B210 Grille
Revision as of 04:18, 30 June 2019; view current revision
Category: Datsun B210
Datsun B210 radiator grilles varied over the production run.
[hide]
Coupe vs Sedan
Early vs Late
#Early Sedan
#Early Coupe
#Late Sedan
#Late Coupe
#Excellent 1400 (also used by 140Y and 160Y)
#Excellent 1600
Early
B210 EARLY means:
  • JDM 1973-1975
  • USA 1974-1976 Model year (to July 1976)
  • AUS 1976-1978
Early Sedan
174_5cd77bbb00ba6.jpgPost 491392
NOTE: USA sedans used the #coupe grille.
NOTE VB210 Vans (wagons) also used this sedan grille.
* 62302-H5125 JDM GRILLE KIT-radiator (ex. GX)
* 62302-H5225 JDM GRILLE KIT-radiator GX
* 62304-H5100 MOULDING-grille radiator (R.H.) GL,GX, V.SP-DX [half-eyebrow]
* 62305-H5100 MOULDING-grille radiator (L.H.) GL,GX V.SP-DX [half-eyebrow]
Silver, with non-standard center emblem
1956.jpgAlbum 1956
Gunmetal gray
12659_4b01296ba506c.jpgUpload click to view
1332.jpgAlbum 1332 3851.jpgAlbum 3851 11001_4a6d31d0975da.jpgUpload click to view 11001_4a6d3192208b4.jpgUpload click to view 4489_4b01ce5c57b16.jpgUpload click to view 10405_49d6d7100f65b.jpgUpload click to view 3882_4a23244068bf9.jpgUpload click to view 3882_4a7cd6805d746.jpgUpload click to view 3882_4a2607843d39b.jpgUpload click to view
Ornament
The early sedan grille used 'S' or 'D' mark.
19364.jpgAlbum 19364
Fog Lamp
Fog lamps were a rare OPTION for the early sedan.
Rectangular Fog Lamp (sedan style)
* 26150-H5027 LAMP KIT-fog (from '75-4) (op.) S-all, Van
 * replaced 26150-H5026 LAMP KIT-fog (from '74-1) (op.) S-all, Van
   * superceded 26150-H5025 LAMP KIT-fog (op.) S-all, Van
Early Coupe
The early Coupe grille has a bold honeycomb style to invoke a sense of power. It is also used by all early USA Sedans.
62302-H5500 USA GRILLE KIT-radiator Coupe & Sedan
62302-H5500 JDM GRILLE KIT-radiator K-DX,K-GL
62302-H5700 JDM GRILLE KIT-radiator K-GX
3508.jpgAlbum click to view 4229.jpgAlbum click to view 8761.jpgAlbum click to view 18913.jpgAlbum click to view
11916_4a3c6139ee283.jpgUpload click to view 174_4c3909be95ff4.jpgUpload click to view
Ornament
The early coupe grille used a shield-shape 'S' or 'D' badge.
See main article: B210 Grille Badge#Coupe
Fog Lamp
Fog lamps were OPTION. Most B210 had masking plates in the fog lamp position.
62310-H5500 JDM MASK-fog lamp A K-DX
62310-H5600 JDM MASK-fog lamp A K-GL
26150-H5500 JDM LAMP ASS'Y-fog K-GX (op.)K-DX,K-GL
Round Fog Lamp (coupe-style)
* 26150-H5527 LAMP KIT-fog (from '75-4) (op.) K-DX,K-GL
  * replaced 26150-H5526 LAMP KIT-fog (from '74-1) K-GX (op.) K-DX,K-GL
    * superceded 26150-H5525 LAMP KIT-fog (op.) K-GX (op.) K-DX,K-GL
OPTION fog lamp | w/o fog lamp
11320_4a64275c3fdc9.jpgPost 263846 11916_4a3c6139ee283.jpgUpload click to view
Late
LATE B210 means:
* JDM 1976-1977 (B310 production began November 1977)
* USA 1977-1978 Model year (from August 1976)
* AUS ???
Late Sedan
New Grille has a clearly rectangular center section. There is a bright chrome strip outlining the center section.
174_5cd77bde929e7.jpgPost 491392
Variations
* no fog lamps
* amber fog lamps
* yellow fog lamps
* Silver outline with silver center section (AU)
* Silver outline with black center section (UK GLS, UK Estate)
* Black outline with black center section (GX, SSS, FRA)
2044.jpgAlbum 2044
AUS black center
45085711015_f8c0495235_z.jpgflicker click to view 8577.jpgAlbum 8577
AUS silver center
3872.jpgAlbum 3872 11814_4a1bdfc035123.jpgUpload click to view
JDM 7702-7707
62302-H7426 GRILLE KIT-FRONT S.A12,A14,-=STR, V.DX,SPDX
62302-H7425 GRILLE KIT-FRONT =STR, V.SMDX
* 62302-H7401 JDM GRILLE ASSY-RADIATOR =STR+V.SMDX (2-dr STD 4-speed + Van Semi-DX)
62302-H7402 JDM GRILLE ASSY-RADIATOR K.A12S,A14S.DX,GL
62302-H7420 JDM GRILLE ASSY-RADIATOR S.A12,A14-=STR V.DX,SPDX
62302-H7502 JDM GRILLE ASSY-RADIATOR *S.A14S.GX [same as USA]
MOULDING
62304-H7410 MOULDING-RADIATOR GRILLE S.A12,A14-=STR, V.DX,SPDX
62304-H7411 MOULDING-RADIATOR GRILLE S.A12,A14-=STR
part-black grille (w/silver headlight surrounds)
10255_4a34c2df98dd1.jpgUpload click to view 10146_4c22bab2acbc8.jpgUpload click to view
GX all-black grille (w/black headklight surrounds) + fog lamps
11611.jpgAlbum 11611 1968.jpgAlbum 1968 7711_4b241ff4254a5.jpgUpload click to view
1976 GX
174_5c97e15b3095d.jpgPost 490993
1977 GX-T
174_5c9ae1885e33f.jpgPost 491015 174_5c9ae1af618cb.jpgPost 491015
Ornament
See main article: B210 Grille Badge#Late Sedan
Late Coupe
NOTE: USA and Canada coupes used the worldwide #late Sedan grille
The late coupe grille is similar to the early coupe grille, but without the round cutous. It has a horizontal bar through it with a new emblem mounted right over this bar.
26939.jpgAlbum 26939
JDM
62302-H7427 JDM GRILLE KIT-FRONT K.A12,K.A14.DX,GL
62302-H7525 JDM GRILLE KIT-FRONT K.A14.GX
* 62302-H7506 JDM GRILLE ASSY-RADIATOR K.A14.GX
* 62304-H7506 JDM MOULDING-RADIATOR GRILLE K.A12,A14
H7427 Coupe B211
H7525 Coupe.A14.GX
10994_4ae90d6f286b1.jpgUpload click to view 10994_4aefbc82e6507.jpgUpload click to view
Export (coupe grille was used on export Sedans)
2531_4ae6401781cff.jpgUpload click to view 2531_4ae640772dd62.jpgUpload click to view 7431.jpgAlbum 7431 4487_59d8a42a05d2f.jpgPost 486374
Ornament
15432.jpg 174_5a696536a72fd.jpgPost 487406
グリル
Sunny Excellent
PB210
B210-based Datsun Sunny 1400 Excellent (PB210) used a deep-vee, twin-nostril grille. This grille was also used by 140Y and 160Y including the 140Z & 160Z coupes.
19991.jpgAlbum 19991 1865.jpgAlbum 1865
140Y South Africa
174_59d8c13932f50.jpgPost 486376
Excellent 1600
The 1976-1977 Excellent 1600 (GB211) replaced the earlier Excellent 1400 in the Japan home market.
GB211
* Single center-section (no twin-nostril look)
* no horizontal bar
* no fog lamps
62302-H7925 GRILLE KIT-FRONT L16.GL
62302-H7926 GRILLE KIT-FRONT L16.GX
* 62302-H7900 GRILLE ASSY-RADIATOR K.L16S
* 62304-H7900 MOULDING-RADIATOR GRILLE L16
62311-H7925 ORNAMENT-FRONT [S-badge looks like 1/2 Mid-model Sunny Truck badge] Coupe & Sedan
GB211 Grille
As usual, USA models used different grilles, partly due to FMVSS safety regulations. Canada models were the same.
  • 5-mph bumper safety changed the front apron, and did not allow use of the standard front combination lights. So the parking and signal lights were moved to the Grille.
  • Nissan Motor Co. in U.S.A. standardized on a single grille for all B210 -- coupes and sedans used the same grille.
NA 1974-1976 Model year (to July 1976)
NA 1977-1978 Model year (from August 1976)
Early North America
1974-1975 north american sedans and coupes used the worldwide #Early Coupe grille. The fish-gill type #Early Sedan grille was not used.
  • Same as JDM Coupe grille (non-GX)
  • #Fog-lamp position was used for amber combination lamp (turn signal + parking lights)
11786_4a71058fb5c0a.jpgUpload click to view B210earlygrilleUSA.jpg B210earlygrilleUSAmissingbumper.jpg
USA used amber Turn Signal lamps in place of the JDM fog lamps (non-USA has the Turn Signal/Markers/Indicators in the bumper)
174_4c3902216a198.jpgPost 326923
Late North America
Late North America B210s used the #late sedan grille for all coupes, as can be seen on this Canadian Coupe:
12259_4a8f4c5732987.jpgPost 272377
* Black or gray ouline with same color center section
62302-H7526 USA KIT GRILLE-RADIATOR (WITH MOULDI 0876-0177
* 62302-H7500 USA GRILLE-RADIATOR 0876-0177
* 62304-H7410 USA MOULDING-GRILLE RADIATOR 0876-0177
F2302-H7420 USA KIT GRILLE-RADIATOR (WITH MOULDI 0277-0777
* 62302-H7502 USA GRILLE-RADIATOR 0277-0777
* 62304-H7411 USA MOULDING-GRILLE RADIATOR 0277-
62302-H7700 USA GRILLE-RADIATOR 0877- [Black]
* 62304-H7411 USA MOULDING-GRILLE RADIATOR 0877-
With moulding installed:
With moulding missing:
