ARP
Revision as of 06:13, 10 January 2012; view current revision
Category: Engine Mechanical
ARP bolt kits are popular for the A-series engine.
Rod Bolts
ARP Rod Bolts: See Rod Studs
Cylinder Head Studs
ARP cylinder head studs & nuts replace the stock bolts.
  • 202-4202 (A12)
  • 202-4203 (A14)
NOTE: 1974-up A12 and A14 use the same center (long) head bolt.
So:
  • use #202-4202 (A12) for early engines A10 and pre-1974 A12
  • use #202-4203 (A14) for all late engines, including late A12, A12A, A13, A14, A15
Main Bearing Caps
202-5401a main bolt kit (same as L-series engines)
Nissan
  • 12293-18001 BOLT FIXING BEARING CAP (10)
    • same as L28, Z24, and L20B engines
