The Idler Arm is part of the Steering Linkage, and is the counterpoint to the Steering Gear Arm.
The Idler Arm bolts to the subframe rail on opposite side from the steering gearbox.
Steering_Linkage: #1 Idler Arm
It fastens to the chassis via two long bolts.
linkage. The bolts go through the Front Side Member (front chassis rail).
RHD
RHD Idler Arm is the same for all 1200s: ute/wagon/sedan/coupe -- even the 1994 Sunny Truck uses the same part number.
LHD
Idler Arm LHD * 48530-H1600 ASSY-IDLER STEERING [LHD] * RockAuto.com * TRW 18778 through 7/72
Bushing
The same bushing set is used by RHD and LHD.
Idler Arm Bushing * 48544-H1000 BUSH-IDLER * Beck/Arnley 1013851 (2 per idler arm) at http://rockauto.comFits: ** Mitsubishi/Chrysler 1983-1993 various models ** Nissan B110, B310, S110, 1979-1981 S130, A10, 1980-1982 720, 1977-1980 810
Idler Arm Repair Kit (includes 2 bushes, washer & lock nut) * Raybestos 4501067 * ACDelco 45C1067 or 88911321 $8.41 Rockauto.com
Comparison
48530-21000 RHD PB110(L14) PB210(L14),GB210(L16) 510/610 Bluebird 710 Violet S10 Silvia![]()
ステアリング アイドラ アーム
