Nissan Factory service manual for the A14E fuel injected engine, 1978 edition.
A14E Service Manual A14E Service Manual Part 2 Engine Overhaul & Service Data
You can help us out! If you can type Japanese, please click Edit and type in the text. Also need help translating. Thanks!
A型 エンジン
A-series Engine
(1978 Standards Conforming Car)
はじめに Introduction
はじめに
この本は、53年度排出ガス規制適合のNAPSを挟用したA系EGI仕 ... | Introduction
This book, A-specifications EGI system was for conforming the NAPS of 1978 fiscal exhaust gas regulations ... |
目次 Table of Contents
Summary 4
page 4| 1. 概要
| 1. Summary
Engine Main Specifications 5
1-1 エンジン主要諸元 Engine Main Specifications
NAPS Specification List 6
1-2 NAPS仕様-覧 NAPS Specification - List
Engine Appearance 7
1-3 エンジン外観 Engine Appearance
1. 二?空気導入 Exhaust Air Induction Tube 2. Throttle Chamber 3. Air Regulator 4. EGR control valve 5. Dash Pot
1. Water temperature switch 2. TV valve 3. Water temp sensor 4. Blowby lower hose
1. Alternator 2. Distributor 3. Blowby upper hose 4. Pressure Regulator 5. VVT valve 6. VC solenoid valve 7. Fuel injector
Engine Sectional View 10
1-4 エンジン断面図 Engine Sectional View
Engine Performance Curve 11
1-5 エンジン性能曲線 Engine Performance Curve
NAPS System View 12
1-6 NAPSシステム図 NAPS System View
NAPS Piping Diagram 13
1-7 NAPS配管図 NAPS Piping Diagram
(1) Vacuum Hose Diagram
mm
1. 170 Vacuum gallery ~ pressure regulator
2. 90 VVT tube ~ VVT valve
3. 200 VVT valve ~ TV valve 3-way connector
4. 70 Vacuum gallery ~ Dist. 3-way connector
5. 50 Vacuum gallery ~ Dist. 3-way connector
6. 190 Vacuum gallery ~ TV valve
7. 170 EGR control valve ~ TV valve
8. 110 TV valve ~ 3-way connector
9. 540 Distributor ~ 3-way connector
10. 120 Vacuum gallery ~ VC solenoid valve
11. 200 VVT valve ~ VC solenoid valve
12. 200 Throttle chamber ~ vacuum gallery
13. 90 Vacuum connector ~ vacuum gallery
14. 130 Throttle chamber ~ vacuum gallery
(for Distributor)
15. 230 Throttle chamber ~ VC solenoid valve
16. 170 Throttle chamber ~ vacuum gallery
(for EGR control)
17. Blind Cap
Engine Maintenance Notes 15
1-8 エンジン整備上の注意 Engine Maintenance Notes
Engine Start-up Notes 18
1-9 エンジン始動上の注意 Engine Start-up Notes
Regular Inspection And Maintenance 19
2. 定期点検整備 Regular inspection and maintenance
キャニスター Canister * ? * ? filter 40,000 km
キャニスター本体 Canister Body
フィルター Filter
フィルターの点検 Filter Inspection
Checker 28
3. チェッカー Checker
Function Checker 28
3-1 ファンクション チェッカー Function Checker
EGI Harness Check 30
3-2 EGI ハーネス チェッカー (EG1131) EGI Harness Checker
(1) (2)page 31
page 34 - EGI Circuit
full | japanese
Page 35 - Checker: ハーネス実態図 EGI Harness Schematic View
full | Japanese
EGI Control Unit Checker 38
3-3 EGIコントロール ユニット チェッカー EGI Control Unit Checker
Fault Diagnosis 42
4. 故障診断 Fault diagnosis
On-vehicle Engine Maintenance 45
5. 車載上のエンジン整備 On-vehicle Engine maintenance
Air Door Adjustment 45
5-1 アイ ドル調整
Air Cleaner and ? 48
5-2 エア クリーナー及びニ?空気?入(EAI)装
Throttle Chamber 89
5-8 スロットル チャンバー
Manifold 90
5-9 マニホールド
Cylinder Head 92
5-10 シリダー ヘッド
Catalyst ? 95
5-11 触媒コンベーター及び排気温?報装置
103
104
105
108
Engine ? 111
6. エンジン脱? Engine ?
Engine Overhaul 114
See A14E Service Manual Part 2
7 Engine Overhaul 114 7.1 Overhaul Notes 114 7.2 Disassembly 115 7.3 Inspection, Correction, Replacement 119 7.3.1 Cylinder Head and Valve 119 7.3.2 Cylinder Block 124 7.3.3 Piston, Piston Ring, Conrod 125 7.3.4 Crankshaft, Main Bearing 128 7.3.5 Camshaft 130 7.3.6 Other Components 131 7.4 Assembly 132
Service Data 141
8. サ=ビス データ Service Data
8.1 Standard Bolt, Nut Tightening Torque 141 8.2 Engine Torque Specs 142 8.3 Service Data 143
Special Tools And Checker 146
9. 特殊工具監及びチェッカー Special tools and checker
Special Tools 146
9-1 特殊工具
Checker and Check Sheet 151
9-2 チェッカー及びチェック シート
Inspection Circuits 155
10. 点検回路 Checking Circuits
Function Checker Check 155
10-1 ファンクション チェッカー チェック
EGI Harness Checker Check 156
10-2 EGI ハーネス チェッカー チェック
Memos
[pages 176-183 are blank "Memo" pages for taking notes]
Back cover
