Take the face plate and scan it on the flatbad scanner, then modify it. Finally, print a new one out with the photo printer. You can modify the font, colors, etc. Bolt it to the speedo using the standard screws. Best to secure the perimeter with some kind of contact cement (what to use?) so that in heat or cold the lable doesn't warp and stop the indicator needle.
Also see:
Raw Scans
Scans of original 1971-1973 B110 components:
- Speedometer, Miles Per Hour (129 kb high-resolution)
- 1152 x 1152 pixels
- Discussion
- Clock, RHD (130 kb high-resolution)]
- Discussion
Custom Files
Here is a multi-layer PNG file, which you can print out in a photo printer.
You could also modify it first (it is calibrated for 4.11 diff). Perhaps reverse the colors to black numerals on white face?
ask
