<-- back to Part Numbers Index
Also see:
Main article for usage, photos, cross-reference 56-Series Transmission
Contents[hide] |
FS5C56A
1 32882-H7200 GEAR ASS'Y-reverse idle 2 32281-H7200 SHAFT-reverse idle 3 32283-H7201 BEARING-needle reverse idle (2) 4 32285-H7201 SPACER-needle bearing 5 32293-73200 PIN-retaining 6 32284-H7201 WASHER-thrust reverse idler (2) 7 32213-H7200 GEAR-counter 8 32220-H7200 GEAR-1st counter 9 32221-H7201 RING-snap counter 1st 10 32223-H7200 BEARING-ball, counter shaft as required 11 32224-H7200 WASHER-thrust counter bearing (t-2.30~2.35) 12 32224-H7201 WASHER-thrust counter bearing (t-2.35~2.40) 13 32224-H7202 WASHER-thrust counter bearing (t-2.40~2.45) 14 32224-H7203 WASHER-thrust counter bearing (t-2.45~2.50) 15 32224-H7204 WASHER-thrust counter bearing (t-2.50~2.55) 16 32224-H7205 WASHER-thrust counter bearing (t-2.55~2.60) 17 32200-H7200 GEAR ASS'Y-main drive 18 32611-H7200 RING-synchro 19 32612-H7200 BLOCK-thrust 20 32613-H7200 BLOCK-anchor 21 32614-H7200 BAND-brake 22 (2) 22 32616-H7200 CIRCLIP 23 32203-18000 BEARING-main driver gear 24 32205-18000 WASHER-thrust, main drive gear 25 32204-18000 RING-snap, main drive gear
F4W56L
4-speed Light-Duty to March 1973
1 32280-24901 ASSY-GEAR REVERSE IDLER 17T 4 SPEED 2 32283-24901 BUSH-GEAR REVERSE IDLER 4 SPEED 3 32281-24900 SHAFT-REVERSE IDLER 4 SPEED 4 32285-18000 RING-SNAP REVERSE IDLER (2) 4 SPEED 5 32210-24900 GEAR-COUNTER 29T,25T,19T,13T 4 SPEED 6 32223-24900 BEARING-BALL COUNTER SHAFT 4 SPEED 7 32220-24901 GEAR-REVERSE COUNTER 13T 4 SPEED 8 00922-11700 RING-SNAP 4 SPEED 9 32219-18000 BEARING-BALL COUNTER SHAFT 4 SPEED 10 32224-18003 SHIM-ADJUSTING COUNTER BEARING T=1. (0) 4 SPEED 10 32224-18006 SHIM-ADJUSTING COUNTER BEARING T=1. (0) 4 SPEED 10 32224-18004 SHIM-ADJUSTING COUNTER BEARING T=1. (0) 4 SPEED 10 32224-18002 SHIM-ADJUSTING COUNTER BEARING T=0. (0) 4 SPEED 10 32224-18001 SHIM-ADJUSTING COUNTER BEARING T=0. (0) 4 SPEED 10 32224-18005 SHIM-ADJUSTING COUNTER BEARING T=1. (0) 4 SPEED 11 00922-24000 RING-SNAP 4 SPEED 12 32200-H1000 ASSY-GEAR MAIN DRIVE 19T,30T 4 SPEED 13 32203-18000 BEARING-BALL MAIN SHAFT 4 SPEED 14 32205-18000 WASHER-MAIN BEARING 4 SPEED 15 32204-18000 RING-SNAP MAIN DRIVE GEAR SHAFT 4 SPEED 16 32241-H1010 SHAFT-MAIN 4 SPEED 17 32246-18000 WASHER-THRUST MAIN SHAFT 4 SPEED 18 32253-H1000 BUSH-MAIN SHAFT REVERSE GEAR 4 SPEED 0570- 6 32253-18000 18 32253-18000 BUSH-MAIN SHAFT REVERSE GEAR 4 SPEED 19 32264-H1000 BEARING-NEEDLE MAIN SHAFT 4 SPEED 0570- 6 32264-18000 19 32264-18000 BEARING-NEEDLE MAIN SHAFT 4 SPEED 20 32236-18000 SPACER-NEEDLE BEARING 4 SPEED 21 32230-24900 ASSY-GEAR 1ST SPEED MAIN SHAFT 32T 4 SPEED 22 32604-H1000 RING-BAULK (2) 4 SPEED 23 32609-18000 INSERT-SHIFTING (3) 4 SPEED 24 32603-18000 SPRING-SYNCHRONIZER (2) 4 SPEED 25 32601-18000 HUB-SYNCHRONIZER 4 SPEED 26 32606-18000 SLEAVE-COUPLING 4 SPEED 27 32264-24900 BEARING-NEEDLE MAIN SHAFT (2) 4 SPEED 28 32250-24900 ASSY-GEAR 2ND SPEED MAIN SHAFT 27T 4 SPEED 29 32260-24900 ASSY-GEAR 3RD SPEED MAIN SHAFT 23T 4 SPEED 30 32604-H1000 RING-BAULK (2) 4 SPEED 30 32604-H1010 RING-BAULK (2) 4 SPEED 2 32604-H1000 31 32609-18000 INSERT-SHIFTING (3) 4 SPEED 32 32603-18000 SPRING-SYNCHRONIZER (2) 4 SPEED 33 32601-18000 HUB-SYNCHRONIZER 4 SPEED 34 32606-18000 SLEEVE-COUPLING 4 SPEED 35 32265-18000 WASHER-THRUST SYNCHRO HUB 4 SPEED 35 32265-H7200 WASHER-THRUST SYNCHRO HUB 4 SPEED 0570- 2 32265-18000 36 32720-14600 BALL-STEEL 4 SPEED 37 32272-18000 BEARING-PILOT MAIN SHAFT 4 SPEED 38 32273-24900 BEARING-MAIN SHAFT 4 SPEED 39 32205-18000 WASHER-MAIN BEARING 4 SPEED 40 32204-18000 RING-SNAP MAIN SHAFT 4 SPEED 41 32245-24901 GEAR-REVESE MAIN SHAFT 31T 4 SPEED
F4W56A
4-speed Heavy-Duty from April 1973
1 32280-G1100 ASSY-GEAR REVERSE IDLER 17T 4 SPEED 0473- 2 32283-G1100 BUSH-GEAR REVERSE IDLER 4 SPEED 0473- 3 32281-G1100 SHAFT-REVERSE IDLER 4 SPEED 0473- 4 32285-18000 RING-SNAP REVERSE IDLER 4 SPEED 0473- 5 32210-G1100 GEAR-COUNTER 29T,25T,19T,13T 4 SPEED 0473- 6 32223-24900 BEARING-BALL COUNTER SHAFT 4 SPEED 0473- 7 32220-G1100 GEAR-REVERSE COUNTER 13T 4 SPEED 0473- 8 00922-11700 RING-SNAP 4 SPEED 0473- 9 32219-G1000 BEARING-NEEDLE COUNTER SHAFT 4 SPEED 0473- 10 32224-G1004 WASHER-THRUST COUNTER BEARING T=2 (0) 4 SPEED 0473-0573 3 10 32224-H7205 WASHER-THRUST COUNTER BEARING T=2. (0) 4 SPEED 0673- 2 32224-G1005 10 32224-H7204 WASHER-THRUST COUNTER BEARING T=2 (0) 4 SPEED 0673- 2 32224-G1004 10 32224-H7203 WASHER-THRUST COUNTER BEARING T=2. (0) 4 SPEED 0673- 2 32224-G1003 10 32224-G1003 WASHER-THRUST COUNTER BEARING T=2. (0) 4 SPEED 0473-0573 3 10 32224-G1002 WASHER-THRUST COUNTER BEARING T=2. (0) 4 SPEED 0473-0573 3 10 32224-H7201 WASHER-THRUST COUNTER BEARING T=2. (0) 4 SPEED 0673- 2 32224-G1001 10 32224-G1005 WASHER-THRUST COUNTER BEARING T=2. (0) 4 SPEED 0473-0573 3 10 32224-G1001 WASHER-THRUST COUNTER BEARING T=2. (0) 4 SPEED 0473-0573 3 10 32224-H7200 WASHER-THRUST COUNTER BEARING T=2. (0) 4 SPEED 0673- 2 32224-G1000 10 32224-G1000 WASHER-THRUST COUNTER BEARING T=2. (0) 4 SPEED 0473-0573 3 10 32224-H7202 WASHER-THRUST COUNTER BEARING T=2. (0) 4 SPEED 0673- 2 32224-G1002 11 32200-G1000 ASSY-GEAR MAIN DRIVE 19T,30T 4 SPEED 12 32203-18000 BEARING-BALL MAIN SHAFT 4 SPEED 0473- 13 32205-18000 WASHER-THRUST MAIN DRIVE GEAR 4 SPEED 0473- 14 32204-18000 RING-SNAP MAIN DRIVE GEAR 4 SPEED 0473- 15 32241-G1101 SHAFT-MAIN 4 SPEED 0473- 16 32246-G1000 WASHER-THRUST MAIN SHAFT 4 SPEED 0473- 17 32253-18000 BUSH-MAIN SHAFT REVERSE GEAR 4 SPEED 0473- 18 32264-18000 BEARING-NEEDLE MAIN SHAFT 4 SPEED 0473- 19 32230-G1100 ASSY-GEAR 1ST SPEED 4 SPEED 0473- 20 32604-H1000 RING-BAULK (2) 4 SPEED 0473- 20 32604-H1010 RING-BAULK (2) 4 SPEED 0473-0573 32 32604-H1000 21 32609-18000 INSERT-SHIFTING (3) 4 SPEED 0473- 22 32603-18000 SPRING-SYNCHRONIZER (2) 4 SPEED 0473- 23 32601-18000 HUB-SYNCHRONIZER 4 SPEED 0473- 24 32606-18000 SLEEVE-COUPLING 4 SPEED 0473- 25 32264-24900 BEARING-NEEDLE MAIN SHAFT (2) 4 SPEED 0473- 26 32250-G1100 ASSY-GEAR 2ND SPEED 4 SPEED 27 32260-G1100 ASSY-GEAR 3RD SPEED 4 SPEED 0473- 28 32604-H1000 RING-BAULK (2) 4 SPEED 0473- 28 32604-H1010 RING-BAULK (2) 4 SPEED 0673- 2 32604-H1000 29 32609-18000 INSERT-SHIFTING (3) 4 SPEED 0473- 30 32603-18000 SPRING-SYNCHRONIZER (2) 4 SPEED 31 32601-18000 HUB-SYNCHRONIZER 4 SPEED 32 32606-18000 SLEEVE-COUPLING 4 SPEED 33 32265-18000 WASHER-THRUST SYNCHRONIZER HUB 4 SPEED 0473- 33 32265-H7200 WASHER-THRUST SYNCHRONIZER HUB 4 SPEED 0473- 2 32265-18000 34 32720-14600 BALL-STEEL 4 SPEED 0473- 35 32272-18000 BEARING-PILOT MAIN SHAFT 4 SPEED 0473- 36 32273-G1000 BEARING-BALL MAIN SHAFT 4 SPEED 0473- 37 32205-18000 WASHER-MAIN BEARING 4 SPEED 0473- 38 32204-18000 RING-SNAP MAIN SHAFT 4 SPEED 0473- 39 32245-G1100 GEAR-REVERSE MAIN SHAFT 4 SPEED 0473-
