Brake lamp located in the dash cluster gauge lights up if there is a problem.
Brake Stop Lights
Hand Brake Switch
Lamp switch for Hand Brake handle was fitted to USA 1200s, and is fitted to newer utes.
Pressure Loss Switch
A brake check switch is used on some 1200s to signal if there is a problem with the brake pressure.
Click the photo to read the details on this switch.
Schematic
The dash lamps are always connect to 12V when IGN switch is on. They only light up when a switch grounds the bulb. A switch is fitted to the hand brake lever. When you pull the lever, it grounds the circuit.
- G: Green wire from IGN fuse to dash cluster lamps
- B: Black wire to main body earth bolt in engine compartment
- Y/G: Yellow wire w/Green stripe, from switch to bulb, grounds the bulb
