<-- back to Wiper Switch
Datsun 620 truck uses a NILES wiper switches look identical to Datsun 1200 switches, except for a spacer.
- JDM 620 did not light illuminated switches
- USA starting 1972.09 has illuminated switch
- USA 1978-1979 Datsun 620 with Deluxe trim have an intermittent wiper switch
Datsun 620 truck uses a NILES wiper switches look identical to Datsun 1200 switches, except for a spacer. Some have black escutcheon.
All 620 wiper switches use Datsun 1200 knobs (type H10 or H70). To remove, push in and turn counter-clockwise p
For USA, 1978-1979 Datsun 620 with Deluxe trim have an intermittent wiper switch, which pulls out three clicks (OFF, INT, Low, High). All other use the two-speed switch (OFF, Low, High). So either a 4-position switch 3-position switch.
USA Dash Harness 1972-1975 yellow square connector * 5-spade terminals for switch 1976-1977 white rectangle connector * 5-spade terminals for non-intermittent switch 1976-1977 white rectangle connector * 6-spade terminals for either switch * intermittent switch uses a sub-harness
non-intermittent, non-illuminated (all Japan, and 1972 USA)
USA Early and Late switches pictured, both connected to the Fiberscope fiber optic illumination unit
1973-up USA 620 uses a lighted switch as do all USA vehicles starting with the 1973 model year
Datsun 620 USA catalog COMP-SWITCH,WIPER 25260-B5500 1972 [non-illuminated] [from 1972.08] 25260-B6401 1973-1975 [from 1972.09] 25260-B8060 1976-1978 25260-B8060 1979 except DX 25260-B9300 1979 DX COMP-SWITCH,WIPER (INTERMITENT) * 28890-B8060 AMP UNIT-INTERMITENT WIPER * 24018-B9300 HARNESS-WIPER * 08360-61291 SCREW 2 * 01552-00411 CLIP [zip tie] 25163-B5011 ESCUTCHEON 25265-H1000 KNOB-WIPER SWITCH 1972 25265-H7001 KNOB-WIPER SWITCH 1973-1979 25170-U0500 ASSY-ATTACHMENT WITH ILLUMINATION 1973-1979 * for illumination lamp * 26261-89900 BULB (12V/3.4W) * 25170-E7500 SOCKET-BULB * 08310-40814 SCREW WITH SPRING WASHER SWITCH-ILLMINATION CONTROL (1973 did not use a switch) * 25280-B8001 1974-1977 * 25280-B8002 1978-1979 * 25280-B9800 1979 Deluxe 25287-B7900 PROTECTOR-ILLUMINATION SWITCH KNOB-ILLUMINATION SWITCH * 25285-P0100 1974-1975 * 25285-B8000 1976-1977 * 25285-R5300 1978-1979 * 25285-U2000 1976-1979
ダットサン トラック 1972 620 Japan catalog C-234 revision 1977.2 25260-B5000 SWITCH COMP.-wiper 25265-H7001 KNOB-wiper switch
ダットサン トラック 620 Japan catalog C-410 revision 1980-05 [1976-1979] 25260-B5000 SWITCH COMP.-wiper -7708 25260-B5005 SWITCH COMP.-wiper 7709- W/INTERMIT * 28890-B8060 AMP-INTERMITENT WIPER 7709- ALL * 28890-R4710 AMP-INTERMITENT WIPER -7708 *ALL [option] *PU T,V,OST 25265-H7001 KNOB-wiper switch
25260-B5000
25260-B5000 JDM non-intermittent 'NILES TYPED- JAPAN 091T' (NILES WS-620A)
Wiring appears to be identical to Datsun 1200 standard Wiper Switch
