B10 Grille
Revision as of 08:28, 13 November 2021; view current revision
Category: Datsun B10
Grille Badge
1967 'D' chevron 62311-18025 (JDM and Export used this)
1968-1970 'S' shield 62311-27725
1968-1970 'D' shield 62311-27726
Front%20Grill%20Badge%20(62311-27726).jpg 174_5c0a39be48c17.jpgPost click for topic
COUPE [flag style 'S'] 62311-25725
62311-25700
Coupe
* 62303-25700 Coupe (base) 7-slat with 4 vertical risers
* 62303-25701 Coupe GL 7-slat with 6 vertical risers
* OPTION blackout-style with chrome top and bottom slats
* 25701 head lamp rim Coupe (also used by 1969-1970 sedan)
Deluxe - 4 verticals
6644.jpgAlbum 6644 12215.jpgAlbum 12215
GL - 6 verticals
7822.jpgAlbum 7822
OPTION grille (black)
6674.jpg 6674.jpgAlbum 6674
257 grille on Datsun 1200
174_5c07a5265b107.jpgPost 490075
7077.jpgAlbum 7077 7073.jpgAlbum 7073
0600695A30150526W00100.jpg 0600695A30150526W00101.jpg 0600695A30150526W00102.jpg 25410.jpgAlbum 25410
Export Coupe
Late Australia Coupe used a JDM sedan grille
15066.jpgAlbum 15066
1970 Australia Coupe
4321.jpgAlbum 4321
Sedan
* Type 180   1967 (multi-slat aluminum)
* Type 27700 1968 (eggcrate style)
* Type 27701 1968 (4 chromed slats)
* Type H01   1969 (3 chromed triple-slats)
#1967 Sedan
#1968 Sedan eggcrate
20590.jpgAlbum 20590
#1968 Sedan #4-slat
#1969 Sedan 3-slat
Head light rim (eyebrows)
* 18000 round type 1967 (differs from Truck)
* 25700 half type 1968 sedan
* 25701 half type 1969-1970 sedan (same as coupe)
1967
16515_5656dfb3ec288.jpgPost 474009
1967 Sedan
1966-1967 62303-18002
Aussie Sedan
27295.jpgAlbum 27295 16515_5656e003c5adf.jpgPost 474009
JDM 1000 - note the 'D' badge
1967 Standard Sedan
174_618f764189070.jpgPost 496187 545751_10150892107859043_782474042_9468402_1341966209_n.jpg
1968 Sedan
27700 eggcrate | 27701 4-slat
the 4-slat has the same eggcrate mesh background but appears more subdued. Either the mesh is blacked out or the slats are wider/brighter?
62303-27700
62303-27701
Type 27700
11775.jpgAlbum 11775 3538.jpgAlbum 3538
Type 27701 - notice:
* the same mesh with 17 vertical dividers
* much more prominent horizantal slats
174_613ba4be0ef04.jpgPost 495828
11617.jpgAlbum 11617
1969 Sedan
3-slat grille
The Datsun 1000 has been restyled with a newly designed radiator grille. The new grille for the Datsun 1000 sedan and light van has been made along powerful horizontal lines which give a sporty and powerful look to the vehicle.
Service Bulletin Vol. 99 page 1
difference between 1968 4-slat (top two) and 1969 3-slat grilles (bottom two). The 3-slat has wide slats with black above and below the bright strip
3418.jpgAlbum 3418
Type H01 62303-H0100
4236.jpgAlbum 4236 8363.jpgAlbum 8363 9986.jpgAlbum 9986 7076.jpgAlbum 7076 15238.jpgAlbum 15238
1969 Sedan GL
GL (introduced 1969 August) came with 7-slat grille blackout-style with chrome top and bottom slats
27885.jpg1969 brochure 174_5cfdd9e417ba8.jpgGL brochure
It looks like the #Coupe OPTION grille
Van
B10 Wagon (VB10) uses same grilles as Sedan:
  • Type 180 1967 (multi-slat aluminum)
  • Type 277 1968 (eggcrate style)
  • Type H01 1969 (4 chromed slats)
GRILLE-radiator
* 62303-18002 [with vertical center badge]
* 62303-27700 from Chassis no. VB10-066701 [eggcrate style with 'S' shield badge]
* 62303-27701 from Chassis no. VB10-955161
* 62303-H0100 from 1968 October
1966/1967 grille
8739.jpgAlbum 8739
1968 eggcrate type
11048.jpgAlbum 11048 11047.jpgAlbum 11047
1969-1970 Deluxe
7078.jpgAlbum 7078 2693.jpgAlbum 2693 174_612f618591102.jpgPost 495790
Same as sedan?
2178.jpgAlbum 2178
Truck
B20 Truck a.k.a. ute
  • Early ute grille has vertical bars dividing it into 2 sections
  • Early sedan grille has vertical bars dividing it into 4 sections
Type 180 Sedan/Van Grille - 1968 #Export Truck
27701 1968 Sedan Grille - #Export Truck
Type 154 pick-up Grille #STD 1968 Truck
G01 pick-up Grille #STD 1969-1970 Truck | #DX Truck
STD 1968 Truck
STANDARD
* 62303-15400 GRILLE-radiator TS (not listed in Export catalog)
  Used with chevron center emblem
  27846.jpgAlbum 27846
* 62303-15401
  Used with shield center emblem
Export B20 (B20U) introduction
1968
2418.jpgAlbum 2418
STD 1969-1970 Truck
* 62303-G0100 GRILLE-radiator TS 1969-
  Used with shield emblem
  Painted (non-chrome)
  27845.jpgAlbum 27845
27843.jpgAlbum 27843 27844.jpgAlbum 27844
CA1.jpg 20567.jpgAlbum 20567
13696.jpgAlbum 13696 17641.jpgAlbum 17641
DX Truck
DELUXE 62303-G0101 GRILLE-radiator TD | 62311-27725 'S' ornament
62303-G0100.jpg Front%20Grill%20Badge%20(62311-27726).jpg 174_5c0a39be48c17.jpgPost click for topic
Deluxe added small vertical dividers in the upper and lower portion of the grille -- similar to the 1963 Datsun 320 truck grille
400px-Datsun-SunnyTruckB20.JPGWIKI go to Wikipedia 17616.jpgAlbum 17616 5392.jpgAlbum 5392 174_5c0a39a4d5381.jpgPost 490091 174_5c0a3997589e6.jpgPost 490091 174_5c0a39c8e74eb.jpgPost 490091 174_5c0a39d1ae678.jpgPost 490091 174_5c0a39eb7e616.jpgPost 490091
Export Truck
  • Deluxe Truck was not offered
  • Apparently in AUS, sedan grilles were used with some utes
1968 Australia ute with 180-Type (1967 sedan) grille
7266.jpgAlbum 7266
Australia ute with H01-Type (1969 sedan) grille
5503.jpgAlbum 5503 8261.jpgAlbum 8261 1805.jpgAlbum 1805 1789.jpgAlbum 1789
