The Pertronix Electronic Ignition Retrofit Kit model 1741 fits a stock Datsun 1200 distributor. Moderate cost. It is is points replacment unit, but not a high-energy system.
Contents[hide] |
- Easy 2-wire hookup, replace points & condensor
- RPM range: 0 - 15000 RPM (with high performance coil)
- Sold both in USA and Australia
- Fits in stock distributor
Retail prices
- $112.52 USD
- About $63-78 USD online
- About 65 + s/h on eBAy
- Also sold in Australia
More information:
Reviews
- Red wire: 12V +
- Black wire: Coil -
Distributor Timing
If you removed the distributor to install the Pertronix kit, see How to Install a Distributor on A-series Engine: Installing Distributor
Finally, when you are ready to start the engine you will want to immediate check the timing. See Ignition Timing for the procedure.
