71-Series Transmission
Revision as of 05:27, 19 March 2011; view current revision
The 71 transmission is Nissan's strongest transmission. It was fitted to L-series six cylinders, FJ engines and more. 71 series comes in four different lengths, however a stumpy version is the same length as a Datsun 1200 transmission though obviously much larger around. The stronger 71B replaced the original 71A designs in the 1970s.
[hide]
The 71-series has the mainshaft and countershaft 71 mm apart. This larger transmission is thus stronger than the 56-series used in the Datsun 1200, and stronger than the 63-series used in some A14-powered B210s. The C revision boxes (FS5W71C) was used with 3-liter V6 engines.
Although the Nissan 90-Series Transmission was rated higher, experience shows that the 71C is practically just a as durable even behind a 300ZX turbo (see Gearbox Strength).
While never offered in an A-series version (it would be overkill even for a supercharged A-engine), the 71 is a good choice for larger Engine Swaps.
71 series is also the size of the Datsun 1200 Automatic Transmission (L3N71B), so a 1200 automatic Tunnel should fit them.
Transmission Parts Codes:
  • 32010 TRANSMISSION ASSEMBLY
Lengths
Long extension housing is the most common.
Overall Transmission Assy Length
Long tail #1: 31.5 inches
Long tail #2: ? inches
Tail #3: ? inches
Short tail: 26.3 inches (stumpy)
Stumpy
  • 71-Series Transmission
    • Skyline DR30 (FJ20 engine with 71C)
    • Datsun 720 pickup USA (71B)
Skyline DR30 transmission
71 Original
F4W71
Short 4-speed with flanged output
  • 1969-1972 Datsun 521 with L16 engine
Short 4-speed with sleeve-yoke output
  • 1972-1973 Datsun 620 with L16 engine
Long 4-speed
71A
F4W71A Long housing
  • 1969-1971 240Z 4-speed
FS5C71A Long housing
  • Removable bell housing
  • Datsun Roadster with U20 bell
  • Datsun Roadster with R16 bell
  • Datsun 240Z early USA dealer installed with L-series bell
71B
Look for 71B cast into the transmission case.
F4W71B
Short housing
  • Datsun 720 with Z-series engine (short 26.3")
(1972-1982) long housing. Rear extension of transmission has bolt-on cover plate.
  • 1972-1973 Datsun 240Z
  • 1974 Datsun 260Z
  • 1975-1978 Datsun 280Z
  • 1979 Datsun 280ZX
  • Datsun 610
  • 1977-1980 Datsun 810 L-series six-cylinder
  • 1974-1979 Datsun 620 with L18 or L20B engine
  • 1979 Datsun 720 with L20B engine
  • 1980-1982 Datsun 720 with Z-series engine (long 31.5")
FS5W71B
  • Datsun 200SX (S110) with Z20 engine
  • Datsun Maxima (810) with LD28 diesel
  • Nissan 720 with SD diesel
  • Nissan 200SX with CA18ET engine
  • Datsun 720 long tail
  • 1977-80 Datsun 280Z
  • 1979 280ZX (non-Turbo)
  • Datsun 810
  • Datsun 620
Short extension housing
Engines
L-series (various)
Z-series (S110)
LD28 diesel (Maxima)
SD diesel (Nissan 720)
CA18ET (Nissan 200SX)
71C
FS5W71C - The 71C has a different shifter than the 71B and all versions are longer than the 71B. A 71B front housing can be swapped.
  • 1983- Nissan 300ZX (non-turbo, turbo uses 90-series)
  • 1986-1989 Nissan D21 (Hardbody) with Z-series engine
  • 1989- Nissan D21 (Hardbody) with KA-series engine
  • Pathfinder/Xterra/Frontier with KA-series engines
  • Pathfinder/Xterra/Frontier with VG-series (V6) engines
Engines
VG-series (V6)
KA-series
Z-series
Like transmission parts interchange:
  • 71A bell housings
  • 4-speed to 4-speed
  • 5-speed to 5-speed
  • 71B/71C front cases
Complete transmission units of the same length interchange. For example, replacing a shorty FS5W71B with a shorty FW471.
L-series and Z-series/KA-series use the same bell patttern -- BUT the L-series is a slant engine. So while the transmissions will physically bolt on, use the Z-/KA front case with the Z-series engines, and the L-series front case with the L-series engines. OR, you can bend the gearshift to the appropriate angle, but you risk transmission oil leaking out.
720 North America
The north america parts catalog lists these transmissions
  • L20B used from introduction 0679-0680
  • SD22 Diesel 0679-1082
  • SD25 Diesel 1182-
  • Z22 from 0880-1082
  • Z20 from 1182-0784
  • Z20 from 0784-
  • Z24 from 1182-0784
  • Z24 from 1183-
  • Z24 from 0784-
  • Z24I from 0485-
4-speeds
L20B
F4W71B 4-speeed for L20B
  • 32010-44W05 FED 2WD long + 4WD regular
  • 32010-45W05 CAL 2WD long + 4WD regular
  • 32010-B9860 CAL 2WD regular
  • 32010-B9960 FED 2WD regular
Z22
F4W71B 4-speed for Z22 engine
  • 32010-05W00 2WD regular
  • 32010-46W00 4WD [both wheelbase]
  • 32010-Q4900 Heavy Duty [both wheelbase]
5-speeds
L20B
FS5W71B
0679-0680
  • 32010-44W06/32010-44W16 King Cab 4WD FED
  • 32010-45W06 King Cab 4WD CAL
0679-1179
  • 32010-B9910/32010-B9912 King Cab 2WD + non-KC CAL
  • 32010-B9911 King Cab 2WD + non-KC CAL FED
1279-0680
  • 32010-B9912 King Cab 2WD + non-KC CAL
  • 32010-B9913 King Cab 2WD + non-KC FED
Z24
OPTION FS5W71B with 16" extension housing
  • 32010-20W16/32010-20W15 King Cab + 2WD 0784-
SD Engine
  • 32010-V2400/32010-Y8401 SD22 0679-1082
  • 32010-19W15 SD25 1182-
