B310 Dash
Revision as of 22:21, 3 May 2019; view current revision
Category: Datsun B310
Datsun B310 dashboard had round gauges, and later changed for 80s fashion.
Early: Individual pods for gauges of instrument panel
Late: Single large opening for instrument panel
Early Style for all Round Headlight models (1977-1979)
Late Style for Square Headlight models (1980-1982)
Early
All round headlight models used a wide driver's "cockpit" that encompassed the radio and center vents. This was 1977-1980.5 + all JDM VB310 van.
2+4 dash: Two large central gauges flanked by four small
2+2 dash: Two large central gauges flanked by two small
LHD used a 2+2 "flat" dash for all models
SGX-E 2+4 dash
NOTE: LHD has the two side pods reversed
Small Left: single: clock mask
            double: Fuel/Temp (Coupe GX)
Large Center Gauges
* Left: Speedometer
* Right is one of:
         Water/Fuel (sedan)
         Blank with idiot lamps
         Econometer (coupe A14.GL)
         Tachometer (coupe GX)
Small Right:
* Single: Water/Fuel with idiot lights (oil/brake)
* Double: stacked Volt/Amp (coupe GX)
#Van - 2+2
GL - 2+2
GXE - 2+4
SGX - 2+4
See: #Cluster Lid
Europe
Malta
16083.jpgAlbum 16083
Datsun 140Y wagon - Romania
7023.jpgAlbum 7023
Japan California
Sunny California (wagon)
0205239A30150423W00113.jpg 0205239A30150423W00114.jpg 0205239A30150423W00115.jpg
Taiwan
Yulon#302
174_5c0b7264d0a82.jpgPost 490113
Van
Australia
20461.jpgAlbum 20461 20462.jpgAlbum 20462 20460.jpgAlbum 20460 20459.jpgAlbum 20459 20458.jpgAlbum 20458
USA Coupe
20121107_131954_DSC04458.jpg 20121107_132103_DSC04468.jpg 20121107_132031_DSC04463.jpg 20121107_132057_DSC04467.jpg 20121107_132045_DSC04465.jpg 20121107_132051_DSC04466.jpg 20121107_132305_DSC04472.jpg 20121107_132027_DSC04462.jpg
USA Sedan
large speedometer flanked by OPTION tachometer
To left of speedometer is smaller temp/water gauge
Small left side round pod is Clock Blank
Tachometer blank with idiot lamps (Oil/Amps)
Datsun-B210-46.jpg Datsun-B210-48.jpg Datsun-B210-49.jpg Datsun-B210-50.jpg Datsun-B210-54.jpg
10761.jpgAlbum 10761
Tachometer
Tachometer Yellow Zone
* Carburetor 6000-6250
* EGI        6400-6800
GX-E
TACHOMETER ASSY
24855-H8700 *K.(DX+GL) -7811
24855-H8701 *K.(DX+GL) 7812- CLEAR LAMP
24855-H9200 (S+K).GX
24855-H9201 (S+K).A14E
Clock
Clock is on the side of the dash towards center of car.
LHD: Clock on right side of dash
RHD: Clock on left side of dash
GX: Clock in center stack (above radio)
2+4 dash: CENTER STACK CLOCK, sealed shield
2+2 dash: left-side CLUSTER CLOCK, clear shield
GX,DX,GL analog
SGL, SGX digital
CLOCK K,S.SGX
27380-H9210 DIGITAL QUARTZ LUMINOUS SPORT INST -7804
27380-H9211 DIGITAL QUARTZ LUMINOUS SPORT INST -7805-7909
SGX for dash center stack
RHD: Left Clock (digital)
RHD: Left Clock (analog)
Econometer
Econometer (per Datsun catalog) was called Economonitor in Australia and ECONO MONITOR エコノモニター in Japan (aka Econo Meter/エコノメーター).
174_5c10d1413b248.jpgPost 490146
Warning Lamp Assembly
Warning Lamp grid of four or six lamps is adjacent to the door.
LHD: grid on left side of dash
RHD: grid on right side of dash
rectangular grid cluster
variations
FUEL DOOR
BRAKE TEMP
BRAKE TEMP FUEL DOOR
FUEL DOOR TAIL STOP
BRAKE TEMP FUEL DOOR TAIL STOP
SGX: all six icons
26597 LAMP ASSY-EXHAUST TEMPERATURE
25040-H8700 BRAKE
      H8760 BRAKE FUEL DOOR TAIL STOP
      H9200 BRAKE FUEL DOOR
26599 LAMP ASSY-WARNING FUEL
25040-H8560 DOOR TAIL STOP
      H8561 DOOR
Late
1980-1982 switched to a smaller driver's "cockpit" that included just the instrument panel -- the radio and center vents were outside of this area. Japan vans stayed with the early style.
H85 single side gauges
    Speedometer + Idiot Lamps S,W except SGX
    Speedometer + Tachometer Coupe except SGX
H92 double side gauges S,K.SGX
2+4 cluster SGX
2+2 cluster Wagon/Sedan (except SGX)
210 (North America)
Yulon 303
Sedan/Wagon
SEDAN/WAGON GAUGES (except SGX)
  Round or Digital Clock (or 'NISSAN' clock mask)
Speedometer
Large Fuel/Temperature
 Idiot Lamp
NO tachometer option
Idiot Lamps (Large Fuel/Temperature)
* 'CHG' with BATTERY symbol
* OIL symbol
Idiot Lamp (Small pod) two variations
* H85 S,W.GL#,DX# BRAKE
or
* H92 S.GX CHG
2x2 cluster (2 large, 2 small)
With Digital Clock
With Analog Clock
Coupe
COUPE GAUGES (except SGX)
 Round Clock (or 'NISSAN' clock mask)
Speedometer
Tachometer
 Small Fuel/Temperature
Idiot Lamp BATTERY (bottom of tachometer)
digital clock | analog clock
SGX
SGX/SGX-E GAUGES
 Digital Quartz Clock
 Fuel
Speedometer (160kph)
Tachometer
 Oil Pressure
 Water Temperature
Idiot Lamp BATTERY symbol (bottom of tachometer)
MASKED: Idiot Lamp Meter strip (bottom of cluster)
SGX-E 6800 RPM tachometer for EGI
Monitor Lamp Strip
Six variations, including two blank strips.
Masks are placed at bottom of cluster (where photo is labeled "Delete Plate")
Inspection Monitor Lamp strip 25040-H8563?
SGX with full Monitor Lamps (all six icons)
68450-H8501 MASK 7910- CT,S.DX,SPT,ES+W.DX, SGX
25040-xxxxx LAMP ASSY [six variations]
      H8500 EXH TEMP,BRAKE,FUEL
      H8562 FUEL,DOOR
      H8761 EXH TEMP,BRAKE,FUEL,DOOR,TAIL,STOP
      H9201 EXH TEMP,BRAKE,FUEL,DOOR
      H8563 FUEL,DOOR,TAIL,STOP
      H8611 CT/DX [blank]
      H8761 SGX [blank]
      USA   BRAKE
Tachometer
All Coupe and Sedan.SGX get a tachometer. There is no room for tachometer on Wagon, Van or regular Sedan dash.
H90 dual idiot lights at bottom
H92 single idiot light at bottom
TACHOMETER ASSY
24855-H9020 K-(K.SGX#,K.RSE),W.GX
24855-H9021 K.RSE,S.GXE
24855-H9215 (4S+K).SGX  [std redline]
24855-H9216 (4S+K).SGXE [EFI redline]
LENS 68435
25021-H9020 K-SGX# S.(GX#+SGL) OIL,BATTERY
25026-H8503 S,W.GL#,DX. BRAKE
25026-H9215 S.GX        CHG
Cluster Lid
Early - individal gauge lenses
Late  - one big opening for all gauges
H850 DX
H851 Late Model
H856 GL
H86  CITY + DX.WAGON
H92  GX
H94  Van STD late
CLUSTER LID
68420-H8500 DX BLACK
68420-H8501 DX BROWN
68420-H8510 7910- BLACK
68420-H8511 7910- BROWN
68420-H8560 GL BLACK
68420-H8561 GL BROWN
68420-H8600 CT BLACK W.DX
68420-H8601 CT BROWN W.DX
68420-H9200 GX# BLACK
68420-H9201 GX# BROWN
68420-H9400 BROWN
            7812- V.STD
            8011- V.A12.STD
            8110- V.A12.DXA
68420-H9460 8011- BLACK V.A12.STD,DXA
NOTE: DXA was a trim only available with 2-seat Van (VB312R)
H94
