Grille Badge
See main article: B10 Badges
1967-1968 'D' chevron 62311-18025 (JDM and Export used this)
1969-1970 'S' shield 62311-27725 1969-1970 'D' shield 62311-27726
COUPE [flag style 'S'] 62311-25725 62311-25700
Coupe
* 62303-25700 Coupe (base) * 62303-25701 Coupe GL
Export Coupe
Australia Coupe
1970 Australia Coupe
Sedan
* Type 180 1967 (multi-slat aluminum) * Type 277 1968 (eggcrate style) * Type 257 Coupe-style (JDM sedan use) 62303-25700 * Type H01 1969 (4 chromed slats)
1967 Sedan
1966-1967 62303-18002
JDM 1000 - note the 'D' badge
full
1967 Standard Sedan
full
1968 Sedan
62303-27700 62303-27701
1969 Sedan
62303-H0100
1969 Standard Sedan
Van
Wagon uses same grilles as Sedan:
- Type 180 1967 (multi-slat aluminum)
- Type 277 1968 (eggcrate style)
- Type H01 1969 (4 chromed slats)
GRILLE-radiator * 62303-18002 [with vertical center badge] * 62303-27700 from Chassis no. VB10-066701 [eggcrate style with 'S' shield badge] * 62303-27701 from Chassis no. VB10-955161 * 62303-H0100 from 1968 October
1966 grille
Same as sedan?
1968-1969 Deluxe
Truck
B20 Truck a.k.a. ute
- Early ute grille has vertical bars dividing it into 2 sections
- Early sedan grille has vertical bars dividing it into 4 sections
Type 180 Sedan/Van Grille
full
Type 154 pick-up Grille
full
STD 1968 Truck
STANDARD * 62303-15400 GRILLE-radiator TS (not listed in Export catalog) Used with chevron center emblem
* 62303-15401 Used with shield center emblem full
Export B20 (B20U) introduction
1968
STD 1969-1970 Truck
* 62303-G0100 GRILLE-radiator TS 1969- Used with shield emblem
DX Truck
DELUXE 62303-G0101 GRILLE-radiator TD full
Deluxe added small vertical dividers in the upper and lower portion of the grille -- similar to the 1963 Datsun 320 truck grille
Export Truck
- Deluxe Truck was not offered
- Apparently in AUS, sedan grilles were used with some utes
1968 Australia ute with 180-Type (1967 sedan) grille
Australia ute with H01-Type (1969 sedan) grille
