Sunny Truck Distributors
Revision as of 05:11, 4 June 2025; view current revision
Categories: Sunny Truck | Engine Electrical System
<-- back to Distributor
Sunny Truck was fitted with a regular (contact points) distributor through October 1989. From there on it was fitted with Electronic Ignition.
15190.jpgAlbum 15190 15191.jpgAlbum 15191
Versions
22100-H1001 DISTRIBUTOR ASS'Y (HITACHI D411-61)
* B110 Type
22100-G1400 DISTRIBUTOR ASS'Y (HITACHI D411-97) (from '73-4)
* B210 Type
22100-H1011 DISTRIBUTOR ASS'Y (MITSUBISHI TVG-4FL)
* alternate B110 type
22100-G1410 DISTRIBUTOR ASS'Y (MITSUBISHI TVT3T01877) (from '73-1)
* alternate B210 type
22100-G1610 DISTRIBUTOR ASSY 7510-7907 MITSUBISHI
22100-W8511 DISTRIBUTOR ASSY 7907-8602 MITSUBISHI
22100-G1910 DISTRIBUTOR ASSY 8602-8910 MITSUBISHI
22100-95W10 DISTRIBUTOR ASSY 8910-     MITSUBISHI
* Bolt-down cap type (Mitsubishi), electronic
The last one is Electronic Ignition
22100-24B01 1400 South Africa?
* 2210024B01, 22100-G5110
22162 DISTRIBUTOR CAP
22162-71312 7510-8602 Mitsubishi > 22162-71311
* 210/713 type 70 mm I.D. clip-on
22162-25G11 8602-8910 Mitsubishi <> 22162-25G10
* low-profile clip-on
22162-78A10 8910-     Mitsubishi
* bolt-down
12962.jpgAlbum 12962
22157 ROTOR all Mitsubishi
22157-18011 -8602 > 22157-18010
22157-R9007 8602-8812
*  37x56x22 mm
22157-10B10 8812-8910
22157-23G15 8910-
Coils
All used with ballast resistor, except the Electronic Distributor
* 22433-U3100 COIL ASSY-IGNITION [HITACHI] 7510-8910
* 22433-U3110 COIL ASSY-IGNITION [HANSHIN] 7510-8910
* 22433-U3140 COIL ASSY-IGNITION [MITSUBISHI] 8504-8910
* 22433-52A60 COIL ASSY-IGNITION MITSUBISHI
U3110
20226.jpgAlbum 20226 20227.jpgAlbum 20227 20240.jpgAlbum 20240
Resistor
* 22460-14606 RESISTOR-IGNITION COIL 7510-8910 Hitachi choice
  Hanshin HP5-13E10 12V-R(ヒタチ センタク シヨウ)
* 22460-14615 RESISTOR-IGNITION COIL 7510-8910 Hanshin choice
* 22460-14645 RESISTOR-IGNITION COIL 8504-8910 Mitsubishi choice
22100-W8511
20228.jpgAlbum 20228
April 1985 (S60) L-GB122-024688
20231.jpgAlbum 20231
22100-G1910
DISTRIBUTOR ASSY 8602-8910 (from 1986 February to 1989 October)
Nissan 22100-G1910 Mitusbishi 3T23581 7804E
20225.jpgAlbum 20225
  • points distributor with clip-on cap
  • came with Hanshin coil Nissan 22433-U3110
22100-95W10
This is fitted to Datsun 1200 trucks from October 1989 through end of production in 1994. It is a nice unit with the transistor unit mounted in the distributor body, under the distributor cap. Late-model Electronic Distributor.
Mitsubishi T4T66373
20230.jpgAlbum 20230 20229.jpgAlbum 20229 20223.jpgAlbum 20223 20242.jpgAlbum 20242 20241.jpgAlbum 20241
22462-52A60 COIL-IGNITION
22100-95W10 DISTRIBUTOR ASSY A12S 8910- ミツビシ (Mitsubishi) デストリビユーター (デストリビューター)
22100-95W12
B2235-U7410 TAPE-SEAL, DISTRIBUTOR [a roll of tape] 7510-, 1194- B14U SR20DE,GA16DE
* superceded by 22235-U7400 $3.39 USD
22301-95W10 CONTROL ASSY-VACUUM
22023-G5110 UNIT-SETTER
22201-22010 SCREW 7510- [fixing timing plate to distributor]
22180-71200 SEAL-O RING [distributor to engine block] A/L/Z engines $4.25 USD
22101-95W10 HOUSING ASSY-DISTRIBUTOR
Condensor: None used
? 22107-95W10 GOVERNOR SET-DISTRIBUTOR
22115-95W10 SIGNAL-ROTO ASSY
22109-52H60 WEIGHT-GOVERNOR
22127-95W10 SPRING-GOVERNOR
22136-77A11 PLATE ASSY-BREAKER
22132-95W10 CAM SET
22229-95W10 SIGNAL SET
95W12
17193.jpgAlbum 17193 17194.jpgAlbum 17194 17195.jpgAlbum 17195
22020-G5111 TRANSISTOR IGNITION UNIT [fits inside distributor]
* 8910- Sunny Truck
* Intermotor 15650
* J117
* Mazda/Ford 323/626/929/MPV/MX3/B2600/B2200
* Suzuki
* Komatsu/TCM/
Cap & Rotor
* 22162-78A10 CAP ASSY-DISTRIBUTOR B12 1088- GA16I $27.36 USD
  * 22185-95W10 PACKING [seal, cap to body]
  * ? 04136-00211 SCREW
* 22157-23G15 ROTOR-HEAD $6.88 USD
Cap fits North America models:
* 1988-1990 Nissan Sentra with Mitsubishi distributor
  Oreillys.com E16 or GA16 Sentra
  * Master Pro C672
  * BWD C672
  * Beck/Arnley 1746918
  * Niehoff Ultra WA468A; Pro-Power WA468ACS
  * Bosch 03320
  * Standard Motor Products JH180
  * AC/Delco E338A
* 1987-1988 Nissan Pulsar NX
Bosch 03320 CAP fits North America models:
* Nissan 1983-1994
  * 1989-1990 Nissan 240SX
  * 1990-1994 Nissan Pickup
  * 1983-1990 Nissan Pulsar NX
  * 1991-1993 Nissan NX
  * 1984-1994 Nissan Sentra
* Subaru 1987-1991
  * 1988-1989 Subaru DL
  * 1990-1994 Subaru Loyale
  * 1987-1989 Subaru GL
  * 1987-1989 Subaru RX
  * 1987-1989 Subaru GL-10
  * 1987-1991 Subaru XT
* Suzuki
  * 1989-1994 Suzuki Swift
T4T66373 2227 Nissan service part, possibly remanufactured. Note the sticker instead of cast/stamped numbers.
20237.jpgAlbum 20237
1993: Mitsubishi T4T66373 7720 Nissan 22100-95W10
20234.jpgAlbum 20234
20224.jpgAlbum 20224
Mitsubishi T4T Family
Mitsubishi T4T series came with points and electronic versions. See Mitsubishi T4T Distributors
