Also see:
Part Numbers Index Main article for usage, photos, cross-reference Trunk (boot) Rear Bumper Weatherstripping Jack
Sedan
1 84300-H1800 ASSY-TRUNK LID COUPE 2 84420-H1800 ASSY-STRIKER TRUNK LID LOCK COUPE 3 08310-61614 SCREW-MACHINE WITH WASHER M6X1.0 (2) COUPE 4 08915-43610 WASHER-PLAIN M6 (2) COUPE 5 84430-H1800 ASSY-LOCK TRUNK LID COUPE 5 84460-H1800 ASSY-CYLINDER LOCK TRUNK LID COUPE 5 84460-H1801 ASSY-CYLINDER LOCK TRUNK LID COUPE 2 84460-H1800 6 08310-61612 SCREW-MACHINE M6 (2) COUPE 7 08915-13610 WASHER-LOCK M6 (2) COUPE 8 08915-43610 WASHER-PLAIN M6 (2) COUPE 9 84520-H1800 ASSY-HINGE TRUNK LID RH COUPE 10 84521-H1800 ASSY-HINGE TRUNK LID LH COUPE 11 84532-H1800 BAR-TORSION TRUNK LID RH COUPE 12 84533-H1800 BAR-TORSION TRUNK LID LH COUPE 13 84542-H1800 ROLLER-TRUNK LID SPRING (2) COUPE 14 08310-51018 SCREW M5 W/WASHER FIX HINGE TO BODY 1 (10) COUPE 15 77720-89921 SCREW-MACHINE M6 W/WASHER FIX HINGE TO (4) COUPE 16 84810-H1800 WEAHERSTRIP-TRUNK LID COUPE 17 85011-H1905 BUMPER-REAR CENTER COUPE 17 85011-H7100 BUMPER-REAR CENTER COUPE 0772- 0 85011-H1905 18 85012-H1000 BUMPER-REAR RH COUPE 19 85013-H1000 BUMPER-REAR LH COUPE 20 62663-18000 BOLT-SPECIAL M6 FIX BUMP CENTER TO SI (4) COUPE 21 08915-13610 WASHER-LOCK FIX BUMP CENTER TO SIDE (4) COUPE 22 08911-10610 NUT-HEX M6 FIX BUMP CENTER TO SIDE (4) COUPE 23 85204-H7100 ASSY-STAY BUMPER REAR (2) COUPE 0772- 0 85204-H1000 23 85204-H1000 STAY-BUMPER REAR (2) COUPE 24 62663-18000 BOLT-SPECIAL M6 FIX STAY TO BUMPER (4) COUPE 24 08144-01610 BOLT (4) COUPE 0772- 25 08915-43610 WASHER-PLAIN M6 FIX STAY TO BUMPER (4) COUPE 25 08915-44010 WASHER-PLAIN (4) COUPE 0772- 26 08915-13610 WASHER-LOCK (4) COUPE 26 08915-14010 WASHER-LOCK (4) COUPE 0772- 27 08911-10610 NUT-HEX M6 (4) COUPE 28 85206-H1801 BRACKET-BUMPER REAR SIDE RH COUPE 28 85206-H7100 BRACKET-BUMPER REAR SIDE RH COUPE 0772- 0 85206-H1801 29 85207-H1801 BRACKET-BUMPER REAR SIDE LH COUPE 29 85207-H1000 BRACKET-BUMPER REAR SIDE LH COUPE 2 85207-H1801 29 85207-H7100 BRACKET-BUMPER REAR SIDE LH COUPE 0772- 0 85207-H1000 30 62663-18000 BOLT-SPECIAL M6 FIX BRACKET TO BUMPER (2) COUPE 31 08915-43610 WASHER-PLAIN M6 (2) COUPE 32 08915-13610 WASHER-LOCK M6 FIX BRACKET TO BUMPER (2) COUPE 33 08911-10610 NUT-HEX M6 (2) COUPE 34 08110-82010 BOLT-HEX M8X1.25 FIX STAY TOBODY (2) COUPE 35 08915-53810 WASHER-PLAIN M8 FIX STAY TO BODY (2) COUPE 36 08915-13810 WASHER-LOCK M8 (2) COUPE 37 62678-21000 SHIM-BRACKET BUMPER SIDE (2) COUPE 38 08110-61810 BOLT-HEX M6 FIX BRACKET TO BODY (2) COUPE 39 08915-53610 WASHER-PLAIN M6 FIX BRACKET TO BODY (2) COUPE 40 08915-13610 WASHER-LOCK M6 FIX BRACKET TO BODY (2) COUPE 41 85020-H1900 OVERRIDER-REAR BUMPER RH COUPE 41 85020-H7000 OVERRIDER-REAR BUMPER RH COUPE 0772- 0 85020-H1900 42 85021-H1900 OVERRIDER-REAR BUMPER LH COUPE 42 85021-H7000 OVERRIDER-REAR BUMPER LH COUPE 0772- 0 85021-H1900 43 85024-H1900 RUBBER-OVERRIDER (4) COUPE -672 2
Coupe
1 84902-H2500 TRIM-TRUNK FLOOR CENTER COUPE 0271- 0 84902-H1800 1 84902-H7100 TRIM-TRUNK FLOOR CENTER (BLUE,LB-211 COUPE 0772- 2 85207-H1801 1 84902-H7101 TRIM-TRUNK FLOOR CENTER (BEIGE,LH-20 COUPE 0772- 1 84902-H7102 TRIM-TRUNK FLOOR CENTER (BLACK,LG-13 COUPE 0772- 1 84902-H1800 TRIM-TRUNK FLOOR CENTER COUPE 2 76983-68400 LOCK-MALE COUPE 3 84903-H7100 TRIM-TRUNK FLOOR RH (BLUE,LB-211 COUPE 0772- 3 84903-H7101 TRIM-TRUNK FLOOR RH (BEIGE,LH-20 COUPE 0772- 3 84903-H2501 TRIM-TRUNK FLOOR RH COUPE EVAPO 0271- 0 84903-H1900 3 84903-H1900 TRIM-TRUNK FLOOR RH COUPE EVAPO 0470- 3 84903-H1800 TRIM-TRUNK FLOOR RH COUPE 3 84903-H7102 TRIM-TRUNK FLOOR RH (BLACK,LG-13 COUPE 0772- 4 84904-H1800 TRIM-TRUNK FLOOR LH COUPE 4 84904-H2500 TRIM-TRUNK FLOOR LH COUPE 0271- 0 84904-H1800 4 84904-H7100 TRIM-TRUNK FLOOR LH (BLUE,LB-211 COUPE 0772- 0 84904-H2500 4 84904-H7101 TRIM-TRUNK FLOOR LH (BEIGE,LH-20 COUPE 0772- 4 84904-H7102 TRIM-TRUNK FLOOR LH (BLACK,LG-13 COUPE 0772- 5 08510-51612 SCREW-TAPPING M5 FIX TRIM 1 (16) COUPE 6 08963-20540 NUT-SPRING TYPE A M5 FIX TRIM 1 (16) COUPE 7 08915-43510 WASHER-PLAIN M5 FIX TRIM 1 (16) COUPE 8 76982-68400 ASSY-LOCK FEMALE COUPE 9 08410-41210 SCREW-TAPPING COUPE 10 08915-43410 WASHER-PLAIN COUPE 11 08915-13410 WASHER-LOCK COUPE 12 84905-H1800 STOPPER-TRIM TRUNK FLOOR COUPE 13 84911-H1800 FINISH-TRUNK LID T=1.5 COUPE 13 84921-H1900 FINISH-TRUNK SIDE RH T=2 COUPE EVAPO 14 84922-H1800 FINISH-TRUNK SIDE T=1.5 COUPE EVAPO 14 84921-H1800 FINISH-TRUNK SIDE RH T=1.5 COUPE 14 84921-H2500 FINISH-TRUNK SIDE RH T=1,5 COUPE 0271- 0 84921-H1800 15 84922-H1800 FINISH-TRUNK SIDE LH T=1.5 COUPE 15 84922-H2500 FINISH-TRUNK SIDE LH T=1.5 COUPE 0271- 0 84922-H1800 16 84931-H1800 FINISH-TRUNK REAR T=2 COUPE 16 84931-H1801 FINISH-TRUNK REAR T=2 COUPE EVAPO 0470- 16 84931-H2501 FINISH-TRUNK REAR T=2 COUPE EVAPO 0271- 0 84931-H1801 17 66919-H1001 CLIP-TRIM 1 (14) COUPE 18 66919-H1099 CLIP-TRIM 1 (15) COUPE 19 84932-H1800 MASK-REAR LAMP T=2 (2) COUPE 19 84932-H2500 MASK-REAR LAMP T=2 (2) COUPE 0271- 0 84932-H1800 20 84941-H1800 COVER-TRUNK LID HINGE COUPE 21 84939-H1800 WELT-TRUNK FINISH COUPE
