Japan Electrical Control Systems formed 1973 as a joint venture of Nissan and Bosch.
Feed Type
SR: side-feed injectors (most) SR: top-feed injectors (some) RB25: side-feed injectors CA: top-feed injectors, low impedance (requires dropping resistor) RB20: top-feed injectors, low impedance
Colors
Wheel HP listed is appropiate power level of the injector set for a conservative tune (not saturating the injectors).
Side-feed Injectors 185cc 125whp Pink GA16 259cc 175whp Red SR20DE 333cc 226whp Grey SR20VE 370cc 250whp Purple SR20DET 444cc 300whp Brown SR20DET (S15)
Top-feed Injectors 260cc 175wgp Red CA18DE 370cc 250whp Cream CA18DET 350cc 275whp Green SR20VE 20V P12 444cc 300whp Yellow SR20DET (GTiR), SR20VET
INJECTOR ASSY-FUEL 16600,16603
16600-35F05 JECS キイロ/YELLOW <> 16600-35F01 <> 16600-35F00 DKC キイロ/YELLOW [330cc???] * S13 CA18D
16600-35F10 (OPTION) JECS ミドリ/GREEN <> 16600-35F11 <> 16600-35F15 DKC ミドリ/GREEN * S13 CA18D
16600-56E00 JECS <> 16600-56E01 <> 16600-56E05 DKC [370c, top-feed, 2.6ohm] * RS13/S13 CA18DT, U12 CA18DT
16600-52F10 センタク シヨウ ミドル/SELECT USE GREEN <> 16600-52F12 * S13 SR20D, RS13 SR20DE
16600-52F00 センタク シヨウ ミドル/SELECT USE GREEN <> 16600-52F02 * S13 SR20D, RS13 SR20DE
16600-50F00 センタク シヨウ キイロ/SELECT USE YELLOW <> 16600-50F02 * RS13, S13
16600-50F10 センタク シヨウ ミドル/SELECT USE GREEN <> 16600-50F12 [380cc, side-feed] * RS13, S13
16600-05U00/16600-05U02 [440cc top-feed diversion] * AWC24.RB26DETT,R33.RB26DETT,R32.RB26DETT
16600-54C00/16600-54C02 [440cc top-feed diversion, 2.0 ohm] * AWC34.RB26DETT,R34.RB26DETT * N14.SR20DET
Bosch Grey top feed, high impedance, 365cc
* JAPAN Primera, USA Sentra 2000-2002
16600-0A500 オートックバージョン シヨウ [K116] <> 16600-91F00 [BROWN, 480cc, side-feed] * S14 *2WS.SR20DET.MT, S15.SR20DET.MT.F6
16600-21U00 <> 16600-21U01 [PURPLE, 370cc, side-feed] * S14.SR20DET,S15.SR20DET.AT.F4,R33.RB25DET * R33.RB25DET,C34.RB25DET,WC34.RB25DET,C35.RB25DET * USA Z32.VG30DTT
16600-10Y01 [DARK RED, 260cc] * SR20DE: M12,N30,P11,WP11,R11,RB14,S14,S15,U14,W11 * SR18DE: N15 * RB25DE: R33,WC34,C34 * USA B14U.SR20DE,B14X.SR20DE * USA Z32.VG30D
16600-01Y00/16600-01Y01/16600-01Y03 JECS RED 16600-01Y05/16600-01Y10/16600-01Y11 DKC RED [TOP-FEED] * S14.SR20DE,S15.SR20DE,P11.SR20DE,U14.SR20DE * M12.SR20DE,N15.SR18DE,N30.SR20DE,RB14.RB25DE * W11.SR20DE,P11.SR20DE,R11.SR20DE,WP11.SR20DE * R33.RB25DE,WC34.RB25DE,C34.RB25DE * USA KN13 CA18DE Aftermarket * SMP FJ191 * Airtex/Wells 4G1458 * Bosch 62016 red-top, top-feed
16600-37M00 SELECT USE JECS W/BLUE POINT * USA KN13 CA16DE 0986-0887 aftermarket * Airtex/Wells 4G1456 Blue Stripe ** 16600-37M00/16600-37M05/16600-37M06
16600-37M10 SELECT USE JECS W/BLACK POINT * USA KN13 CA16DE 0986-0887 * Airtex/Wells 4G1455 Black Stripe ** 16600-37M07/16600-37M10/16600-37M15/16600-37M16 * SMP FJ131 Black * AcDelco 2171887 BLACK
16603-17M00 * USA N12.E15ET * B12.E15T,B11.E15ET,N12.E15ET 16603-18F00 * USA S12.CA18ET 16603-18F02 JECS BLACK 16603-18F11 DKC BLUE * USA S12.CA18ET 16603-18F12 DKC BLACK * USA S12.CA18ET AFTERMARKET * Beck/Arnley 1580164 Green-top ** 16600-AA000 * SMP FJ158 Green-top ** 16600-18F14 ** 16600-AA000 ** 16600-37M00/16600-37M05/16600-37M06/16600-37M07/16600-37M10/16600-37M15/16600-37M16/16600-37M17 ** 16603-17M00/16603-17M01 ** 16603-18F00/16603-18F01/16603-18F02/16603-18F11/16603-18F12/16603-18F13/16603-18F14
CA-Series
CA18DE - YELLOW OR GREEN high power engines CA18DE - RED low power engines
16600-35F05 JECS キイロ/YELLOW <> 16600-35F01 <> 16600-35F00 DKC キイロ/YELLOW [330cc???] * S13 CA18D 16600-35F10 (OPTION) JECS ミドリ/GREEN <> 16600-35F11 <> 16600-35F15 DKC ミドリ/GREEN * S13 CA18D
CA18DET - 370cc??? 16600-56E00 JECS <> 16600-56E01 <> 16600-56E05 DKC * RS13/S13 CA18DT, U12 CA18DT
SR-Series
SR20DE 16600-52F10 センタク シヨウ ミドル/SELECT USE GREEN <> 16600-52F12 * S13 SR20D, RS13 SR20DE 16600-52F00 センタク シヨウ ミドル/SELECT USE GREEN <> 16600-52F02 * S13 SR20D, RS13 SR20DE SR20DET 16600-50F00 センタク シヨウ キイロ/SELECT USE YELLOW <> 16600-50F02 * RS13, S13 16600-50F10 センタク シヨウ ミドル/SELECT USE GREEN <> 16600-50F12 * RS13, S13
Bosch Grey top feed, high impedance, 365cc * JAPAN Primera, USA Sentra 2000-2002
RB-series
440cc
Dropping Resistor
Resistor pack/resistor box can be obtained from the wreckers from a Nissan Pulsar or Silvia/180SX/240SX. Or any other 1980s 4-injector EFI Nissan.
22698 RESISTOR-DROPPING
JECS A15-000J01 JECS A15-000G02 * 2-wire * fuel pump resistor JECS A15-000A00 2-wire * 1990 KGN13 GA16I JECS A15-000850 3-wire? * KEN13 CA16DE
22698-36F00 (JECS A15-000G01) * S13(S20DE+SR20DET+CA18DE+CA18DET) * 6-pin squircle connector (pin 5 missing)
22698-N4202 (JECS A15-000571) $60.65 USD * B310.A14E, 250.Y44E, S110.(Z18E+Z20E)
22698-W1401 <> 22698-D0300 * B310 A15E * K10.3HB.T,910.(Z18E#+Z20E),B11.(E15E+E15ET),N12.E15T,R30.(Z20E+FJ20E),S110.(Z18E+Z20E+FJ20)
