60-Series Transmission
Revision as of 08:55, 29 December 2014; view current revision
Categories: Transmission | Transmission Modifications
The 60-series transmissions can handle the torque from A14 and A15 engines. So the 60 four-speed is stronger than the 56 four-speed which was used behind A12 engine. The 60-series 5-speed is a beefier model than the stock Datsun 1200 GX-5's 56-Series Transmission. These 5-speeds came in the 1977-1982 Datsun B310 (210/Sunny/140Y/150Y). The four-speeds came behind A14s & A15s.
See 5-speeds#60_vs_56
60-series transmissions were used exclusively behind A14 and A15 engines, due to their ability to handle more torque than the smaller 56-series. However, starting with the B310 it was also offered behind the A12.
* B310 GL with A12 (B310H) came with optional 5-speed 60L (B310HF)
* FS5W60L used through 8010 (end of A12 in Japan)
* A13 (debut 8011) used 60A
60-series transmissions came in three varieties:
  • 60L four-speed for A-series engine
  • 60L five-speed for A-series engine
  • 60A five-speed for A-series engine
60L for A-series engine
* Four-speed: 1975 to 1982
* Five-speed: 1977-1979 B310 Sunny (manufactured through 1979 September)
  * Dogleg shift pattern
* 1980-up B310 Sunny (from 1979 October)
* Standard shift pattern
Note that 60-series gearboxes may be available for other engine types, so make sure you get one to match the A-series engine.
Gear Ratios
(see 5-speed Gear Ratios)
box	         4th	3rd	2nd	1st	5th	Rev
60L 4-speed     1.000	1.378	2.170	3.513		3.764
60L 5-speed     1.000	1.378	2.170	3.513	0.846	3.464
60A 5-speed A   1.000	1.378	2.170	3.513	0.821	3.764
60A 5-speed B   1.000	1.320	2.170	3.513	0.821	3.764
NOTES
  • The 1st through 4th gears are all the same -- 4-speed and 5-speed -- except for a few 5-speeds with 3rd closer to top (larger gap from 2nd to 3rd).
  • For freeway driving, the 60A has a larger overdrive and so is preferable to the 60L dogleg.
  • First gear is the same in all 60-series boxes
Swap Notes
When swapping a 60 transmission into a 1200, these parts should be obtained from the donor car:
  • Transmission
  • Release Lever which differs from the 1200 part
  • Release Bearing sleeve, which may differ from the 1200 version
  • Shifter
  • Crossmember or at least the rubber insulator
* the 60a 4-speed and 60a 5-speeds are the same length as the stock Datsun 1200 transmission, and the shifter is in the same spot
Rear Crossmember
The rear engine crossmember, that is to say the Gearbox Crossmember.
6946.jpg B310 stock rear engine mounts
Pitroad says the South Africa Datsun Bakkie (B140) had a FS5W60A 5-speed, and that the trans crossmember might work for a B110.
The 56-series mount (insulator) fits inside the crossmember, and bolts to the sides of the crossmember:
4651.jpg 1200 style mount
  • 11321-H1000 ASSY-INSULATOR ENGINE MOUNTING REAR B110 MANUAL
  • 11321-H1020 ASSY-INSULATOR ENGINE MOUNTING REAR B110 AUTOMATIC
  • 11321-H6200 ASSY-INSULATOR ENGINE MOUNTING REAR B210 A13 MANUAL TO 0873 [56-series]
  • 11321-H6201 B210 A14 0978-0874 [60-series 4-speed]
  • 11321-H7300 B210 A14 0974- [60-series 4-speed]
  • 11323-H7310 [63-series 5-speed]
  • 11321-H6201 INSULATOR ASSY-ENGINE MOUNTING REAR B310 A12A MANUAL [56-series]
The 60-series insulators sit on top of the crossmember, and bolt from the bottom:
1706.jpg B310 60-series rear engine mount
  • Uses two M8 X 1.25 NUT
  • 11320-H9100 INSULATOR ASSY-ENGINE MOUNTING REAR B310 A14/A15 MANUAL [60-series]
  • 11320-W5800 INSULATOR ASSY-ENGINE MOUNTING REAR B310 AUTOMATIC
Using 1200 Crossmember
1200 crossmember Adapted to 60-series transmission
Stock 1200 mount fitment (56-series)
884.jpg 4648.jpg Stock 1200 mount fitment
60-series fitment with adapter plate:
60-series fitment with modified mount:
click click click
Using B310 Mount
Or, use the B310 60-series rubber insulator with a simple custom crossmember that bolts to the original crossmember points.
60-series rubber mount
Use a u-shaped flat steel adapter, with long bolts and spacers.
Put together, it looks like this:
Or use a more sophisticated mount which doesn't need long bolts or spacers. Buy a mount at B-Pro, which replaces both the rubber mount and the crossmember:
click
Fits 60-series to Datsun 1200 manual tunnel.
Pitroad also sells a kit for the 60A:
They say it will also work for 60L if 20mm spacers are used.
Or make your own:
EDP mount adapter
OR, cut down a 60-series crossmember and weld angle-iron to it:
holes offset ~40mm and ~230mm apart
Custom Crossmember
8131.jpg custom engine mounts
Tailshaft
The stock Datsun 1200 driveshaft should be used. While the B310 driveshaft is the same length, it has the larger H150-style rear flange.
Reverse Switch
The reverse-light switch is right where the Datsun 1200 chassis x-member mount is. See Transmission_Interchange#Reverse_Switch
Swap Into Datsun 1200
(A special note of thanks to Davo1200 who started this section originally in the old Tech Section)
How do I install a 5 speed Sunny box?
Vanette Transmission
4650.jpg FS5W60A vs RS5W60A 5-speed comparo
Parts
Part Number prefixes:
  • H90xx B310 unique to F5W60L
  • 180xx B10 56-series
  • H73xx B210 60-series
Case Comparo
B210 F4W60A
  • 32100-H7300 ASSY-CASE,TRANSMISSION B210 F4W60A 0974-0776
  • 32100-H7302 ASSY-CASE,TRANSMISSION B210 F4W60A 0876-0377
  • 32100-H8902 ASSY-CASE,TRANSMISSION B210 F4W60A 0477-
B310 F4W60
  • 32100-H8902 CASE COMP-TRANSMISSION B310 F4W60 CANADA
  • 32100-H8903 CASE COMP-TRANSMISSION B310 F4W60 0879- USA
  • 32100-H9301 CASE COMP-TRANSMISSION B310 F4W60 0879- USA (supercedes 32100-H8903)
B310 FS5W60A
  • 32100-H9001 CASE COMP-TRANSMISSION B310 FS5W60A -0779 [FS5W60L, dogleg]
  • 32100-H9300 CASE COMP-TRANSMISSION B310 FS5W60A 0879- CAN (supercedes 32100-H9001)
  • 32100-H9301 CASE COMP-TRANSMISSION B310 FS5W60A 0879- FED, CAL (supercedes 32100-H9001)
F4W60L
rally cross of F4W60L Gear ratio
  • 1st: 3.19
  • 2nd: 2.38
  • 3rd: 1.89
  • 4th: 1.00
F4W60 gears - B210 USA CATALOG
32200-H7300 ASSY-GEAR MAIN DRIVE 20T
32210-H7300 GEAR-COUNTER 31-27-20-15T
32220-H7300 GEAR-REVERSE COUNTER 14T
32230-H7300 ASSY-GEAR 1ST SPEED 34T
32250-H7300 ASSY-GEAR 2ND SPEED 28T
32260-H7300 ASSY-GEAR 3RD SPEED 24T
32280-H7300 ASSY-GEAR REVERSE IDLER 22T
32245-H7300 GEAR-REVERSE MAIN SHAFT 34T
FS5W60L
Gearset
  • 32241-H9001 SHAFT-MAIN 1
  • 32264-H7300 BEARING-NEEDLE MAIN SHAFT 2
  • 32260-H9000 GEAR ASSY-3RD 27T 1
  • 32604-H9000 RING-BAULK 4
  • 32603-18000 RING-SYNCHRONIZER 4
  • 32609-18000 INSERT-SHIFTING 6
  • 32601-H9001 HUB SYNCHRONIZER-2ND & 3RD 1
  • 32606-18000 SLEEVE-COUPLING 2
  • 32250-H9000 GEAR ASSY-2ND 1
  • 32253-H7300 BUSH-1ST GEAR (MAIN SHAFT) 2
  • 32246-H7300 WASHER-THRUST 1
  • 32273-H7300 BEARING-(BALL,) MAIN SHAFT 1
  • 32246-H9000 WASHER-THRUST MAIN SHAFT 1
  • 32267-H7300 BEARING-(NEEDLE,) MAIN SHAFT 1
  • 32230-H9000 GEAR ASSY-1ST 1
  • 32602-32200 SPRING-SHIFTING INSERT (SYNCHRONIZER INSERT) 3 unique to F5W60L
  • 32608-H9000 INSERT-SHIFTING 9
  • 32258-H9001 HUB SYNCHRONIZER-1ST & REVERSE 1
  • 32245-H9000 GEAR-REVERSE, MAIN SHAFT
  • 32234-H9000 RETAINER SHIFTING INSERT 1 Catalog is incorrect
  • 32354-H9000 NUT-HEX (M25 X 1.0) 1
  • 32228-H9000 RING-SNAP OVERDRIVE BEARING 1 ? Or 00922-12200?
  • 00922-12200 RING-SNAP (T=1.2)? Or 32228-H9000?
  • 32227-H9000 BEARING-(BALL,) MAIN SHAFT END 1
  • 32228-H9000 RING-SNAP,MAIN SHAFT END BEARING 1? Or 00922-12200?
  • 32204-H7300 RING-SNAP MAIN DRIVE GEAR SELECT T=1.34-1.40 1 Select only one 32204
  • 32204-H7301 RING-SNAP MAIN DRIVE GEAR SELECT T=1.40-1.46
  • 32204-H7302 RING-SNAP MAIN DRIVE GEAR SELECT T=1.46-1.52
  • 32204-H7303 RING-SNAP MAIN DRIVE GEAR SELECT T=1.52-1.58
  • 32204-H7304 RING-SNAP MAIN DRIVE GEAR SELECT T=1.58-1.64
  • 32204-H7305 RING-SNAP MAIN DRIVE GEAR SELECT T=1.64-1.70
  • 32204-H7306 RING-SNAP MAIN DRIVE GEAR SELECT T=1.70-1.76
  • 32209-H7300 SPACER-BEARING MAIN DRIVE GEAR 1
  • 32214-H7300 RING-MAIN BEARING 2
  • 32203-H7300 BEARING-MAIN DRIVE 1
  • 32200-H7300 GEAR ASSY-MAIN DRIVE 1
  • 32272-H7300 BEARING-PILOT MAIN SHAFT 1 1 of 3
  • 32268-H9000 RING-SNAP SELECT T=1.60 1 Select only one 32263
  • 32268-H9001 RING-SNAP SELECT T=1.65 Select only one 32263
  • 32268-H9002 RING-SNAP SELECT T=1.70 Select only one 32263
  • 32601-H9000-HUB SYNCHRONIZER-4TH & 5TH 1 Also F560A
  • 32340-H9000 GEAR ASSY-OVERDRIVE 1
  • 32345-H9000 BEARING-OVERDRIVE GEAR (NEEDLE MAIN SHAFT) 1
  • 32219-H9000 BEARING-COUNTER SHAFT 1 Also F460A 7812-
  • 32224-H7200 WASHER-THRUST COUNTER SHAFT FRONT SELECT T=2.30-2.35 1 Select only one 32224
  • 32224-H7201 WASHER-THRUST COUNTER SHAFT FRONT SELECT T=2.35-2.40
  • 32224-H7202 WASHER-THRUST COUNTER SHAFT FRONT SELECT T=2.40-2.45
  • 32224-H7203 WASHER-THRUST COUNTER SHAFT FRONT SELECT T=2.45-2.50
  • 32224-H7204 WASHER-THRUST COUNTER SHAFT FRONT SELECT T=2.50-2.55
  • 32224-H7205 WASHER-THRUST COUNTER SHAFT FRONT SELECT T=2.55-2.60
  • 32224-H7206 WASHER-THRUST COUNTER SHAFT FRONT SELECT T=2.25-2.30
  • 32224-H7207 WASHER-THRUST COUNTER SHAFT FRONT SELECT T=2.20-2.25
  • 32210-H9000 GEAR-COUNTER ASSY 1
  • 32219-H9010 BEARING-COUNTER SHAFT 1
  • 32220-H9000 GEAR-REVERSE COUNTER 1
  • 32222-H9003 RING-SNAP COUNTER SHAFT SELECT T=1.3 1 Select only one 32222
  • 32222-H9004 RING-SNAP COUNTER SHAFT SELECT T=1.4
  • 32284-H9000 WASHER-THRUST COUNTER SHAFT REAR 1 Mistake? See 32285N
  • 32282-H9000 GEAR-REVERSE IDLER 1
  • 32272-H7300 BEARING-REVERSE IDLER GEAR 2 2 of 3
  • 32285-H9000 SPACER-REVERSE IDLER GEAR 1
  • 32292-14600 PIN-RETAINING 1 Also F560A
  • 32281-H9000 SHAFT-REVERSE IDLER 1
  • 32284-N9000 WASHER-THRUST REVERSE IDLER 2
FS5W60A
Bearings
BALL BEARING
32203  32203-H7300 BEARING-MAIN DRIVE
32219M 32219-H7300 BEARING-COUNTER SHAFT, REAR
ENCLOSED BEARING
32219  32219-H9700 BEARING-COUNTER SHAFT, FRONT
NEEDLE CAGE
32272  32272-H7300 BEARING-PILOT
32264M 32264-H7300 BEARING-NEEDLE MAIN SHAFT
32283  32289-H9700 BEARING-REVERSE IDLER GEAR
Thrust Washers
32287  32265-18000 WASHER-THRUST REVERSE IDLER [center]
32318  32287-H9700 WASHER-THRUST [REVERSE IDLER, rear]
32285N 32283-H9700 WASHER-THRUST REVERSE IDLER [front]
32224  WASHER-THRUST COUNTER SHAFT FRONT
       SELECT USE
       32224-H7200 T=2.30-2.35
       32224-H7201 T=2.35-2.40
       32224-H7202 T=2.40-2.45
       32224-H7203 T=2.45-2.50
       32224-H7204 T=2.50-2.55
       32224-H7205 T=2.55-2.60
       32224-H7206 T=2.25-2.30
      32224-H7207 T=2.20-2.25
Seals
Input Shaft
Front Cover Oil Seal for Aichi R4W60L/W60 4-speed, W60L/W60A 5-speed, RS5W60R 5-speed
32114-Y4000 Front Cover Oil Seal 60-series
Specs
* shaft size: 30 mm
* bore size: 45 mm
* seal outer diameter: 45.2 mm
* seal width: 8 mm
RockAuto
National 1981
Timken 1981
Fits:
* Nissan 32113-Y4000, 32114-20100, 32114-Y4000
* 8942152200
* 8943270620, 8943270621, 8943348450, 8943895931
* 9004310029, 9004311141, 9031130010, 9031130014
* 9031130115, 94215220, 94327062
* Ford EBTZ7052D
* Toyota W55 transmission
* Isuzu 8943270620 camshaft seal
Nissan 32114-Y4000
* A12/A14/A15,KA20DE/KA24E/KA24DE,TD23/TD25/TD27,NA20
* RD28,RB20,L18/LD20/L20,H20,Z18/Z20,VG20/VG30,FJ20,CA18
* 60-series, 71-series 71B/71C
Output Shaft
  • 32136-H5000 OIL SEAL-REAR EXTENSION [4-speed & 5-speed 60-series]
    • Nitrile Seal, Counter-Clockwise-Spiral Design
    • Shaft Size: 1.181"
    • Housing Bore: 1.772"
    • Seal Width: 0.591"
    • Seal Outside Dia: 1.78"
    • Flange Outer Diameter=2.441" (?)
  • 32160- many EXTENSION ASSY-REAR
Factory Service Manual says:
If rear extension bushing is worn or cracked, replace it as an assembly of bushing and rear extension
