Nissan GA16 engine. The Nissan GA16 engine is similar to the A15, but distributor is in the back and RWD transmissions are avialable and Asia and Europe markets. It is also possible to adapt a 60 series Datsun B210 or B310 transmission as well. This is a high output lightweight engine, the GA16DE version has 16V head and variable camshaft technology. There are also GA13 and GA14 but it's not really worth all the work for these smaller versions. A GA18 is perenially discussed, but appears to be a global legend, always existing in some other country but never actually seen. The GA engine series was replaced by the QG series in 1999 (the QG18DE has 126 HP).
Sources
GA16 is fitted to FWD Nissans like Sunny/Sentra and Pulsar circa 1989-2000. Also to Tsubame Y10 (Mexico) through 2004 Tsuru B13 through 2007.
Nissan B13 "Sentra" 1991-1994 USA 110 hp - standard two compression rings on pistons.
Nissan B13 Sentra/Sunny 1991-1994
Nissan B14 "Sentra" 1995-1999 USA Sentra, all except SE/SE-R GA16DE 1,597cc DOHC 7,200 rpm redline 115 hp (86 kW) @ 6000rpm - Low drag single compression ring on each piston and they also feature micro polished crankshaft journals. 110 ft lb @ 4500 rpm
USA - non-GA16DE B12 GA16I KN13 GA16D KN13 GA16
JAPAN B13 GA16DE B14 GA16DE C23 GA16DE N14 GA16DE N15 GA16DE
JAPAN - other GA series B12 GA15E B12 GA15S B12L GA15E B12L GA15E B12L GA15S B12L GA15S B13 GA13DS B13 GA15DS B14 GA13DE B14 GA15DE C23 GA16DS N13 GA15E N13 GA15E N13 GA15S N13 GA15S N13P GA15E N13P GA15E N13P GA15S N13P GA15S N14 GA13DS N14 GA15DS N15 GA15DE R10 GA15DS R11 GA15DE RB14 GA15DE U13 GA16DS W10 GA16DS
Europe EL C23M GA16DE N14 GA14DS N14 GA16DS N14 GA14DE N14 GA16DE N15 GA14DE N15 GA16DE P10E GA16DS P10E GA16DE P11E GA16DE W10 GA16DS W10 GA16DE WP11E GA16DE Y10 GA16DS Y10 GA16DE B12 GA16I B12 GA16S B12 CA16D B13 GA16DS B13 GA16DE N13 GA14S N13 GA16S N13 GA16I
Look for the Bulge on left side of this photo, which indicates NVCS variable-valve timing (115hp)
VCT bulge on right front of valve cover
1991-1994 Nissan NX 1600 N14 1991-1994 Nissan Sentra B13 1994-1995 Nissan 100NX B13 (UK) 1991-1994 Nissan Presea R10 1995-1996 Nissan Presea R11 1995-1999 Nissan Sentra B14 1995-1999 Nissan 200SX B14 1995-1999 Nissan Almera N15 1995-1999 Nissan Pulsar N15 1993-1999 Nissan Primera P10/P11 10/1992-07/1995 Nissan Sunny Y10 1999-2001 Nissan Exalta Philippines
Transmission
GA engines may use the E-series bellhousing pattern -- reportedly it shares enough bolt and alignment pin holes with the A-series for the transmissions to line up. Just like the E15, the block dowels line right up, and so do three block-to-transmission bolts. The 63A 5-speed input shaft may need to be machined as it is a little too long for the GA16DE.
Use any 4-speed or 5-speed you want. Use the traditional method of using an aluminum adapter plate that bolts to the engine and provides new holes for the transmission and starter.
Or in Europe or Aisia, source a Serena (Nissan Van C23 1992-) RWD transmission. They have these in Japan, Malaysia and New Zealand too.
- 32010-G2N69 RS5W71C [remote shift 5-speed 71-series transmission]
- Europe
- 32010-0C061 RS5W71C
- 9106-9701 Japan
- through 2009 Malaysia
This is a large 71-series transmission, so tunnel mods will be required. Possibly could be converted to floor shift using Z-car or Silvia rear housings. However, the shifter will be too far back. Instead, consider the stock Remote Shift version, with a floor shifter from another car adapted (remote shifter).
Nissan Rasheen 1995-2000 RWD - IRS GA15DE mounted transversely uses RS5F31A transaxle uses RWD-only transfer case 2-piece propeller shaft uses R180? differential
Swap Notes
Use a manual transmission GA engine flywheel. If using a 60 series B210/B310 transmission: remove the GA starter ring gear [it's facing the wrong way for the FWD starters anyway]. Use the [smaller] A series starter ring gear and machine the back of GA flywheel to fit it [it's an interference fit]. Then heat the A-series ring gear and install it backwards from the original GA gear. You can notch the GA block for clearance and use the stock A-series starter.
Remove EGR and block, since it points backwards.
Remove distributor and fit an inexpensive EDIS crank trigger system (about $200 USD). Or simply cut an access panel in your firewall for clearance and use the original distributor.
Weld up new motor mount brackets -- typical engine swap stuff. This is not a bolt-in swap.
Fit a carburetor (custom manifold) OR use the factory EFI and ECU (convert your 1200 to EFI):
EFI fuel pump Surge tank Fuel lines Return line to fuel tank
On a GA16DE the standard throttle valve will be against the firewall. Either relocate it with a custom intake, cut out the firewall to allow intake piping, or use twin side draft carbs.
Weber DCOE twin-carburetor manifold
Oil Pan needs to be clearanced on the bottom to clear crossmember [on a B310]. The sump is in the correct place, but the bottom of the pan is tapered and needs to be flat.
New exhaust pipe and use 1.75 piping and muffler and tail pipe
Variable Cam Timing
The compelling part of this swap is 116 HP from variable cam timing. You could even carburete this engine and still use the VCT with an RPM-activated 12V relay.
- 23796-57Y00 VALVE ASSY-SOLENOID, VALVE TIMING CONTROL
- 13025-57Y10 SPROCKET-CAMSHAFT,INTAKE
