Datsun 1000 tail lights vary by model and country.
Side Lights
Datsun 1000 front guard was fitted with different indicator lamp lenses depending on the year.
1967 Model: Small Round dome type 26161-18000 LENS-lamp
Type 180 - 1967 & the first 26 1968s
1968-1969: Short spear (about 10cm long) same as early Datsun 521 26161-25700 LENS-lamp (from C/# B10-80026, VB10-84001)
1970: Long spear (13cm+). Same as Datsun 510 "1600" 26161-A4600 LENS-lamp (from C/# B10-350001, VB10-240001, KB10-80001, B20-61001)
* Replaces spear A
Same as JDM & ADM 510s
Coupes uses same lense as others, but the assembly (lamp housing) is different for Coupe.
1967 round type looks similar to 1969 Datsun 510 rear USA (EVER WING A3036 SAE P167), but this is much flatter (the B10 lens sticks out quite a bit).
Similar to Datsun 410 side lamp
1968-1960 short spear looks identical to USA Datsun 521 part number 26160-B0101ᴳ
The 1970 long spear looks similar to USA 510, but those are asymmetric:
* 26161-21000 ASSY LENS WITH RIM RH 1068- 510 USA
* 26166-21000 ASSY LENS WITH RIM LH -0969 510 USA
BULB 12V-6W 26073-30001 <> 26715-89900
26161-18000 LENS-lamp 2 ALL (exc. Coupe) * 26160-18000 ASS'Y-LAMP, side marker [round type]
26161-25700 LENS-lamp 2 ALL [10cm short spear] * 26160-27700 ASS'Y-LAMP, side marker ALL (exc. Coupe) * 26160-25701 ASS'Y-LAMP, side marker Coupe
26161-A4600 LENS-lamp 2 ALL [13cm long spear] * 26160-H0110 ASS'Y-LAMP, side marker ALL (exc. Coupe) * 26160-H0310 ASS'Y-LAMP, side marker Coupe
Front Lights
Datsun 1000 was fitted with clear lens front combination lamp, using an orange bulb.
Australia
Aussie models had a orange bulb offset to the inside of the lens.
FRONT PARKING & TURN SIGNAL LAMP * Coupe: Below bumper * Sedan: Above bumper
PARKING & TURN SIGNAL LAMP ASSY H03 Coupe 209 Sedan, Wagon, Ute 1967 277 Sedan, Wagon, Ute 1968-1970
Sedan
Sedan clear rectangular lens
26120-20908 ASSY=LAMP,PARKING & TURN SIGNAL RH (TO SEP-'67) 26125-20908 ASSY=LAMP,PARKING & TURN SIGNAL LH (TO SEP-'67)
26126-20900 LENS=TURN SIGNAL RH CLEAR (TO SEP-'67) 26127-20900 LENS=TURN SIGNAL LH AMBER (TO SEP-'67)
1967 Right 26122-20900, Right Amber Lens
26120-27751 ASSY=LAMP,PARKING & TURN SIGNAL RH (FROM OCT-'67) 26125-27751 ASSY=LAMP,PARKING & TURN SIGNAL LH (FROM OCT-'67)
26125-27750 'EVER WING EW0603L'
Coupe
Coupe front lights * 257 Early: Large Amber lens * H03 Late: 2-section (amber + clear)
Type 257 Early Coupe: Large Amber lens
Late Coupe: 2-section (amber + clear)
PARKING & TURN SIGNAL LAMP ASSY 26120-H0300 RH COUPE 26125-H0300 LH COUPE 26120-25702 Right 26125-25702 Left
26126-25702 LENS LH
初代 サニー クーペ KB10 フロントレンズ
Ute
Export B20 (B20U) introduction
Japan-market. Clear lens with centered orange bulb.
EXCEPT COUPE ASS'Y-LAMP, & turn signal
* all Ichiko 市光 except as noted
26120-18000 RH
26125-18000 LH
26120-18010 Koito 小糸 (2, left and right identical)
(up to C/# B10-80025, VB10-84000)
26120-27701 RH
26125-27701 LH
26120-H0110 LH
26125-H0110 LH
26121-18000 LENS-parking & turn signal (2)
COUPE LENS-parking & turn signal
26120-25703 RH
26125-25703 LH
26120-H0310 RH
26125-H0310 LH
Position
Sedan, Van, Ute: Fitted above the bumper
Coupe: Fitted below the bumper
Tail Lights
Datsun 1000 rear lamps were combination type (park, stop, and reverse lamps in one "Combination Lamp").
Sedan
B10 Sedan rear lamps came in early and late styles.
1966-1968 reverse in center
1969-1970 reverse inside, extra wide
H01 type: 1970 (from October 1969)
Coupe
KB10 taillights
Wagon
VB10 lamp
1968 (to September 1968), also 1967 Australia
182 1967 Red + Red 209 1967 Red + Amber Australia 209 1968 Red + Amber H04 1969-1970 Amber + Red + Clear
Reverse Lamp 1967-1968 Deluxe had separate lamp 1969-1970 Lower portion of tail lamps
1967 - note reverse lamp under right side of bumper
26536-H0401 center lens
.jpg)
