FJ engine swap
Revision as of 02:10, 13 March 2017; view current revision
Categories: Engine Modifications | Engine Swaps | Nissan Engines
The F20DET engine was basically a detuned race engine, a bit heavy but possibly Nissan's strongest ever engine. The stock engine can take massive boost and survive, while turning out incredible horsepower. Originally designed as the FJ24 for use in 240RS racing cars, it was in mass production as the FJ20 engine fitted to the DR30 Nissan Skyline. The FJ engine is very heavy at 366 lbs, heavier than the 318 lb Buick V8 3.5 liter engine. The FJ engine was produced in three variations: 1) FJ24E 2) FJ20E 3) FJ20ET.
For general information, see: http://fj20.com
The mighty FJ20E makes 148 HP from 2-liters, and with a turbo the FJ20ET makes up to 203 HP in stock form.
PRO12T
579.jpgAlbum 579
FJ20ET Turbo
400px-FJ20ET.jpgWIKI click for photo
Although it is heavier than a GM 3800 V6, the FJ fits somewhat better into a 1200's engine bay. It looks most excellent, doesn't it?
17207.jpgAlbum 17207
Sources
FJ Engine Source:
  • 1982-1983 Nissan Silvia BS110 '240RS' 240 HP, Works 275 HP
    400px-Nissan_Silvia_S110.jpgWIKI click for photo
  • 1983-1988 Nissan Silvia S12 FJ20E 150 PS, FJ20ET 190 PS, FJ20ET inter-cooled 205 PS
    400px-Nissan_200sx_SE.jpgWIKI click for photo
  • 1982-1985 Nissan Skyline DR30 '2000RS' FJ20E 110kw
    3322.jpgAlbum 3322
  • 1983-1984 Nissan Skyline DR30 '2000RS Turbo' or 'RS-X Turbo' FJ20ET 140kw
  • 1984-1985 Nissan Skyline DR30 'RS-X Turbo C' FJ20E 151 kw
    400px-LD4C4288.jpgWIKI click for photo 400px-LD4C4250.jpgWIKI click for photo
Which is better? FJ20 or SR20?
Both:
  • make about the same HP in stock form (SR20DE 140-169HP, F20E 148 HP)
  • In turbo versions, both are too large for as 1200 (too large for normal engineering process) in Australian. In this country, the CA18DET is better than SR20DET or FJ20ET for street cars.
FJ20DET
  • In stock condition, can take more boost than SR20DET, thus more HP without opening the engine up
SR20
  • Much lighter, so won't be as detrimental to handling
  • More were produced, so prices are lower
Build-Ups
  • FJ20 has all the usual build-up parts, same as SR20. However as less FJs were produced, so too the market for FJ parts is more expensive than SR parts.
FJ-powered 1200s
34 PSI
34 PSI
FJ1200
Santo Di Pietro's ute out of New South Wales with FJ power.
Fast Fours November 2014
26601.jpgAlbum 26601 26600.jpgAlbum click to view
Hot4s 257
Hot4s-257-2b.jpg 26540.jpgAlbum click to view 26541.jpgAlbum click to view
Sandy's fj1200
22627.jpgAlbum 22627 22890.jpgAlbum 22890 22628.jpgAlbum click to view 22629.jpgAlbum click to view 22630.jpgAlbum click to view 22626.jpgAlbum click to view 18032.jpgAlbum click to view 17521.jpgAlbum click to view 17520.jpgAlbum click to view 17519.jpgAlbum click to view 17518.jpgAlbum click to view 17426.jpgAlbum click to view 17423.jpgAlbum click to view 17242.jpgAlbum click to view 17241.jpgAlbum click to view 17240.jpgAlbum click to view 17239.jpgAlbum click to view 13921.jpgAlbum click to view 13911.jpgAlbum click to view 10750.jpgAlbum click to view 10749.jpgAlbum click to view 10748.jpgAlbum click to view 10747.jpgAlbum click to view 10746.jpgAlbum click to view 10745.jpgAlbum click to view 10744.jpgAlbum click to view
FJ1200
24235.jpgAlbum click to view 24234.jpgAlbum click to view 24233.jpgAlbum click to view 22891.jpgAlbum click to view 22890.jpgAlbum click to view 22889.jpgAlbum click to view 22888.jpgAlbum click to view
HYP014
14630.jpgAlbum 14630 14636.jpgAlbum 14636 14634.jpgAlbum click to view 14629.jpgAlbum click to view 14628.jpgAlbum click to view 14631.jpgAlbum click to view 14632.jpgAlbum click to view
Joshh
Main forum: Joshh's FJ20et 1200 ute
FJ2020 on Simmons FR
FJ2020 on Convo rims
post-21145-1224492028870042089.jpg post-21145-12244926481162724260.jpg post-21145-1224492236759208526.jpg post-21145-122449203635452681.jpg post-21145-12244920306959542.jpg
Montery Park
See Main Article: Monterey Park
Stanek
Paul Stanek's IPC Turbo Charging B110 Coupe
SuPeR
SuPeR's ute
TIG20T
See Main Article: TIG20T
TUF120
TUF120
post-209-1229235530122510236.jpg post-41355-1235745893325587072.jpg post-209-12292354781993449952.jpg
YAQ70Z
YAQ70Z
5976.jpgAlbum 5976 5827.gifAlbum 5827 5828.gifAlbum 5828
FJ-powered B210
Sleeper 120Y spotted at 2005 South Coast Nationals
Sleeper.jpgPost click for topic Sleeper1.jpgPost click for topic SleeperDatto.jpgPost click for topic
FJ-powered B210: Y Be Normal! -Datsun 120y (As Featured in Hot 4's No.27 FJ20.com
510 Swaps
11120_49e67a0ff2d8a.jpgUpload click to view 11120_49e67a195c1f0.jpgUpload click to view 11120_49e67a2307c39.jpgUpload click to view 11120_49e67a2bc1a65.jpgUpload click to view 11120_49e67a344a000.jpgUpload click to view 11120_49e67a8cd5acd.jpgUpload click to view 11120_49e67a9a45c60.jpgUpload click to view 11120_49e67b447298f.jpgUpload click to view 11120_49e67f66cde6a.jpgUpload click to view 11120_49e67f87add4d.jpgUpload click to view
Swap Notes
Distributor
The FJ distributor uses Nissan Optical CAS for EFI computer signaling. See FJ CAS.
If converting to carbureted, use a standard distributor. The distributor from a Datsun A12 engine fits into the FJ20 engine block, but you need to change drive gear from A12 to FJ20 drive gear.
If the distributor is missing, use an A12 Datsun or Austin mini distributor. An A12 electronic ignition distributor is preferred so you can use the output to an aftermarket ECU.
22100 DISTRIBUTOR ASSY
R30 (8108-9003) FJ20E & FJ20T
22100-R2000 8110-8206 ハーネス L=410 MM [FJ20E only]
22100-R2007 8206-8308 ハーネス L=580 MM マイナー マ デ
22100-R2001 8308-8601 Hitachi マイナ ゴ センヨウ
22100-R2002 8601-8612 Hitachi
22100-R2003 8612-9003 Hitachi
22100-R2007 DR7 type
FJ20 timing plate
578.jpg 579.jpg 580.jpg 1082.jpeg 1168.jpg 1197.jpg 1198.jpg 1199.jpg 1210.jpg 1342.jpg 1343.jpg 1344.jpg 2044.jpg 2045.jpg 2046.jpg 2047.jpg 2048.jpg 2234.jpg 2509.jpg 2510.jpg 2514.jpg 2699.jpg 2910.jpg 2911.jpg 2932.jpg 2987.jpg 3108.jpg 3109.jpg 3277.jpg 3322.jpg 3448.jpg
th_3450.jpgAlbum click to view
th_3451.jpgAlbum click to view 3497.jpg 3498.jpg 3932.jpg 3933.jpg 4114.jpg 4117.jpg 4186.jpg 4187.jpg 4188.jpg 4189.jpg 4678.jpg 4895.jpg 5326.jpg 5328.jpg 5471.jpg 5976.jpg 5981.jpg 6577.jpg 6779.jpg 6915.jpg 7550.jpg 8154.jpg 8155.jpg 8156.jpg 8157.jpg 8158.jpg 8159.jpg 9398.jpg 9449.jpg 9464.jpg 9937.jpg 9938.jpg 9939.jpg 9940.jpg 9941.jpg 10744.jpg 10746.jpg 10747.jpg 10748.jpg 10749.jpg 10750.jpg 12537.jpg 12538.jpg 13081.jpg 13082.jpg 13083.jpg 13084.jpg 13243.jpg 13244.jpg 14628.jpg 14629.jpg 14630.jpg 14937.jpg 14938.jpg 15108.jpg 15109.jpg 16136.jpg 17207.jpg 17208.jpg 17649.jpg 17944.jpg 18332.jpg 21542.jpg 22626.jpg 22627.jpg 22628.jpg 22629.jpg 22630.jpg 22888.jpg 22889.jpg 22890.jpg 22891.jpg 22901.jpg 22902.jpg 23041.jpg
