Nissan Factory service manual for the A14E fuel injected engine, 1978 edition.
A14E Service Manual A14E Service Manual Part 2 Engine Overhaul & Service Data
You can help us out! If you can type Japanese, please click Edit and type in the text. Also need help translating. Thanks!
A型 エンジン
A-series Engine
(1978 Standards Conforming Car)
はじめに Introduction
はじめに
この本は、53年度排出ガス規制適合のNAPSを挟用したA系EGI仕 ... | Introduction
This book, A-specifications EGI system was for conforming the NAPS of 1978 fiscal exhaust gas regulations ... |
目次 Table of Contents
Summary 4
page 41. 概要
| 1. Summary
Engine Main Specifications 5
1-1 エンジン主要諸元 Engine Main Specifications
page 5http://i297.photobucket.com/albums/mm219/ddgonzal/005.jpg/A14E
NAPS Specification List 6
1-2 NAPS仕様-覧 NAPS Specification - List
page 6http://i297.photobucket.com/albums/mm219/ddgonzal/006.jpg/A14E
Engine Appearance 7
1-3 エンジン外観 Engine Appearance
1. 二?空気導入 Exhaust Air Induction Tube 2. Throttle Chamber 3. Air Regulator 4. EGR control valve 5. Dash Pot
1. Water temperature switch 2. TV valve 3. Water temp sensor 4. Blowby lower hose
1. Alternator 2. Distributor 3. Blowby upper hose 4. Pressure Regulator 5. VVT valve 6. VC solenoid valve 7. Fuel injector
Engine Sectional View 10
1-4 エンジン断面図 Engine Sectional View
page 10http://i297.photobucket.com/albums/mm219/ddgonzal/010.jpg/A14E
Engine Performance Curve 11
1-5 エンジン性能曲線 Engine Performance Curve
page 11http://i297.photobucket.com/albums/mm219/ddgonzal/011.jpg/A14E
NAPS System View 12
1-6 NAPSシステム図 NAPS System View
page 12http://i297.photobucket.com/albums/mm219/ddgonzal/012.jpg/A14E
NAPS Piping Diagram 13
1-7 NAPS配管図 NAPS Piping Diagram
(1) Vacuum Hose Diagram
page 13http://i297.photobucket.com/albums/mm219/ddgonzal/013.jpg/A14E
mm 1. 170 Vacuum gallery ~ pressure regulator 2. 90 VVT tube ~ VVT valve 3. 200 VVT valve ~ TV valve 3-way connector 4. 70 Vacuum gallery ~ Dist. 3-way connector 5. 50 Vacuum gallery ~ Dist. 3-way connector 6. 190 Vacuum gallery ~ TV valve 7. 170 EGR control valve ~ TV valve 8. 110 TV valve ~ 3-way connector 9. 540 Distributor ~ 3-way connector 10. 120 Vacuum gallery ~ VC solenoid valve 11. 200 VVT valve ~ VC solenoid valve 12. 200 Throttle chamber ~ vacuum gallery 13. 90 Vacuum connector ~ vacuum gallery 14. 130 Throttle chamber ~ vacuum gallery (for Distributor) 15. 230 Throttle chamber ~ VC solenoid valve 16. 170 Throttle chamber ~ vacuum gallery (for EGR control) 17. Blind Cap
page 14http://i297.photobucket.com/albums/mm219/ddgonzal/014.jpg/A14E
Engine Maintenance Notes 15
1-8 エンジン整備上の注意 Engine Maintenance Notes
page 15http://i297.photobucket.com/albums/mm219/ddgonzal/015.jpg/A14E
page 16http://i297.photobucket.com/albums/mm219/ddgonzal/016.jpg/A14E
page 17http://i297.photobucket.com/albums/mm219/ddgonzal/017.jpg/A14E
Engine Start-up Notes 18
1-9 エンジン始動上の注意 Engine Start-up Notes
page 18http://i297.photobucket.com/albums/mm219/ddgonzal/018.jpg/A14E
Regular Inspection And Maintenance 19
2. 定期点検整備 Regular inspection and maintenance
page 19http://i297.photobucket.com/albums/mm219/ddgonzal/019.jpg/A14E
page 20http://i297.photobucket.com/albums/mm219/ddgonzal/020.jpg/A14E
page 21http://i297.photobucket.com/albums/mm219/ddgonzal/021.jpg/A14E
page 22http://i297.photobucket.com/albums/mm219/ddgonzal/022.jpg/A14E
page 23http://i297.photobucket.com/albums/mm219/ddgonzal/023.jpg/A14E
page 24http://i297.photobucket.com/albums/mm219/ddgonzal/024.jpg/A14E
キャニスター Canister * ? * ? filter 40,000 km
キャニスター本体 Canister Body フィルター Filterフィルターの点検 Filter Inspection
page 25http://i297.photobucket.com/albums/mm219/ddgonzal/025.jpg/A14E
page 26http://i297.photobucket.com/albums/mm219/ddgonzal/026.jpg/A14E
page 27http://i297.photobucket.com/albums/mm219/ddgonzal/027.jpg/A14E
Checker 28
3. チェッカー Checker
Function Checker 28
3-1 ファンクション チェッカー Function Checker
page 28http://i297.photobucket.com/albums/mm219/ddgonzal/028.jpg/A14E
page 29http://i297.photobucket.com/albums/mm219/ddgonzal/029.jpg/A14E
EGI Harness Check 30
3-2 EGI ハーネス チェッカー (EG1131) EGI Harness Checker
page 30http://i297.photobucket.com/albums/mm219/ddgonzal/030.jpg/A14E
(1) (2)page 31
page 31http://i297.photobucket.com/albums/mm219/ddgonzal/031.jpg/A14E
page 32http://i297.photobucket.com/albums/mm219/ddgonzal/032.jpg/A14E
page 33http://i297.photobucket.com/albums/mm219/ddgonzal/033.jpg/A14E
EGI Circuit (page 34)
full | japanese
Checker: ハーネス実態図 EGI Harness Schematic View (page 35)
full | Japanese
page 36http://i297.photobucket.com/albums/mm219/ddgonzal/036.jpg/A14E
page 37http://i297.photobucket.com/albums/mm219/ddgonzal/037.jpg/A14E
EGI Control Unit Checker 38
3-3 EGIコントロール ユニット チェッカー EGI Control Unit Checker
page 38http://i297.photobucket.com/albums/mm219/ddgonzal/038.jpg/A14E
page 39http://i297.photobucket.com/albums/mm219/ddgonzal/039.jpg/A14E
page 40http://i297.photobucket.com/albums/mm219/ddgonzal/040.jpg/A14E
page 41http://i297.photobucket.com/albums/mm219/ddgonzal/041.jpg/A14E
Fault Diagnosis 42
4. 故障診断 Fault diagnosis
page 42http://i297.photobucket.com/albums/mm219/ddgonzal/042.jpg/A14E
page 43http://i297.photobucket.com/albums/mm219/ddgonzal/043.jpg/A14E
page 44http://i297.photobucket.com/albums/mm219/ddgonzal/044.jpg/A14E
On-vehicle Engine Maintenance 45
5. 車載上のエンジン整備 On-vehicle Engine maintenance
Air Door Adjustment 45
5-1 アイ ドル調整
page 45http://i297.photobucket.com/albums/mm219/ddgonzal/045.jpg/A14E
page 46http://i297.photobucket.com/albums/mm219/ddgonzal/046.jpg/A14E
page 47http://i297.photobucket.com/albums/mm219/ddgonzal/047.jpg/A14E
Air Cleaner and ? 48
5-2 エア クリーナー及びニ?空気?入(EAI)装
page 48http://i297.photobucket.com/albums/mm219/ddgonzal/048.jpg/A14E
Throttle Chamber 89
5-8 スロットル チャンバー
page 89http://i297.photobucket.com/albums/mm219/ddgonzal/089.jpg/A14E
Manifold 90
5-9 マニホールド
page 90http://i297.photobucket.com/albums/mm219/ddgonzal/090.jpg/A14E
page 91http://i297.photobucket.com/albums/mm219/ddgonzal/091.jpg/A14E
Cylinder Head 92
5-10 シリダー ヘッド
page 92http://i297.photobucket.com/albums/mm219/ddgonzal/092.jpg/A14E
page 93http://i297.photobucket.com/albums/mm219/ddgonzal/093.jpg/A14E
page 94http://i297.photobucket.com/albums/mm219/ddgonzal/094.jpg/A14E
Catalyst ? 95
5-11 触媒コンベーター及び排気温?報装置
page 95http://i297.photobucket.com/albums/mm219/ddgonzal/095.jpg/A14E
page 96http://i297.photobucket.com/albums/mm219/ddgonzal/096.jpg/A14E
page 97http://i297.photobucket.com/albums/mm219/ddgonzal/097.jpg/A14E
page 98http://i297.photobucket.com/albums/mm219/ddgonzal/098.jpg/A14E
page 99http://i297.photobucket.com/albums/mm219/ddgonzal/099.jpg/A14E
page 100http://i297.photobucket.com/albums/mm219/ddgonzal/100.jpg/A14E
page 101http://i297.photobucket.com/albums/mm219/ddgonzal/101.jpg/A14E
page 102http://i297.photobucket.com/albums/mm219/ddgonzal/102.jpg/A14E
103
page 103http://i297.photobucket.com/albums/mm219/ddgonzal/103.jpg/A14E
104
page 104http://i297.photobucket.com/albums/mm219/ddgonzal/104.jpg/A14E
105
page 105http://i297.photobucket.com/albums/mm219/ddgonzal/105.jpg/A14E
page 106http://i297.photobucket.com/albums/mm219/ddgonzal/106.jpg/A14E
page 107http://i297.photobucket.com/albums/mm219/ddgonzal/107.jpg/A14E
108
page 108http://i297.photobucket.com/albums/mm219/ddgonzal/108.jpg/A14E
page 109http://i297.photobucket.com/albums/mm219/ddgonzal/109.jpg/A14E
page 110http://i297.photobucket.com/albums/mm219/ddgonzal/110.jpg/A14E
Engine ? 111
6. エンジン脱? Engine ?
page 111http://i297.photobucket.com/albums/mm219/ddgonzal/111.jpg/A14E
page 112http://i297.photobucket.com/albums/mm219/ddgonzal/112.jpg/A14E
page 113http://i297.photobucket.com/albums/mm219/ddgonzal/113.jpg/A14E
Engine Overhaul 114
See A14E Service Manual Part 2
7 Engine Overhaul 114 7.1 Overhaul Notes 114 7.2 Disassembly 115 7.3 Inspection, Correction, Replacement 119 7.3.1 Cylinder Head and Valve 119 7.3.2 Cylinder Block 124 7.3.3 Piston, Piston Ring, Conrod 125 7.3.4 Crankshaft, Main Bearing 128 7.3.5 Camshaft 130 7.3.6 Other Components 131 7.4 Assembly 132
Service Data 141
8. サ=ビス データ Service Data
8.1 Standard Bolt, Nut Tightening Torque 141 8.2 Engine Torque Specs 142 8.3 Service Data 143
Special Tools And Checker 146
9. 特殊工具監及びチェッカー Special tools and checker
Special Tools 146
9-1 特殊工具
page 146http://i297.photobucket.com/albums/mm219/ddgonzal/146.jpg/A14E
page 147http://i297.photobucket.com/albums/mm219/ddgonzal/147.jpg/A14E
page 148http://i297.photobucket.com/albums/mm219/ddgonzal/148.jpg/A14E
page 149http://i297.photobucket.com/albums/mm219/ddgonzal/149.jpg/A14E
page 150http://i297.photobucket.com/albums/mm219/ddgonzal/150.jpg/A14E
Checker and Check Sheet 151
9-2 チェッカー及びチェック シート
page 151http://i297.photobucket.com/albums/mm219/ddgonzal/151.jpg/A14E
page 152http://i297.photobucket.com/albums/mm219/ddgonzal/152.jpg/A14E
page 153http://i297.photobucket.com/albums/mm219/ddgonzal/153.jpg/A14E
page 154http://i297.photobucket.com/albums/mm219/ddgonzal/154.jpg/A14E
Inspection Circuits 155
10. 点検回路 Checking Circuits
Function Checker Check 155
10-1 ファンクション チェッカー チェック
page 155http://i297.photobucket.com/albums/mm219/ddgonzal/155.jpg/A14E
EGI Harness Checker Check 156
10-2 EGI ハーネス チェッカー チェック
page 156http://i297.photobucket.com/albums/mm219/ddgonzal/156.jpg/A14E
page 157http://i297.photobucket.com/albums/mm219/ddgonzal/157.jpg/A14E
page 158http://i297.photobucket.com/albums/mm219/ddgonzal/158.jpg/A14E
page 159http://i297.photobucket.com/albums/mm219/ddgonzal/159.jpg/A14E
page 160http://i297.photobucket.com/albums/mm219/ddgonzal/160.jpg/A14E
page 161http://i297.photobucket.com/albums/mm219/ddgonzal/161.jpg/A14E
page 162http://i297.photobucket.com/albums/mm219/ddgonzal/162.jpg/A14E
page 163http://i297.photobucket.com/albums/mm219/ddgonzal/163.jpg/A14E
page 164http://i297.photobucket.com/albums/mm219/ddgonzal/164.jpg/A14E
page 165http://i297.photobucket.com/albums/mm219/ddgonzal/165.jpg/A14E
page 166http://i297.photobucket.com/albums/mm219/ddgonzal/166.jpg/A14E
page 167http://i297.photobucket.com/albums/mm219/ddgonzal/167.jpg/A14E
page 168http://i297.photobucket.com/albums/mm219/ddgonzal/168.jpg/A14E
page 169http://i297.photobucket.com/albums/mm219/ddgonzal/169.jpg/A14E
page 170http://i297.photobucket.com/albums/mm219/ddgonzal/170.jpg/A14E
page 171http://i297.photobucket.com/albums/mm219/ddgonzal/171.jpg/A14E
page 172http://i297.photobucket.com/albums/mm219/ddgonzal/172.jpg/A14E
page 173http://i297.photobucket.com/albums/mm219/ddgonzal/173.jpg/A14E
page 174http://i297.photobucket.com/albums/mm219/ddgonzal/174.jpg/A14E
page 175http://i297.photobucket.com/albums/mm219/ddgonzal/175.jpg/A14E
Memos
[pages 176-183 are blank "Memo" pages for taking notes]
page about publicationhttp://i297.photobucket.com/albums/mm219/ddgonzal/183.jpg/A14E
Back cover
