100-33M03 N12 USA 0986- (CAL.C+CAL.3HB+CAL.5HB).E16S.MT.F5 HITACHI D4R82-12 W/VENT 22100-34M00 N12 USA 0882-0983 (FED.C+FED.3HB+FED.5HB).E16S.AT HITACHI D4R82-13 22100-34M01 N12 USA 0882-0983 (FED.C+FED.3HB+FED.5HB).E16S.AT HITACHI D4R82-13 22100-34M02 N12 USA 0882-0983 (FED.C+FED.3HB+FED.5HB).E16S.AT HITACHI D4R82-13 W/VENT 22100-36A00 N12 USA 0983-0885 (FED.C+FED.3HB+FED.5HB).E16S HITACHI D4P83-03 22100-36A01 N12 USA 0885-0486 (FED.C+FED.3HB+FED.5HB).E16S HITACHI D4P83-03D 22100-36A02 N12 USA 0486- (FED.C+FED.3HB+FED.5HB).E16S HITACHI D4P83-03E W/VENT 22100-27M00 N12 USA 0283-0983 E15ET HITACHI D4P82-06 22100-27M01 N12 USA 0983-0784 E15ET HITACHI D4P82-03 22100-27M02 N12 USA 0283-0983 E15ET HITACHI D4P82-06B 22100-27M03 N12 USA 0983-0784 E15ET HITACHI D4P82-03B 22100-27M04 N12 USA 0283-0983 E15ET HITACHI D4P82-06B W/VENT 22100-27M05 N12 USA 0983-0784 E15ET HITACHI D4P82-03B W/VENT
22100-03A00 B11 EUR 0284-0486 (S+W).E15S.MT 22100-03A00 B11 EUR 0284-0486 (S+C).E13S.MT 22100-03101 B11 EUR 0284-1286 (S+C).E13S.MT 22100-03101 B11 EUR 0284-1286 (S+C).E15S.MT 22100-03A02 B11 EUR 0284-1286 (S+W).E16S.MT 22100-03A02 B11 EUR 1286-0588 (S+C+W).(E13S+E15S).MT HITACHI 22100-03A02 B11 EUR 0284-0486 (S+C).E13S.MT 22100-03A02 B11 EUR 0284-0486 (S+W).E15S.MT 22100-03A03 B11 EUR 1286-0588 (S+C+W).(E13S+E15S).MT HITACHI 22100-03A03 B11 EUR 0284-0486 (S+C).E13S.MT 22100-03A03 B11 EUR 0284-0486 (S+W).E15S.MT 22100-03A04 B11 EUR 1286-0588 (S+C+W).(E13S+E15S).MT HITACHI 22100-03A04 B11 EUR 0284-0486 (S+C).E13S.MT 22100-03A04 B11 EUR 0284-0486 (S+W).E15S.MT 22100-03A04 B11 EUR 0588- E13S HITACHI EI 22100-05M02 B11 EUR 0382-0284 E15S.(MT.F4+MT.F5)+E13S 22100-05M02 B11 EUR 0284-1286 V.(E13S+E15S) 22100-05M04 B11 EUR 0382-0284 E15S.(MT.F4+MT.F5)+E13S POINTS CLIP-ON 22100-05M04 B11 EUR 0284-0588 V.(E13S+E15S) POINTS CLIP-ON 22100-05M05 B11 EUR 0382-0284 E15S.AT 22100-05M06 B11 EUR 0382-028R OPTION.E15S.AT 22100-08A00 B11 EUR 0284-0486 (S+W).E15S.AT 22100-08A01 B11 EUR 0486-1286 (S+W).E15S.AT 22100-08A02 B11 EUR 1286-0588 (S+W).E15S.AT 22100-25M00 B11 EUR 0382-0284 OPTION.E15S.(MT.F4+MT.F5) 22100-25M02 B11 EUR 0382-0284 OPTION.E15S.(MT.F4+MT.F5) 22100-36A00 B11 EUR 0385-0885 E16S HITACH D4P83-03 22100-36A01 B11 EUR 0885-1285 E16S HITACH D4P83-03D 22100-36A02 B11 EUR 1285-0588 E16S HITACH D4P83-03E 22100-P4000 B11 EUR 0284-0486 OPTION(E13S+E15S).MT 22100-P4001 B11 EUR 0486-1286 OPTION(E13S+E15S).MT 22100-P4002 B11 EUR 1286-0588 OPTION(E13S+E15S).MT HITACHI 22100-P4005 B11 EUR 1084-0486 OPTION(E15S.AT) 22100-P4006 B11 EUR 0486-1286 OPTION(E15S.AT) 22100-P4007 B11 EUR 1286-0588 OPTION(E15S.AT) HITACHI 22100-P4008 B11 EUR 1286-0588 OPTION(E15S.AT) HITACHI 22100-P4009 B11 EUR 1286-0588 OPTION(E15S.AT) HITACHI 22100-03A00 M10 EUR 0285-0486 E15S HITACHI D4R83-30 EI 22100-03A01 M10 EUR 0486-1286 E15S HITACHI D4R83-30 EI 22100-03A02 M10 EUR 1286-1187 E15S HITACHI D4R83-30 EI 22100-03A03 M10 EUR 1187- E15S HITACHI D4R83-30 EI 22100-03A04 M10 EUR 1187- E15S HITACHI D4R83-30 EI 22100-12R01 M10 EUR 0982-0285 OPTION.E15S POINTS CLIP-ON 22100-13R00 M10 EUR 0982-0285 E15S POINTS CLIP-ON 22100-13R01 M10 EUR 0982-0285 E15S F/SERVICE POINTS CLIP-ON 22100-13R05 M10 EUR 0982-0285 OPTION.E15S POINTS CLIP-ON 22100-13R06 M10 EUR 0982-0285 OPTION.E15S F/SERVICE POINTS CLIP-ON 22100-P4000 M10 EUR 0285-0486 OPTION.E15S HITACHI D4R83-39 EI 22100-P4001 M10 EUR 0486-1286 OPTION.E15S HITACHI D4R83-39 EI 22100-P4002 M10 EUR 1286-1187 OPTION.E15S HITACHI D4R83-39 EI 22100-P4003 M10 EUR 1187- OPTION.E15S HITACHI D4R83-39 EI 22100-41M01 N10 EUR 0881- E10S HITACHI D410-92 POINTS CLIP-ON 22100-25M00 N10 EUR 0881- E15S.(MT.F4+M5.F5) HITACHI D414-A4 POINTS CLIP-ON 22100-06M00 N10 EUR 0881- E15S.AT HITACHI D414-A5 POINTS CLIP-ON 22100-05M05 N10 EUR 0881- E13S.AT HITACHI D412-B1 POINTS CLIP-ON 22100-05M02 N10 EUR 0881- E13S.(MT.F4+M5.F5) HITACHI D412-A9 POINTS CLIP-ON 22100-08M00 N12 EUR 0684-0486 E10S HITACHI D4R83-38 EI 22100-08M01 N12 EUR 0486-0686 E10S HITACHI D4R83-38 22100-08M02 N12 EUR 0686- E10S HITACHI D4R83-38 W/VENT 22100-41M02 N12 EUR 0482-0584 E10S HITACHI D410-A4 POINTS CLIP-ON 22100-41M04 N12 EUR 0482-0584 E10S HITACHI D4A86-10 W/VENT 22100-03A00 N12 EUR 0684-0486 E13S.(MT.F4+MT.F5) +E15S.MT.F4 +3HB.E15S.MT.F5 HITACHI D4R83-30 22100-03A01 N12 EUR 0486-0686 E13S.(MT.F4+MT.F5) +E15S.MT.F4 +3HB.E15S.MT.F5 HITACHI D4R83-30 22100-03A02 N12 EUR 0686- E13S.(MT.F4+MT.F5) +E15S.MT.F4 +3HB.E15S.MT.F5 HITACHI D4R83-30 W/VENT 22100-03A05 N12 EUR 0684-0486 E13S.AT HITACHI D4R83-36 22100-03A06 N12 EUR 0486-0686 E13S.AT HITACHI D4R83-36 22100-03A07 N12 EUR 0686- E13S.AT HITACHI D4R83-36 W/VENT 22100-05M02 N12 EUR 0482-0584 E13S.(MT.F4+MT.F5) +E15S.(MT.F4+MT.F5) HITACHI A412-A9 22100-05M02 N12 EUR 0482-0584 OPTION.E13S.MT +E15S.(MT.F4+MT.F5) HITACHI A412-A9 22100-05M04 N12 EUR 0482-0584 E13S.(MT.F4+MT.F5) +E15S.MT.F4 +3HB.E15S.MT.F5 HITACHI D412-A9 W/VENT F/SERVICE 22100-13R00 N12 EUR 0283-0584 E13S.AT HITACHI D412-B5 22100-13R01 N12 EUR 0482-0584 E13S.AT HITACHI D4A86012 W/VENT F/SERVICE 22100-05M05 N12 EUR 0482-0584 E15S.AT HITACHI D412-B1 POINTS CLIP-ON 22100-05M07 N12 EUR 0482-0584 E15S.AT HITACHI D414-A9 POINTS CLIP-ON 22100-06M06 N12 EUR 0482-0584 OPTION.E15S.AT HITACHI D4149-A9 POINTS CLIP-ON 22100-06M08 N12 EUR 0482-0584 OPTION.E15S.AT HITACHI D4R86-18 W/VENT F/SERVICE 22100-08A00 N12 EUR 0684-0486 E15S.AT HITACHI D4R83-31 EI 22100-08A01 N12 EUR 0486-0686 E15S.AT HITACHI D4R83-31 EI 22100-08A02 N12 EUR 0686- E15S.AT HITACHI D4R83-31 W/VENT EI 22100-25M00 N12 EUR 0482-0584 OPTION.E15S.MT HITACHI D414-A4 POINTS CLIP-ON 22100-25M02 N12 EUR 0482-0584 OPTION.E15S.MT HITACHI D4A86-13 W/VENT F/SERVICE 22100-P4000 N12 EUR 0684-0486 OPTION.E15S.MT HITACHI D4R83-39 EI 22100-P4001 N12 EUR 0486-0686 OPTION.E15S.MT HITACHI D4R83-39 EI 22100-P4002 N12 EUR 0686- OPTION.E15S.MT HITACHI D4R83-39 W/VENT EI 22100-P4005 N12 EUR 0684-0486 OPTION.E15S.AT HITACHI D4R83-40 EI 22100-P4006 N12 EUR 0486-0686 OPTION.E15S.AT HITACHI D4R83-40 EI 22100-P4007 N12 EUR 0686- OPTION.E15S.AT HITACHI D4R83-40 W/VENT EI 22100-27M00 N12 EUR 0682-0584 E15ET HITACHI D4P82-06 22100-27M02 N12 EUR 0682-0584 E15ET HITACHI D4P82-06B 22100-27M04 N12 EUR 0682-0584 E15ET HITACHI D4P82-06C W/VENT 22100-35M00 N12 EUR 0584-0885 E15ET HITACHI D4P82-06 22100-35M01 N12 EUR 0885- E15ET HITACHI D4P82-06D 22100-35M02 N12 EUR 0885- E15ET HITACHI D4P82-06E W/VENT 22100-36A00 N12 EUR 0686-0885 E16S HITACHI D4P83-03 22100-36A01 N12 EUR 0885-0486 E16S HITACHI D4P83-03D 22100-36A02 N12 EUR 0486- E16S HITACHI D4P83-03E W/VENT
