Starting with the A14 engines, the Hitachi D4A points-type distributor replaced the older D4n type (D40/D41). The D4A features a larger cap for improved spark isolation and resistance to crossfiring. The same body casting was later used for the D4F and D4K Electronic Ignition versions.
Models
NORTH AMERICA B210
1974 A13 0673-0874 22100-H6201 ASSY-DISTRIBUTOR 4CYL. HITACHI D42 22108-H6200 SET-SHAFT 22160-M0800 SET-WASHER THRUST 22109-U6001 GOVERNOR-WEIGHT (2) 22110-H6200 SET-SPRING GOVERNOR 22132-H6200 SET-CAM 22136-U6001 ASSY-BRAKER PLATE 22145-89900 SET-CONTACT * superceded 1275 22145-U6001 22102-U6002 CONDENSER 22182-U6001 ASSY-WIRE,EARTH 22403-U6001 ASSY-TERMINAL 22301-H6200 ASSY-VACUUM CONTROL 22119-H5000 SET-PINION 22157-U6001 ROTER-HEAD 22162-U6001 ASSY-CAP 22165-30101 ASSY-CARBON,POINT 22750-U6001 KIT-SCREW 22130-A5500 PACKING 08360-61226 BOLT-HEX.WITH WASHER M6 22180-71200 O RING-DIST,SUPPORT
