Oil pan
Revision as of 06:20, 12 October 2009; view current revision
Category: Engine Lubrication System
Datsun 1200 uses a tradition wet-sump oil pan, holding about 2.5 quarts of oil. It is a sheet metal part that plays no structural function. It is a front-sump design.
North American B210 engines (A13 & A14) used a mid-sump (center sump) design.
  • 11110-H7201 ASSY-PAN OIL
    • Replaces 11110-H7201, 11110-H6200
All the A-series pans bolt to all A-series engines. However, A15 oil pans have bulges for the extra crank throw. Using an A14 pan on A15 results in a banging noise.
Pan Styles
There were several pans for A-series:
1967-1973 - front distributor engine blocks
  • Front Sump (B10 and B110 interchange)
When the distributor was moved back for 1974 there was a change in the pan rail shape under the oil pump area which prevents interchangeability between front-dist & mid-dist engines
1974-up - mid-distributor engine blocks
  • Front sump A12, A12A, A14
    • 11110-H5000 OIL PAN [same as JDM B210]
  • Mid-sump (North American B210)
  • A15 front sump pan with bulges, will retro fit into other A-series mid-dizzy engines.
    • 11110-H9700 OIL PAN [unique to A15]
The lack of clearances bulges on the "B" type pans prevents use on the A15, however the presence of bulges on the A15 pan does not interfere with its use on other rear dist engines.
FWD A-series
  • cast aluminum front sump
Nissan Competition Parts
  • 99996-H1050 B210 COMPETITION OIL PAN Completely baffled with special one-way pick-up tube designed to keep competition Oil pump primed
  • 99996-H1052 1200/210 COMPETITION OIL PAN Specifications same as 99996-H1050
  • 99996-H1135 SPECIAL OIL PAN GASKET Seals better than the
stock gasket and can be reused when properly installed
  • 11128-H2375 ADAPTER/OIL TEMP SENDING UNIT Will adapt a Stewart/ Warner manual oil temperature sending unit to any stock oil pan
695.JPG 699.jpg 867.jpg 868.jpg 929.png 1141.jpg 1868.jpg 5038.jpg 7999.jpg 8000.jpg 8001.jpg 8002.jpg 15363.jpg 17278.jpg
