Bluebird
Revision as of 21:19, 16 June 2018; view current revision
Category: Nissan Vehicles
Bluebird is Nissan's C-class (compact) model family, which grew out of the original Datson (DAT Light Car) model, the Datson Type 10 of 1931. For additional details, see History. Bluebird family includes the 210/310/410/510/610/810/910 model series -- but not the 710 which was of the Violet family.
[hide]
The Bluebird is of direct lineage to the original Datson Light Car
The first Datsun to be called Bluebird was the 210 model series, apparently during mid-run.
  • 1957-1959 210 Datsun 1000/Datsun Bluebird 1000
  • 1959-1963 310/311/312 Datsun Bluebird/1000/1200
  • 1963-1967 410/411 Datsun Bluebird/410/411
  • 1967-1973 510 Datsun Bluebird/510/1600,1300,1400
  • 1973-1976 610 Datsun Bluebird/610/180B
  • 1976-1979 810 Datsun Bluebird/810/180B/200B
  • 1980-1983 910 Datsun/Nissan Bluebird/810/Maxima (to 1986 in Australia)
  • 1983 switch to FWD starting with U11 model series Bluebird/Maxima
Bluebirds often feature Independent rear suspension (IRS) starting with the 510 series. 510 wagons are a notable exception, although export 510 sedans may also may have a live axle.
Later 6-cylinder-equipped Bluebirds, starting with the G610 and the G810 -- stretched models -- may be considered D-class (mid-size) cars. At the same time the base 610 and 810 were shorter cars.
1958 210 number plate light with 'ダットサン' script ('DATSUN')
mkauk09-img600x398-13082772687xupjf86341.jpg mkauk09-img600x398-1308277268vsnjiz86341.jpg mkauk09-img600x398-1308277269khjvs586341.jpg
1958 Datsun 116 ID Plate - 27hp!
310
Datsun Bluebird 310 was a car similar in size to the B110, although being full-framed was heavier at 2000 pounds. The wheelbase of the B110 is 20mm longer.
310 Sedan | WP312 wagon
400px-Datsun_Bluebird_1200_Deluxe_rear.jpgWIKI go to Wikipedia 340px-1963_Datsun_Bluebird_%28WP312%29_Special_station_wagon_%2820895999998%29.jpgWIKI go to Wikipedia
Datsun Model Series 310
  310 1959-1960 Bluebird 1000 37hp 7.5:1 compression
 P310           Bluebird 1200 48hp 7.5:1 compression
WP310 6007      Bluebird 1200 wagon
  311 6011-6108 Bluebird 1000 45hp 8.0:1 compression
 P311           Bluebird 1200 60hp 8.2:1 compression
  312 6208-6309 Bluebird 1200
      6209        grille revised
  312 1962-1963 Saenara Bluebird
  312 1963-1966 Shinjin Shinsungho
      1963-1964 Yue Loong Bluebird 704
P models (P310/PL310) were powered by the premium E1 engine (1189 cc "1200").
310 Indicators are separate from grille
19015.jpgAlbum 19015 19016.jpgAlbum 19016
311 Upgrade of the E1 engine to 60hp & full syncromesh.
312 Indicators are wrapped by grille
20364.jpgAlbum 20364 20365.jpgAlbum 20365
312 minor change - larger taillights, wider grille, upright instrument panel
Early 312 with blocky grille
13951_4c81bde905db2.jpgPost click for topic 13951_4c81bdc888fe5.jpgPost click for topic 13951_4c81bdd8179f9.jpgPost click for topic 7935.jpgAlbum 7935 10412.jpgAlbum 10412 10411.jpgAlbum 10411 11392.jpgAlbum 11392 11393.jpgAlbum 11393 11394.jpgAlbum 11394 11395.jpgAlbum 11395 11396.jpgAlbum 11396 11397.jpgAlbum 11397 11398.jpgAlbum 11398
Late 312 with Refined grille
8237.jpgAlbum 8237 11430.jpgAlbum 1143019841.jpgAlbum 19841 19842.jpgAlbum 19842 3304_58bb4b9ac9aef.jpgPost click for topic 3304_58bb4ba7b040a.jpgPost click for topic 3304_58bb4bb409c36.jpgPost click for topic 3304_58bb4bc7f391f.jpgPost click for topic
410/411
410 - The first unibody Datsun. Previous series used body-on-frame construction. And the first to be larger than B110 (410 wheelbase was 80mm longer than B110 wheelbase).
* 410: 1964-1965
* 411: 1966-1967
411
9071.jpgAlbum 9071 5821.jpgAlbum 5821
 410 = C1 engine (998cc)
P410 = E1 engine (1189cc)
P411 = J13 engine
R411 = R16 engine
410 - Round Emblem, bold grille
12064.jpgAlbum 12064 12065.jpgAlbum 12065 12066.jpgAlbum 12066 12067.jpgAlbum 12067 12068.jpgAlbum 12068 12069.jpgAlbum 12069 13744.jpgAlbum 13744
411 minor change - rectangle emblem, fine grille
7245.jpgAlbum 7245 11022.jpgAlbum 11022 11023.jpgAlbum 11023 23937.jpgAlbum 23937 11705.jpgAlbum 11705 16822.jpgAlbum 16822 10994_49f94ac35f0ce.jpgPost click for topic 16823.jpgAlbum 16823 17443_5240f78b4cab1.jpgPost 444789
 SS = 410 with E1 (1200) Twin Carb
      411 with J13 Twin Carb
SSS = 411 with R16 Twin Carb
174_5796cceb2fdc3.jpgPost 480140 174_5796ccd43a2f0.jpgPost 480140 Datsun%20SSS%20badge_.jpg Datsun%20SSS%20emblem.jpg
 S  = Standard
 D  = Deluxe
 F  = Fancy
 N  = automatic clutch
W-  = Wagon
L-  = left hand drive
 -L = handling package?
 -R = 2-door sedan
 -U = export
SS   = Sport Sedan
SS-R = 2-dr Sport Sedan
410 JAPAN Carburetors
C1 = 2-bbl carb
E1 = 2-bbl Hitachi DAB-308-7
E1 = 2-bbl Nikki 2D-30CE <> 2D-30CE-2 Pedal clutch
E1 = 2-bbl Nikki Pedal clutch
E1 = 2-bbl Nikki 2D-30CF <> 2D-30CF-2 Automatic clutch
-K = SS = Twin Carburetor Hitachi HJE38W-1
510
1967-1972 Datsun Bluebird (model series 510)
Also see: 510 Parts Donor
Datsun model series 510 was marketed in Japan as the Bluebird, in America as the 510 and in some countries as 1300/1400/1600 depending on engine (L13, L14 or L16).
JDM Datsun Bluebird
 510 1300 L13 engine
N510 1400 L14 engine
P510 1600 L16 engine
H510 1800 L18 engine
 510  4-door Sedan
 510R 2-door Sedan
K510  2-door Coupe (semi-fastback design)
V510  4-door Van (Wagon)
2-door Sedan vs 2-door Coupe
10135_50344321a1ed4.jpgPost 416008
Coupe - fastback 2-door
3989.jpgAlbum 3989 4063.jpgAlbum click to view 12059.jpgAlbum click to view 16063_502d91231ffd1.jpgPost 415626 16063_502d912ca96b5.jpgPost 415626 16063_502d913e713d6.jpgPost 415626
2-door Sedan - Notchback 2-door
1072.JPGAlbum 1072 2219.jpgAlbum click to view 1200.jpgAlbum click to view 4014.jpgAlbum click to view 4015.jpgAlbum click to view 9398.jpgAlbum click to view 13464.jpgAlbum click to view 6529.jpgAlbum click to view 6906.jpgAlbum click to view
4-door Sedans
2790.jpgAlbum 2790 859.jpgAlbum click to view 1043.jpgAlbum click to view 1044.jpgAlbum click to view 2787.jpgAlbum click to view 2789.jpgAlbum click to view 2790.jpgAlbum click to view 2791.jpgAlbum click to view 2793.jpgAlbum click to view 2866.jpgAlbum click to view 3509.jpgAlbum click to view 3797.jpgAlbum click to view
CA18-powered 510
16442.jpgAlbum click to view 16443.jpgAlbum click to view 16444.jpgAlbum click to view 16445.jpgAlbum click to view
Wagon
4964.jpegAlbum 4964 11120_49d951dc586d9.jpgPost click for topic 11120_49d951e490997.jpgPost click for topic 11120_49da8b65a0c5d.jpgPost click for topic 11120_49da8b6fe9c16.jpgPost click for topic
One-off custom 510 Coupe Utility
11120_49d951bd56bba.jpgPost 249936 11120_49d951c88cb93.jpgPost click for topic 11120_49d951ec4034d.jpgPost click for topic
Late interior | L16
1075.jpgAlbum 1075 1074.jpgAlbum 1074
RED DEVIL Stamm-mobile with 15" Simmons V4 wheels
10457.jpgAlbum 10457 10459.jpgAlbum 10459 10458.jpgAlbum 10458
610
The Datsun 610 was the Bluebird model for the 1973-1977 Model years
See Main Article: 610
It was marketed in various countries as:
  • "Datsun 610" (USA)
  • "Datsun Bluebird-U" (Japan)
  • "Datsun 160B" or "Datsun 180B" depending on engine size
Coupe, Sedan, Wagon
810
Datsun model series 810 was produced 1976-1979. In some countries it was marketed as "Bluebird", in others as "200B" or "180B" or "160B" depending on the engine fitted. Not the same as the 1980-1984 Datsun 810 north america, which is actually model series 910.
Japan         1976-1979 "Bluebird"
North America 1977-1979 "810" and "Maxima"
Australia     1977-1982 "200B"
200B with swapped in FJ20T engine
3796.jpgAlbum 3796
  810 Bluebird 1600
 P810 Bluebird 1800/180B
RG810 Bluebird 2000 G6 L20 six cylinder
HG810 810 L24E engine
Australia "200B" L20B four cylinder
* in GL, SX and GX trim
USA 810/Maxima with L20 six cylinder
810 180B (with swapped-in FJ20 engine)
8157.jpgAlbum 8157 8156.jpgAlbum click to view 8158.jpgAlbum click to view
810 200B
8150.jpgAlbum 8150 8149.jpgAlbum click to view 8151.jpgAlbum click to view 12484.jpgAlbum click to view 12486.jpgAlbum click to view
810 200B SSS
1216.jpgAlbum 1216 1222.jpgAlbum click to view 19674.jpgAlbum click to view 19680.jpgAlbum click to view
early 810 Bluebird script emblem
910
1980-1986 (Australia)
10460.jpgAlbum 10460 9803.jpgAlbum 9803
SSS
13995.jpgAlbum 13995
With Z18ET (Japan):
4979.jpgAlbum 4979 7099.jpgAlbum 7099 7097.jpgAlbum 7097 7098.jpgAlbum click to view
Australia: Bluebird Series I/II 1981-1984 (L20B engine, no IRS, H165)
* Difference between series I and II is most black rubber bumper trim
Bluebird TRX with L20B engine.
* Trim: front air dam, alloy wheels, a small rear spoiler, internal reading lights.etc.
* Rear disc brakes and 15" alloy wheels
3276.jpgAlbum 3276
Australia: Bluebird Series III/Bluebird TRX 1985-1986 with CA20S engine
10072.jpgAlbum 10072 19549.jpgAlbum 19549 6463.jpgAlbum 6463
910 Europe RHD
L16S
L18S
L18T
Z20E
LD20
18227.jpgAlbum 18227 13933_4c9200c2ad441.jpgPost 337291 9641_4a55aac663fc4.jpgPost 262110 9641_4a55b1aa41f08.jpgPost 262122 9641_4a55b21610c3b.jpgPost 262122 16836.jpgAlbum 16836
1979 910 BLUEBIRD JAPAN
13x4.5J+40 - non-SSS
14x5J+40   - all SSS models
14x4.5JJ+35 alloy OPTION P910/Y910
Y910   Z20E
P910   Z18E
PJ910  Z18S/Z18P
J910   Z16S
CT     Z16S.F4
DX     Z16S.FR
GL	Z16S.F4
FANCY GL S.Z18S.AT
GF     Z16S.F4, HT.Z18S.F4, S.Z18S.F4/MT
SSS    Z18S (single carburetor),F4/F5/AT
SSS-E  Z18E (EGI fuel injection),F4/F5/AT
SSS-EL Z20E F5/AT
SSS-ES Z20E F5
SSS-EX Z20E F5/AT
SSS-EX G-type Z20E F5/AT
LPG GL/DX/STD S.Z18P.R3W65L/AT
1980 910 BLUEBIRD JAPAN
Y910   Z20E
P910   Z18E/Z18ET
PJ910  Z18S/Z18P
J910   Z16S
EJ910  LD20
WPJ910 AD WAGON Z18S
VTJ910 VAN L16S
VEJ910 VAN LD20
J = LIVE AXLE
Z18ET 135PS@6000rpm, 2.0kg-m@3600RPM
