Pedals
Revision as of 02:57, 9 January 2016; view current revision
Category: Body
Brake and Clutch pedals go in the pedal box.
[hide]
The pedal boxes are the same manual & auto, but brake pedal width differs. Brake pedal looks the same RHD and LHD. Clutch pedal differs LHD vs RHD. In Oct 1989 they changed the pedals to use a different pads - they may be interchangeable with earlier pedals.
20631.jpg th_willieoec-img600x450-1327301597khao5r38841.jpg th_willieoec-img600x450-1327301597qhkfya38841.jpg th_willieoec-img600x450-1327301597tfg2sp38841.jpg 25866.jpg 25867.jpg
Stays (brackets) are welded to the upper dash panel. The box bolts to the stays
Steering Column bolts undeneath the front of the pedal box
4 bolts where it bolts to the stays
4 bolts at the front, where it bolts to tabs welded into firewall
Throttle Pedal
The accelerator is attached to the firewall, outside of the pedal box.
See main article: Accelerator Pedal
Adjustment
Brake Pedal
  1. Loosen the stopper nut
  2. Measure height of pedal. It should be 143.5 mm. Insert shims on outside of firewall until height is 143.5 mm
  3. Tighten stopper until height is 139.5 to 143.5 mm. Tighten stopper nut.
  4. Double-check free play (5-15 mm)
  5. Double-check total travel of pedal (120mm)
Clutch Pedal
See:
Accelerator Pedal
See Accelerator Pedal
Also See:
Dash Part Numbers for the box and stays
Brake Pedal Part Numbers
Clutch Pedal Part Numbers
* Same: Sedan/Van/Coupe/Truck
RHD
  46580-H1000 STAY-bracket, pedal & steering post (R.H.)
  46581-H1000 STAY-bracket, pedal & steering post (L.H.)
  46570-H1001 ASS'Y-BRACKET, pedal & steering post
LHD
  46580-H1600 STAY-bracket, pedal & steering post (R.H.)
  46581-H1600 STAY-bracket, pedal & steering post (L.H.)
  46570-H1600 ASS'Y-BRACKET, pedal & steering post
fixing reinforce & stay
  08110-62062 BOLT-with lock washer (8) or 08110-61262
  08915-53510 WASHER-plain (8)
Pedal bushing
46525-18000 BUSHING-pedal fulcrum (2)
* replaced by 46525-N8200 0880-up $1.64 USD
* Fits B10, B110, B210 & B310 USA & JDM
Pedal shaft, nut & washer with bushings fitted
Pedal Rubber
46531-18001 COVER-PEDAL PAD for BRAKE MANUAL $2.52
46531-20301 COVER-PEDAL PAD for BRAKE AUTOMATIC NLA
46531-M3000 COVER-PEDAL PAD for CLUTCH $2.52 USD
* formerly 46531-18001
46512-H0101 RUBBER-BRAKE PEDAL STOPPER $3.00 USD
* Will Fit With Most Nissans
46512-H0101
Clear: 46584-S0100, Green: 46512-H0101
Broken and new parts
B140
1400 vs 1200 boxes
B210 manual pedal boxes have an extension welded on the left side. So they are not interchangeable with auto pedal boxes. Brake booster makes a difference too.
B210 JDM Pedal Box
 MANUAL TRANSMISSION
  45670-H5000 Manual A12
  45670-H5800 Manual for use with booster
  * A12 GX,MTM OPT GL,MTM from '75-4
 AUTOMATIC TRANSMISSION
  45670-H5020 Automatic A12 1973-1975
  45670-H5820 Automatic for use with booster
  * GX,ATM OPT GL,ATM from '75-4
 MTM: GX マスターバック, GL ラインオプョン
Non-booster vs Booster pedals (B210)
full
Note that a clutch pedal can be attached to the automatic-type pedal box
B210 manual, with boosted brakes
