Datsun 1000 tail lights vary by model and country.
Side Lights
Datsun 1000 front guard was fitted with different indicator lamp lenses depending on the year and trim.
- 1967 Model: Small Round dome type
- 26161-18000 LENS-lamp
- pic
- Looks similar to 510 rear USA (EVER WING A3036 SAE P167), but this is much flatter.
- The B10 lens sticks out quite a bit.
- 1968, 1969: Short spear
- 1970: Long spear (13cm+). Same as Datsun 510 "1600"
Datsun 521 pickup in USA uses a spear that looks similar.
Datsun 521 part number 26160-B0101 is identical to the 1000 1968/1969 short spear lamp.
Coupes uses same lense as others, but the assembly (lamp housing) is different for Coupe.
Position
Front Lights
Datsun 1000 was fitted with clear lens front combination lamp, using an orange bulb.
Australia
Aussie models had a orange bulb offset to the inside of the lens.
FRONT PARKING & TURN SIGNAL LAMP * Coupe: Below bumper * Sedan: Above bumper
PARKING & TURN SIGNAL LAMP ASSY H03 Coupe 209 Sedan, Wagon, Ute 1967 277 Sedan, Wagon, Ute 1968-1970
Sedan
Sedan clear rectangular lens
26120-20908 ASSY=LAMP,PARKING & TURN SIGNAL RH (TO SEP-'67) 26125-20908 ASSY=LAMP,PARKING & TURN SIGNAL LH (TO SEP-'67)
1967
26126-20900 LENS=TURN SIGNAL RH CLEAR (TO SEP-'67) 26127-20900 LENS=TURN SIGNAL LH AMBER (TO SEP-'67)
1967 Right
26122-20900, Right Amber Lens.
26120-27751 ASSY=LAMP,PARKING & TURN SIGNAL RH (FROM OCT-'67) 26125-27751 ASSY=LAMP,PARKING & TURN SIGNAL LH (FROM OCT-'67)
1968
26125-27750 'EVER WING EW0603L'
1968
1969
1969-1970
Coupe
Coupe front lights * 2-section (amber + clear) * Large Amber lens
26120-H0300 ASSY=LAMP,PARKING & TURN SIGNAL RH COUPE 26125-H0300 ASSY=LAMP,PARKING & TURN SIGNAL LH COUPE
Coupe: 2-section (amber + clear)
Ute
Export B20 (B20U) introduction
Japan-market. Clear lens with centered orange bulb.
full
EXCEPT COUPE 26120-18000 ASS'Y-LAMP, & turn signal ALL except Coupe 26120-27701 RH 26125-27701 RH 26120-H0110 LH 26125-H0110 LH![]()
26121-18000 LENS-parking & turn signal (2)
COUPE 26120-18010 LENS-parking & turn signal (2) [1967?] 26120-25703 RH 26125-25703 LH 26120-H0310 RH 26125-H0310 LH![]()
Position
Sedan, Van, Ute: Fitted above the bumper
Coupe: Fitted below the bumper
Tail Lights
Datsun 1000 rear lamps were combination type.
Sedan
B10 Sedan rear lamps came in two styles.
180 type: 1967-1969full
H01 type: 1970 (from October 1969)full
Coupe
Wagon
VB10 lamp
1968 (to September 1968), also 1967 Australia
182 1967 Red + Red 209 1967 Red + Amber Australia 209 1968 Red + Amber H04 1969-1970 Amber + Red + Clear
Reverse Lamp 1967-1968 Deluxe had separate lamp 1969-1970 Lower portion of tail lamps
1967 (except Australia)
1969-1790 seperate lenses
.jpg)
