Datsun B210 radiator grilles varied over the production run.
Coupe vs Sedan Early vs Late
#Early Sedan![]()
#Early Coupe![]()
#Late Sedan![]()
#Late Coupe![]()
#Excellent 1400 (also used by 140Y and 160Y)![]()
#Excellent 1600![]()
Early
B210 EARLY means:
- JDM 1973-1975
- USA 1974-1976 Model year (to July 1976)
- AUS 1976-1978
Early Sedan
NOTE: USA sedans used the #coupe grille.
NOTE VB210 Vans (wagons) also used this sedan grille.
* 62302-H5125 JDM GRILLE KIT-radiator (ex. GX) * 62302-H5225 JDM GRILLE KIT-radiator GX * 62304-H5100 MOULDING-grille radiator (R.H.) GL,GX, V.SP-DX [half-eyebrow] * 62305-H5100 MOULDING-grille radiator (L.H.) GL,GX V.SP-DX [half-eyebrow]
Silver, with non-standard center emblem
Ornament
The early sedan grille used 'S' or 'D' mark.
Fog Lamp
Fog lamps were a rare OPTION for the early sedan.
Rectangular Fog Lamp (sedan style) * 26150-H5027 LAMP KIT-fog (from '75-4) (op.) S-all, Van * replaced 26150-H5026 LAMP KIT-fog (from '74-1) (op.) S-all, Van * superceded 26150-H5025 LAMP KIT-fog (op.) S-all, Van
Early Coupe
The early Coupe grille has a bold honeycomb style to invoke a sense of power. It is also used by all early USA Sedans.
62302-H5500 USA GRILLE KIT-radiator Coupe & Sedan 62302-H5500 JDM GRILLE KIT-radiator K-DX,K-GL 62302-H5700 JDM GRILLE KIT-radiator K-GX
Ornament
The early coupe grille used a shield-shape 'S' or 'D' badge.
See main article: B210 Grille Badge#Coupe
Fog Lamp
Fog lamps were OPTION. Most B210 had masking plates in the fog lamp position.
62310-H5500 JDM MASK-fog lamp A K-DX 62310-H5600 JDM MASK-fog lamp A K-GL 26150-H5500 JDM LAMP ASS'Y-fog K-GX (op.)K-DX,K-GL
Round Fog Lamp (coupe-style) * 26150-H5527 LAMP KIT-fog (from '75-4) (op.) K-DX,K-GL * replaced 26150-H5526 LAMP KIT-fog (from '74-1) K-GX (op.) K-DX,K-GL * superceded 26150-H5525 LAMP KIT-fog (op.) K-GX (op.) K-DX,K-GL
OPTION fog lamp | w/o fog lamp
Late
LATE B210 means:
* JDM 1976-1977 (B310 production began November 1977) * USA 1977-1978 Model year (from August 1976) * AUS ???
Late Sedan
New Grille has a clearly rectangular center section. There is a bright chrome strip outlining the center section.
Variations * no fog lamps * amber fog lamps * yellow fog lamps * Silver outline with silver center section (AU) * Silver outline with black center section (UK GLS, UK Estate) * Black outline with black center section (GX, SSS, FRA)
JDM 7702-7707 62302-H7426 GRILLE KIT-FRONT S.A12,A14,-=STR, V.DX,SPDX 62302-H7425 GRILLE KIT-FRONT =STR, V.SMDX * 62302-H7401 JDM GRILLE ASSY-RADIATOR =STR+V.SMDX (2-dr STD 4-speed + Van Semi-DX)
62302-H7402 JDM GRILLE ASSY-RADIATOR K.A12S,A14S.DX,GL 62302-H7420 JDM GRILLE ASSY-RADIATOR S.A12,A14-=STR V.DX,SPDX 62302-H7502 JDM GRILLE ASSY-RADIATOR *S.A14S.GX [same as USA]
MOULDING 62304-H7410 MOULDING-RADIATOR GRILLE S.A12,A14-=STR, V.DX,SPDX 62304-H7411 MOULDING-RADIATOR GRILLE S.A12,A14-=STR
part-black grille (w/silver headlight surrounds)
GX all-black grille (w/black headklight surrounds) + fog lamps
Ornament
See main article: B210 Grille Badge#Late Sedan
Late Coupe
NOTE: USA and Canada coupes used the worldwide #late Sedan grille
The late coupe grille is similar to the early coupe grille, but without the round cutous. It has a horizontal bar through it with a new emblem mounted right over this bar.
JDM 62302-H7427 JDM GRILLE KIT-FRONT K.A12,K.A14.DX,GL 62302-H7525 JDM GRILLE KIT-FRONT K.A14.GX * 62302-H7506 JDM GRILLE ASSY-RADIATOR K.A14.GX * 62304-H7506 JDM MOULDING-RADIATOR GRILLE K.A12,A14
H7427 Coupe B211
H7525 Coupe.A14.GX
Export (coupe grille was used on export Sedans)
Ornament
グリル
Sunny Excellent
Excellent 1400
B210-based Datsun Sunny 1400 Excellent (PB210) used a deep-vee, twin-nostril grille. This grille was also used by 140Y and 160Y including the 140Z & 160Z coupes.
140Y South Africa (no fog lamps, just blanking plates)
RADIATOR GRILLE COUPE, SEDAN 1 62302-H5800 GRILLE-radiator outer 2 62303-H5800 GRILLE-radiator inner (R.H.) 3 62304-H5800 GRILLE-radiator inner (L.H.) fixing top edge 4 96706-P0105 SCREW GROMMET 6 5 01461-00021 SCREW-with plain washer 6 fixing bottom edge 6 62380-H5000 RUBBER-radiator grille 3 fog lamp delete plate 7 62306-H5800 MASK-fog lamp (R.H.) DX,GL 8 62307-H5800 MASK-fog lamp (L.H.) DX,GL 9 08513-51623 SCREW-tapping DX,GL 8 10 62312-H5825 ORNAMENT KIT-radiator grille 11 01221-00011 NUT-with washer fog lamp GX, (op.) DX+GL 12 26150-H5800 LAMP ASS'Y-fog (R.H.) 26155-H5800 LAMP ASS'Y-fog (L.H.) 13 08510-51623 SCREW-with washer 8
NOTE: grille is upside down in these photos
Excellent 1600
The 1976-1977 Excellent 1600 (GB211) replaced the earlier Excellent 1400 in the Japan home market.
GB211 * Single center-section (no twin-nostril look) * no horizontal bar * no fog lamps
62302-H7925 GRILLE KIT-FRONT L16.GL 62302-H7926 GRILLE KIT-FRONT L16.GX * 62302-H7900 GRILLE ASSY-RADIATOR K.L16S * 62304-H7900 MOULDING-RADIATOR GRILLE L16 62311-H7925 ORNAMENT-FRONT [S-badge looks like 1/2 Mid-model Sunny Truck badge] Coupe & Sedan
GB211 Grille
As usual, USA models used different grilles, partly due to FMVSS safety regulations. Canada models were the same.
- 5-mph bumper safety changed the front apron, and did not allow use of the standard front combination lights. So the parking and signal lights were moved to the Grille.
- Nissan Motor Co. in U.S.A. standardized on a single grille for all B210 -- coupes and sedans used the same grille.
NA 1974-1976 Model year (to July 1976) NA 1977-1978 Model year (from August 1976)
Early North America
1974-1975 north american sedans and coupes used the worldwide #Early Coupe grille. The fish-gill type #Early Sedan grille was not used.
- Same as JDM Coupe grille (non-GX)
- 62302-H5500 USA GRILLE KIT-radiator Coupe & Sedan
- #Fog-lamp position was used for amber combination lamp (turn signal + parking lights). This was necessitated because the under-the-bumper lamps couldn't be used due to the 5mph bumpers
USA used amber Turn Signal lamps in place of the JDM fog lamps (non-USA has the Turn Signal/Markers/Indicators in the bumper)
Late North America
Late North America B210s used the #late sedan grille for all coupes, as can be seen on this Canadian Coupe:
* Black or gray ouline with same color center section 62302-H7526 USA KIT GRILLE-RADIATOR (WITH MOULDI 0876-0177 * 62302-H7500 USA GRILLE-RADIATOR 0876-0177 * 62304-H7410 USA MOULDING-GRILLE RADIATOR 0876-0177
F2302-H7420 USA KIT GRILLE-RADIATOR (WITH MOULDI 0277-0777 * 62302-H7502 USA GRILLE-RADIATOR 0277-0777 * 62304-H7411 USA MOULDING-GRILLE RADIATOR 0277-
62302-H7700 USA GRILLE-RADIATOR 0877- [Black] * 62304-H7411 USA MOULDING-GRILLE RADIATOR 0877-
With moulding installed:
With moulding missing:
