Datsun 1200s come in 2-door, 3-door, 4-door and 5-door models.
Also see: Glass including window winders and regulators
Comparisons
Long Short
2-door Coupe | Wagon
2-door Sedan | 4-door Sedan
| Ute
Tall Frame | Short Frame ---------------------------- 2-door Sedan | 2-door Coupe ----------------------------
Coupe Window Frame is shorter than Sedan:
Front Doors
Same front doors are use by 4-door sedan, 4-dr van and Truck
2-door sedan and Coupe use long doors. The bodies are nearly the same, but the window frames are different.
2-dr Coupe and 2-dr Sedan door stampings are the same, but the door window frame differs. These photos of coupe doors test-fitted to a sedan so vividly illustrate the difference, which is about 3 cm in height.
Further, coupe and 2-door Door Card varies.
The 2-door inside metal is finished (here in black paint) and uses a mini door card
The 2-door coupe door-top is completely covered by the fabric door card
Rear Doors
4-dr Sedan and 4-dr Van use different doors with differently-shaped glass.
4-door
Four door models include the 4-dr Sedan and 5-dr wagon.
The lower part of the doors are identical 4-door Sedan to 4-door Wagon.
2-door
Datsun 1200 2-door models include Sedan, Coupe, 2-dr wagon, and pickup versions.
- 2-door Sedan and 2-door coupe are long doors (same door bottom, different glass frames)
- 2-door wagon and Pickup use short doors (of 4-door sedan type)
Fiberglass
- ProdBodies formerly Japco - fibreglas hood, fenders, flares, door, trunk, spoiler, air dam
Door Panels
Also see main article: Door Cards![]()
82152-H1000, rear 4-door panel a.k.a. skin
2-door skin being welded to door
Escutcheons
The chrome escutcheon is located behind the interior door latch handle. Right and left vary, in the location where the fitting screw hole is drilled, as well as where the rubber anti-rattle nub is fitted.
- 80510-H1000 ESCUTCHEON-REMOTE CONTROL RH NLA
- 80511-H1000 ESCUTCHEON-REMOTE CONTROL LH NLA
Exterior Handles
As you pull up on the door handle, it raises the latch rod. The rod snaps into the plastic 'holder' bushing.
82605-H1000 ASS'Y-HANDLE, door outside FRONT,REAR (R.H.) 82606-H1000 ASS'Y-HANDLE, door outside FRONT,REAR (L.H.) 80605-H1901 ASSY-HANDLE DOOR OUT SIDE FRONT RH $11.83 USD 80606-H1901 ASSY-HANDLE DOOR OUT SIDE FRONT LH $11.78 USD
24220-H6200 HOLDER-OUTSIDE HANDLE [E-clip] > 84371-H1000 [push-clip]
80608-H1000 ASSY-ROD OUT SIDE HANDLE (?same part used for rear doors?)
This one has the original simpler type of nylon rod holder.
Interior Handles
Arm Rests
80940-H1100 B110 COMP-ARM REST BLACK #766 $36.65 USD * also used by * B210 Front and Rear doors * 620 USA OPTION to 0678, standard equipment from 0778 80940-B9501 620 (BROWN) OPTION to 0678, standard equipment from 0778 USA 80940-B9700 620 (BLUE) OPTION to 0678, standard equipment from 0778 USA
May fit: 80691-A0800 510 DX black with chrome strip
Pull Handles
B110 STD interior handle 'door pulls'
80960-H1001 HANDLE-PULL FRONT & REAR
* B110 STD (Deluxe came with armrests)
* 620 USA standard equipment to 0678
* 521 USA from Jul 1969
* B210 JDM sedan & van, 2-dr & 4-dr, front and rear doors
* KHC120 "Vanette" 8003-8210 HANDLE,PULL FRONT DOOR
80960-H1000 HANDLE-PULL (early version with M5 screws)
B310 STD door pulls 80960-H8800 HANDLE-PULL(BLACK) 80960-H8500 HANDLE-PULL(BROWN) to 0779 80960-03W01 HANDLE-PULL(BROWN) from 0879
B310 DX armrests (front doors) 80940-W5000 ARMREST ASSY-DOOR (BLACK 021G0) 80940-H9100 ARMREST ASSY-DOOR (BLUE 021B16) to 0779 80940-H9101 ARMREST ASSY-DOOR (BLUE 021B27) from 0879 80940-H8500 ARMREST ASSY-DOOR (BROWN 021C3) to 0779 80940-01W01 ARMREST ASSY-DOOR (BROWN 021C5) from 0879
Above Door Fittings
73940-H1101 B110 ASSY-RAIL ASSIST, also 620 OPTION * From 0778 620 OPTION 73940-B9800
Japan models: 73940-H1101 ASSY-RAIL ASSIST (for rear) (2) Coupe, Sedan ex. STD * also used by 620 Truck * Driver's standard, Passenger OPTION 73940-H3200 ASSY-RAIL ASSIST (for front) (1) Coupe, Sedan ex. STD
B210 73940-H5000 B210 ASSY-ASSIST GRIP (GRAY, VK-204)OPTION 96750-H5000 B210 HANGER-COAT (GRAY,#1618)
B310 above-door pull strap & coat hooks
73940-H8501, 73940-W5800 (various) ASSIST GRIP ASSY
96750-H8500 (various) HANGER-COAT
Latch
It seems the latches is identical between 2-dr sedan, 4-dr sedan and Coupe. But there are right and left-hand parts.
Also see: Front Door Fitting Part Numbers
Door Lock Assembly
The L-shaped rod on the left of this photo is to the Lock Cylinder. If turning the Key won't move the knob far enough to lock or unlock, trying bending this rod
The other rod (which goes straight up) is to the interior Lock pull Knob
Lock Knob
- 80595-21003 KNOB-DOOR LOCK [black]
- 80595-N1600 KNOB-DOOR LOCK replaces 80595-21003
- From 1972 510 line
B210 has wedge shaped knobs
Interior Lock Knob Grommet
ドアロックノブ グロメット
Lock Cylinder
See Locks
Parts
The B120 diagram here is almost identical to the Coupe, except that the insulator (80504F) is not used on the other models. The part numbers are mostly the same as Coupe, except for the latch and striker.
Coupe and 2-dr Sedan latch parts are identical.
4-dr sedan parts are mostly different, but the latch itself, escutcheon, and inside door handle (remote control) is the same on front doors. The striker and door handle are different.
80760-H1000 ASSY-HANDLE DOOR WINDOW REGULATOR $24.00 USD 80502-H3600 ASSY-DOOR LOCK FRONT RH $128.10 USD 80503-H3600 ASSY-DOOR LOCK FRONT LH NLA
Hinges
See Door Hinge
Hinge Repair
See Door Hinge
Rubber
80886-H1000 Rubber - Door cover RH 80887-H1000 Rubber - Door cover LH 80834-H1000 Spacer - Weatherstrip spacer, front door RH 80835-H1000 Spacer - Weatherstrip spacer, front door LH
Drain Plugs
These drain plugs fit all Datsun 510, 1200, 620, and 280ZX. The plugs fit on the underside of the doors (2 per door). They help prevent rust by letting water out, and keeping mud from coming in.
Weatherstrip
Door weatherstripping is same material (possible same shape/length) as 510.
- 80830-H1001 WEATHERSTRIP ASS'Y-front door (R.H.) 4 door
- 80831-H1001 WEATHERSTRIP ASS'Y-front door (R.H.) 4 door
- 80830-H1202 WEATHERSTRIP ASS'Y-front door (R.H.) 2-dr Sedan, Coupe $58.90 USD
- 80831-H1202 WEATHERSTRIP ASS'Y-front door (R.H.) 2-dr Sedan, Coupe $59.90 USD
- 80836-H1000 WEATHERSTRIP ASS'Y-door inside (R.H.) 4 door
- 80837-H1000 WEATHERSTRIP ASS'Y-door inside (L.H.) 4 door
- 80836-H1200 WEATHERSTRIP ASS'Y-door inside (R.H.) 2-dr Sedan, Coupe, Coupe (L.H.) $7.53 USD
- 80837-H1200 WEATHERSTRIP ASS'Y-door inside (L.H.) 2-dr Sedan $7.53 USD
2-door Sedan
80830-H1202 ASSY-WEATERSTRIP FRONT DOOR RH (from '70-Jul.)
* 80830-H1200 ASSY-WEATHERSTRIP FRONT DOOR RH
80831-H1200 ASSY-WEATHERSTRIP FRONT DOORLH (from '70-Jul.)
* 80831-H1202 ASSY-WEATHERSTRIP FRONT DOOR LH
80834-H1000 SPACER-WEATHERSTRIP FRONT DOOR RH
80835-H1000 SPACER-WEATHERSTRIP FRONT DOOR LH
80820-H3600 ASSY-MOULDING FRONT DOOR OUTER RH $41.33 USD
* replaced 80820-H1200 ASSY-MOULDING FRONT DOOR OUTER RH
80821-H3600 ASSY-MOULDING FRONT DOOR OUTER LH $46.18 USD
* replaced 80821-H1200 ASSY-MOULDING FRONT DOOR OUTER LH
80825-H1000 CLIP-MOULDING DOOR OUTER
80836-H1200 WEATHERSTRIP-FRONT DOOR INSIDE RH
80837-H1200 WEATHERSTRIP-FRONT DOOR INSIDE LH
ドア ウェザー ストリップ ドア インサイド モール ガラスウエザーストリップ
Door Bumper
Also see: Fuel Door Bumper
All 1200 doors have one of these so when you slam the door, it softly stops it.
80832-H1000 RUBBER-BUMPER FRONT DOOR
Scissor Doors
"Lambo" style doors on Datsun 1200.
See main article: Flip-up Doors
