Instruments and Controls
Revision as of 23:58, 22 July 2016; view current revision
Category: Body
Instruments and Controls is a section in the Datsun 1200 Owners manual.
[hide]
Template:OwnersManual2x2
* Seat Belt Warning System North America models
* Speedometer
* Tachometer (OPTIONAL sedan/coupe)
1972 USA Owners manual (Page 09 ... ):
Seat Belt Lamp, Tachometer and Speedometer
Water Temperature Gauge
1972 USA Owners manual (Page 10 ... ):
If the pointer stays on the "H" side for more than two minutes, stop the vehicle and let the engine cool down, keeping it at 1,000 to 1,500 rpm.
"H" is past the large middle range (way over to right-side -- the H area).
Also see:
* Thermostat
* Temperature Gauge
Fuel Gauge
The fuel gauge is part of the Cluster Gauge
Also see: Fuel Sender
The position of the pointer will vary slightly during acceleration, braking and when the car is going up or down a hill.
Indicator/Warning Lights
Also see: Wiring
Ignition Warning Light
Glows red whenever the alternator is not supplying current
Oil Pressure Warning Light
Stop the engine immediately
Headlight Beam Indicator Light
The beam indicator glows whenever the high beams are being used
Brake System Warning Light
1972 USA Owners manual (Page 11 ... ):
Turn Signal Indicator Lights
Winkers
Switches
Also see: Wiring
Ignition Switch
Also see:
* Keys
* Locks
* Ignition Switch
1972 USA Owner's Manual (page 11):
ignition switch ... is integrated with the steering lock device
1974 Export Pickup Owner's Manual (pages 9,10):
(Optional)
The key can be inserted or withdrawn only when the switch is in the "GARAGE" or "LOCK" position. In the "GARAGE" position, however, the steering is not locked.
(3-position)
The "ON" position allows you to turn on the ignition system as well as all the other electrical circuits.
No mention is made of what the OFF position is for. Presumably its use is the same as the "GARAGE" position.
Notice that the standard 3-position type does not have an "ACC" position.
5-position switch vs 4-position switch:
Note addition of ACC position, which power Radio & Rear Defroster
Portugal market:
Interruptor de ignićāo [Ignition switch]
Desligado [OFF]
Ligado    [ON]
Arranque  [START]
Light Switches
Also see: Lighting Switch
Light Switch
When you pull the switch knob to the first of two positions, parking lights, taillights, license plate lights and instrument panel lights are turned on.
At the second position, the parking lights are still on and the headlight beams are lit, then if you push the turn signal lever switch forward, the headlight high beams will be turned on ... Pull the lever toward you, and it will be changed over to low beam.
The key takeaway here is that:
  • Knob in the 1st Position, NO HEADLIGHTS for US models
  • Knob in the 1st Position, LOW BEAMS work for other countries, including Japan-market
B120 1974 Export owner's manual
LIGHT SWITCH
The light switch clearance lights, parking lights, headlights, taillights, license plate light and instrument panel lights.
With the light switch knob pulled on, the following lights will be on.
1st position:
Clearance, parking, tail, license, instrument panel lights and then headlight low beams.
With the turn signal switch lever pulled up, the headlight low beams can be turned on.
2nd position:
Headlights and other lights
If you push the turn signal switch lever forward, the headlight high beams will be turned on.
INSTRUMENT PANEL LIGHT CONTROL (For Australia only)
The instrument panel light control is integral with light switch. The brightness of instrument panel lights can be adjusted by turn the light switch knob.
Turning the knob clockwise will darken the instrument panel lights.
Turn Signal Switch and High Beam Switch Lever
Hazard Warning Switch
th_13.jpg 1972 USA Owner's Manual
By pushing the tumbler switch, all the directional lights flash at the same time to warn other cars that some trouble happened in your car.
See main article: Hazards
Wiper and Washer Switch
th_12.jpg 1972 USA Owner's Manual
To operate the washer, turn clockwise and hold the knob for a moment, or until there is enough fluid on the glass to wash off the dirt. Do not operate the washer for more than thirty seconds continuously.
Also see:
* Wipers
* Washer
Horn
Also see: Horn
Sound the horn by depressing a horn button on either side of the steering wheel
Parking Brake Lever
Also See: Hand Brake
If the ignition switch is on when the parking brake lever is applied, the brake warning light will glow.
Heat Glass Switch
Heated rear (defrostable) window was Optional equipment.
See main article: Glass#Heated_Glass
The rear heat glass incorporates a printed heating element to prevent frosting or icing
