Strut Inserts (shock absorbers) for the front suspension: Datsun 1200 (B110) uses 45 mm diameter strut tubes. Most other Datsuns, including B210, use a larger 50.8 mm size. This article will help you choose custom fitment inserts for any strut you may be using.
Direct Interchange
Original Nissan Part Numbers
- Datsun 1200s did not come with strut insert cartridges, they had rebuildable strut absorbers.
- Nissan later offered strut inserts specifically for the 1200, they are still available as of May 2008.
Using a factory-quality Strut rebuild kit (rather than removing the factory strut parts and replacing with a new strut 'cartridge' insert) is the way to retain a smooth front-end ride. However, these are no longer manufactured.
Inserts
- Nissan 56105-H5025 about $50 each from Nissan
- T0KICO S1041 (oil), Z1041 (gas)
- Koni 86-1714 (previously 82N-1714, S1003)
- replace 56110-H1026
- KYB (Kayaba) 662002/KC1001 (oil)
- KYB 362001 (gas)
- Replaces B110, B120 Jan 1970-May 1973
- Replaces B210 Mar 1973-Oct 1977
- Replaces VB310 (12" wheel model?)
- Monroe Sensa-Trac 73949 $35
- Compressed Length: 17.875"
- Extended Length: 24.250"
- Body Length: 17.375"
- Travel: 6.375"
- AC/Delco gas-charged 50335/88945515 $39
- KYB 364003 GR-2 gas $52
- 1974-1978 B210
- 1979-1982 210
- 1980-1983 200SX
- 1978-1981 510
- AutoTek 181 00-167
45mm OD Strut Inserts
Discussion: strut inserts
Stock
418 body length / 631 Extended / 462 Collapsed
- Stroke: 169mm (6.7 in)
Stock Nissan B110 inserts. See Strut
KONI
- B110 Nissan 99996-1714N / KONI 86-1714 (previously 82N-1714, S1003)
(still to cross-reference p/no for make and model... 65mm shorter than (120y) B210, KONI 8641 1072sport.
VW Golf/Rabbit
318 body length / 511 Extended / 352 Collapsed
324 / 511 / 359'
- Stroke: 158mm (6.25 in)
- Bilstein part number W0133-1604944
- Get Bilstein (1.507 in) or KYB brand at about 1.5 inch outside diameter. Tokico and KONI are too big around to fit 45mm strut housings.
discussion: VW Rabbit inserts
- Golf Mk I insert is nearly 4 inches shorter than stock and will need a simple spacer made to make up the difference in length in the bottom of the tube.
- Strut piston diameter is larger than B110, so drill out the strut-nut and the strut top hole.
Four different Rabbit Bilsteins available:
- OE style "Touring
- F4PNE3033BE / 171412031J USA Made With Internal Threads
- stiff "Sport"
- F4P300032M0 / 171412031J USA Made With Internal Threads
- softer "heavy duty"
- race: 270/100 for rebound/compression
Bilstein Race & Rallye (gas)
- Strut Part Number V36-0059 (but just buy the inserts)
- 270/100 damping
- Fits:
- 1974-1984 Golf/Rabbit
- 1977-1981 Volkswagen Scirocco I 4 cyl 8v
- 1980-1984 Volkswagen Jetta I 4 cyl 8v
- 1982-1988 Volkswagen Scirocco II 1.8L 8v
- 1986-1988 Volkswagen Scirocco II 1.8L 16v
Monroe Sensa-Trac (gas) 72878 / P832
- Models w/ Internal Threads on Original Strut Housing (U. S. A.)
- Diameter: 1.5"
- Stroke: 152mm (6.000 in)
- Ext len: 511mm (20.125 in)
- Comp len: 359mm (14.125 in)
- Body len: 324mm (12.750 in)
Monroe Sensa-Trac (gas) 72826 / 17090011
- Models w/ External Threads on Original Strut Housing (German)
- Diameter: 1.5"
- Stroke: 6.250"
- Ext len: 20.125"
- Comp len: 13.875"
- Body len: 12.500"
- Piston diameter: 0.75"
Toyota Starlet (RWD)
Get them from TRD
VW Jetta
Jetta inserts -- information on inserts and adapting Koni inserts for VW Jetta so that they fit a 1200.
416 body length/ 599 Extended/ 431 Collapsed,
1200 (B110), 120y (B210)
Gabriel - G44217
Vera - 62-01015
50.8 mm OD Strut Inserts
Most Datsun struts use 2 inch (50.8mm) diameter strut tubes. The insert itself will be 1-5/8 inch (41.3mm) diameter.
KONI
- B210 Nissan 99996-1912R / KONI 86-1912
- B310 Nissan 99996-2002P / KONI 86-2002
- B310 Nissan 99996-2002T (Sport) / KONI 86-2002
Inserts
364 Body length/ 555 Extended/ 318 Collapsed, Book reference wrong???
R31 6/86-12/90, Pintara
Gabriel G44946/G44972
Koni Red Specials - 86-2361
362 body length/ 559 extended/ 392 collapsed
Z31 (300ZX) 5/84-85
Gabriel - G44936
357 body length/ 531 extended/ 366 collapsed
Z31 (300ZX) 1/86-89
Gabriel - G44968
Tokico Performance Gas - HZ3100
381 Body Length/ 543 Extended/ 398 Collapsed
240/260/280z (S30),Gazelle
from chassis#30-060001 strut tube size is increased inside and outside, some inserts will fit both but leading manufacturers are model specific.
non model specific
Mulholland - 2351501
Gabriel - G44869
Monroe US Made - 86361
up to chassis#30-060000
Koni Red Specials - 86-1811
Tokico HP Series - HZ3015
KYB GR2 Gas - 361002
Tokico Illumina 5-Way Adjustable - BZ3015
Tokico HP Series - HZ3012
KYB GR2 Gas - 361003
Tokico Illumina 5-Way Adjustable - BZ3012
403 Body length/ 575 Extended/ 415 Collapsed
200b (810 L24E) 10/77-81, 240K (C110) 73-79, Skyline C210 3/78-80, R30 3/81-86, 200SX 77-79, 1600 (P510) 8/71-73
Gabriel - G44856/G44900
Vera - 62-00976
Koni Red Specials - 86-2224
410mm (415mm if including gland nut) 340mm travel
1600 (P510) 68-8/69, 180b (P610) 72-77
Monroe - MC962,
Gabriel - G44864
437mm Body Length
Stanza/Violet (H510) 77-81, Sunny (B310) 78-81, 200SX 80-83
Monroe - MC949,
Gabriel - G44752
Vera - 62-00570
KYB GR2 Gas - 364003
??????? Not sized yet
1600 (P510) 9/69-7/71
Monroe - MC926
Gabriel - G44865
280ZX (S130) 78-83, Bluebird 80-83, Maxima (910) 82-84
Tokico Illumina - BZ3038,
Tokico Illumina 5-Way Adjustable - TOBZ3038
Tokico Performance Gas - HZ3038
Gabriel - G44977
KYB GR2 Gas - 365013
Measurements
Strut Housing
- Outside Diameter: 45mm (1.77 in)
- Inside Diameter: about 1.5 inch
Nissan 56105-H5025 for Datsun B110
- Body length: 41.8mm (16-3/8 inch). The seal protrudes 1/8 past this.
- diameter: main housing - 37.6mm (1.48 in)
- diameter: upper collar at top of housing - 40.9mm (1.61 in)
- shaft dia. 17.8mm (1.7 in)
- thread height - 24mm
- thread diameter - M10 (10mm hole, 11 mm threads)
- Overall collapsed - 46.2mm (18-3/16 in.)
- Overall extended - 63.1mm (24-13/16 in.)
- Stroke: 16.9mm (6.7 in)
Original B110 Strut valving Damping Force @ 0.3m/sec:
- Expansion kg(lb): 48 (106)
- Compression kg(lb): 22 (48.5)
Stroke
- B310 strut valve: 164 mm (6.46 in)
- B310 cartridge: 161.5
- B310 cartridge: 160.5 A12A Canada (12" wheels)
Damping rates are same for B310 valve or insert, but stroke differs slightly.
Damping Force
| model | B110 1970-1973 disc | B210 1974-1977 A13/A14 | B210 1978 A14 | B310 1979 | B310 80-82 | B310 12" |
| expansion: kg | 48 | 32-48 | 28-42 | 30-40 | 28-42 | 38-58 |
| compression: kg | 22 | 20-30 | 16-24 | 17-23 | 16-24 | 15.5-24.5 |
