Nissan Skyline model R31 was built in Japan 8508-9005. It was fitted with a Four Cylinder CA engine, or six-cylinder RB engines, or a Diesel. Australia-built R31 1986-1990 was sold as Skyline (six-cylinder) or Pintara (four-cylinder). Some parts can be used, or modified for use, on a Datsun 1200.
Engine
JAPAN F CA18S H RB20E/RB20ET SOHC R RB20DE/RB20DET DOHC S RD28 diesel
AUSTRALIA R31 Skyline: Holden RB30E R31 Pintara: CA20E (NAPSX) SOUTH AFRICA built CA20S RB20E RB30E
Wheels
R31 Skyline 14" steelies. See Skyline R31 spare steel wheels
Front Brakes
Standard wheel on both R30 and R31 is 14". Shouldn't be any problem running 14" wheels over these brakes.
Strut
R31 uses a standard Nissan 2.0" strut, so will bolt to the usual SAP. However you NEED to buy/fabricate a spacer with shear ring as the locating nub is a different size.
R31 Handbrake Lever
Diff
JAPAN R31 H190: CA18S Sedan, Hardtop, Wagon CA200: Wagon RB20T [4.11, 8601-] R200: RB20, RD28 Sedan, Hardtop [IRS]
AUS R31 Borg Warner * 9-bolt octagonal cover * has rear disc brakes with finned calipers BW78: Pintara, 25-spline axles BW78: Skyline, 28-spline axles
AUS
There is some confusion as the Japan-built R31 used a similar looking diff, the CA200. Aussie R31 used the BW78.
CA200: 8-bolt cover BW78: 9-bolt cover
See main article: Borg Warner 78
Rear Discs - see R31 Rear Disc Brake Swap
Swaps - see BW78 Rear Axle Swap
CA200
JAPAN R31 Wagon with RB20T SOHC Turbo 1986-1990 * (build dates 8601-9005) CA200: Wagon RB20T [4.11 (CA41), 8601-] * Drum brakes * 5-link with coil springs * 4-lug, 28-spline(?) axles
CASE-DIFFERENTIAL * 2-pinion * M12 ring gear bolts * Fits: CA41,CA43,CA46,CA48,RC35,RC37,RC39,RC41,RC43,RC46 38421-12S00 8601-8708 38420-P9400 8708 <2> 38420-12S10
CA41 37/9=4.111 38100-F3400 8601-8604 38100-F3401 8604- $677 USD
SHAFT ASSY-REAR AXLE 38162-42L00 * R31 with CA18S * R31 Wagon * C32 some * GC22 Vanette 8605 2WD
DRUM-BRAKE,REAR 43206-U4800
43010 CASE ASSY-REAR AXLE 43005-84S55 HOUSING W/GEAR <2> 43005-84S56
38423 GEAR-SIDE 38423-C6100 * (G)C22,D22,E23,E24,F22,F23,R31,WD21,160,250,
Alternative for swaps: GC22 Vanette - CA200 w/LSD
Gearbox
Japan-built R31 used FS5W71C 5-speed transmission.
32707-58S10 Sleeve, Speedometer Pinion 19T for CA18 * same as C22 with A12 engine
Speedometer cable with the larger end will work for Datsun 1200. 810 (200B) cable will work.
