Leaf Springs
Revision as of 10:06, 14 March 2013; view current revision
Datsun 1200 used the tried and true leaf spring (blade) rear suspension, which was common among most cars - including american cars - in the early 1970s.
[hide]
55020-H1000 Sedan, Coupe $159 USD
55020-H1400 Van (heavy duty)
55020-G1000 Truck 4-leaf early
55020-G1001 Truck 4-leaf 7510-
55020-G1002 Truck 4-leaf 8504-
55020-G1060 Truck 5-leaf 7804-8503
55020-G1061 Truck 5-leaf 7804-8503 8504-
Ute 4-leaf pack Type 1
Ute 4-leaf pack Type 2 (2nd leaf overlaps 1st leaf)
Rear Shackle is same for all 1200s
Front 3-point Mount Plate (Sedan, Coupe)
Sedan rear shackle pin bracket
Details (truck, Pin front mount)
Truck rear shackle pin bracket
Truck front leaf pin
Spring Specifications
All 1200 springs are: 1110 mm long, 50mm wide
Spring Eye Diameter
* Coupe, Sedan, Van: 35mm front,  23mm rear
Sedan, Coupe
* 3 leaf: 1 x 6mm thick, 2 x 7mm thick
Van
* 4 leaf std: 3 x 6mm thick, 1 x 13mm thick
* 4 leaf H-D: 2 x 6mm thick, 1 x 7mm thick, 1 x 11mm thick
Truck
* 4 leaf: 2 x 6mm thick, 1 x 7mm thick, 1 x 13mm thick
* 5 leaf: 2 x 6mm thick, 1 x 7mm thick, 2 x 10mm thick
Free Camber
* Sedan, Coupe: 109mm +-3
* Van         : 131mm +-5
* Truck       : 118.5 mm
Laden Camber
* Sedan, Coupe: 11mm @ 192kg
* Van: 11mm @ 295kg
* Truck std 4-leaf: 18.5mm @ 267kg
* Truck HD 5-leaf:  15.1mm @ 376kg
Leaf Mounting
Also see: Shocks#Mounting
B110 mounts leaf directly to metal (unlike B10 and B210 which use rubber-based isoclamp).
Rear axle mounting
Spring Seat
Spring Seat Assembly
Sedan: 55262-H1001
Truck: 55262-G1000 (RH) 12mm shock Nut wide u-bolt
Van:   55262-H1401 (RH) 12mm shock Nut narrow u-bolt
       55262-H1402 (RH)   (from '73-6)
Coupe: 55262-H1801 (RH)  8mm shock Nut
       55262-H1802 (RH)   (from '73-5)
Also see Shock absorbers
B120 Truck
Coupe
B210 Coupe
Sedan and Coupe parts
U-bolts
U-bolts
55247-H1002 CLIP-rear spring Sedan, Coupe.USA
55240-H1800 Coupe.JPM.early
55247-H1401 CLIP-rear spring Van, Coupe.JDM.late
55247-G1000 CLIP-REAR SPRING Truck 4-leaf
55247-G1060 CLIP-REAR SPRING Truck 5-leaf 7804-
Fasteners for U-bolts (Sedan,Coupe,Van,Truck)
08911-64010 NUT-HEX M10 x 1.25 8
08915-14010 WASHER-spring lock 8
Sedan
Ute U-bolts (same M10 diameter but wider spacing for larger axle tube)
B210 Sedan U-bolts (plate has wider spacing than B110)
Bound Bumpers
Coupe & Van rear suspension bumper (above the axle housing)
55240-H1400 ASSY-BUMPER REAR AXLE
08911-64010 NUT-HEX M10X1.25
08915-14010 WASHER-SPRING LOCK
Sedan rear suspension bumper (on the Shocks)
55240-H1001 BOUND BUMPER A
56124-H1001 BOUND-BUMPER B
Torque Arrester
The Torque Arrester (pinion snubber) is a rubber bumper that prevents the leafs from rotating too much under torque input.
See Rear Axle
Bushings
5 55044-H1001 front upper Sedan, Coupe
  * superseded by 55044-H5001 $4.90 USD
6 55045-H1000 front lower Sedan, Coupe [leaf eye, course] $3.63 USD
17 55046-H1000 rear upper $2.27 USD
18 55047-H1000 rear lower [leaf eye, plain] $1.22 USD
NOTE: B210 USA uses the same bushes as 1200 Coupe/Sedan.
Wagon & Ute
V 55045-H1400 front Van, Truck [leaf eye, fine] $4.25 USD
55044-H5001
Ute/Van complete set
Make your own
Or, make your own performance bushings per Nissan Competition book:
    • I went to a local platics place and bought a piece of
Aftermarket
Or, get stiff aftermarket bushings:
Polyurethane bushings out of Mexico: Parbo
SuperPro Bushings
Lowering Springs
120Y Springs
120Y B210 leaf spring is 1165mm. It is 55mm longer than 1200 B110 (1110mm) and is not interchangeable.
Alternative Leaf Springs
Carbon Leafs
リーフ スプリング シャックル ブッシュ
