Ash Tray
Revision as of 03:46, 9 March 2025; view current revision
Categories: Body | Interior | Options
Datsun 1200 came with an ashtray in the center of the dashboard below the ventilator controls. Rear passenger ash trays were an Option.
Front
Image Search: ashtray
画像検索: サニー B110 アッシュトレイ
The front ash tray is named the "Instrument Panel Ash Tray".
Interior Colors
Black 1970-1978 96500-H1000
Blue  96500-H2600 PB110 GL option
Brown 96500-H2700 PBB10 GX option
Brown 96500-G1060 1978.04 to 1989.10
Gray  96500-95W00 1989.10 to 1994.3
NOTE: Sedan, Coupe, Van, Truck same part number
      including 1972 facelift models and PB110
fixing ash tray
08510-70112 SCREW 3
08915-43710 WASHER-plain 1
08913-10710 NUT-lock 3
The tray may be re-colored with vinyl spray paint.
19845.jpgAlbum 19845 174_56945c33a45e2.jpgPost 475341
174_56945c3f3358a.jpgPost 475341 174_56945c5833cb0.jpgPost 475341 willieoec-img600x450-1327299313adpctn23143.jpg willieoec-img600x450-1327299314fraciz23143.jpg willieoec-img600x450-1327299314oefwry23143.jpg
Gray (1990s)
PB110 Sunny Excellent 1400
New
Buy from Bprojects
B210 front ash tray looks similar. However, the upper piece is very different.
B110 two side-fastening screws
B210 two front-fastening screws
28411.pngAlbum 28411
26738A 26261-89905 BULB 7702- FOR ASHTRAY LAMP
68196  68425-H7416 BRACKET A 7702- FOR ASH TRAY
68425C 68425-H5000 GROMMET-SCREW
96501 ASHTRAY-INSTRUMENT
 96500-H5000 BLACK -7701
 96500-H5900 GB211 (Brown)
 96500-H7400 Black 1977.2-
 96500-H7401 Black 1977.2- with Illumination
 96500-H7900 Brown 1977.2- with Illumination GB211
96501A 01451-00191 SCREW 3
Rear
Deluxe B110s came with one of these in the back seat area (below the side window). Two are fitted — one on each side — except for STD sedan and STD van 4-door which only have one. B210 & B310 used the same ashtrays.
4926.jpgAlbum 4926
96502-H1001 ASSY-ASH TRAY, REAR 2 (1 STD, except Van 2-door)
* B110, including PB110
* B210
* B310
08520-51210 SCREW (fixing ash tray, one per ashtray)
The same rear ashtrays were used by Sedan, Coupe and Van.
These were fitted to the interior side trim (2-door sedan, 2-door coupe) or to the rear door cards (4-door models).
4-door sedan - rear door card (ドア内張)
11179.jpg28401.png 26322.jpgcards
2-door sedan - rear inside trim
2-door coupe
アッシュトレイ
