Carburetor Specifications
Revision as of 03:11, 27 June 2011; view current revision
Category: Fuel System
Hitachi DCx carburetors have different specifications depending on market, year, state and other factors. All A-series engines used Hitachi DCx-306 carburetors 26/30 bores, except for the A10 engine which used a smaller DCG-286 model with 26/28 bores. A12 carburetors have 20/26 primary/secondary venturis, and other engines used bigger venturis up to A15s which have bigger 21/27 or 23/27 venturis.
  • DCG - manual choke
  • DCH - electric automatic choke
Also See: Carburetor Repair, Instruction Sheet section
5919.jpg Hitachi DCH306 ID boss
4968.jpgHitachi DCH306
[hide]
Jet Locations
You will need to remove the carburetor top to identify the exact jets which are installed. This can be done with the carburetor on the engine.
To remove the top:
  • remove pump lever cotter pin. The hardest part is disconnecting the throttle pump linkage on the outside of the carb. This is the long lever along the top of the carb and rods that connect the throttle to the pump. There are also small clips that hold the levers. Be careful and don't lose them
  • remove choke linkage cotter pin
  • remove and plug fuel line
  • remove choke pull-off hose
  • remove the top screws
  • if equipped, disconnect auto choke wires and idle cut solenoid wires
North American Models
Carburator Models
Year Engine Hitachi Model
1971 A12 Hitachi DCG306
72-73 A12 Hitachi DCH306
74 A13 Hitachi DCH306
75-76 A14 Hitachi DCH306
Primary Main Jet - North American Models
Year Jet Size
1971 No. 98
1972 No. 97
1973 No. 95
1974 No. 104
1975-76 California No. 104
1975-76 No. 102
1977-78 California Manual Trans. No. 105
1977 No. 104
1978 California Manual Trans. No. 105
1978 No. 104
1978 Federal 5-speed No. 107
Main Air Bleed
71-73 No. 80
74 No. 65
75-77 No. 95
1978 All California No. 95
1978 Four-speed No. 110
1978 Five-speed No. 65
1978 Automatic No. 95
Secondary Main Jet
Year Jet Size
1971 No. 135
1972-73 No. 140
1974 No. 145
1975 No. 150
1976 No. 145
1977-78 No. 145
Secondary Air Bleed
Year Jet Size
71-78 No. 80
1977 California 5-speed No. 60
Primary Slow Jet
Year Jet Size
1971-74 No. 43
1975-78 No. 45
1978 non-California 5-speed No. 46
Secondary Slow Jet
Year Hitachi Model
71-76 No. 50
Australia Model Specifications
Hitachi DCG-306 (G indicated manual choke)
NOTE: B310 A15 uses DCF-306, which differs from DCG as follows:
* vacuum secondaries, instead of counterweighted secondaries
* replaceable sight glass with O-ring
* modified choke fast idle system
Datsun B310
source: Gregory's
Controls
 Idle Cut Off Solenoid (anti-diesel valve)
 Servo Diaphragm
 Dashpot
Venturi
  primary, A12: 20 mm
  primary, A14: 22 mm
  primary, A15: 21 mm
  secondary, A12: 26 mm
  secondary, A14/A15: 27 mm
Main jet,
 primary, A12: 96
 primary, A14: 104
 primary, A15: 100
 secondary, A12: 150
 secondary, A14: 150
 secondary, A15: 145
Main air bleed
 primary, A12: 80
 primary, A14: 65
 primary, A15: 70
 secondary, A12: 80
 secondary, A14: 60
 secondary, A15: 80
Slow Jet
 primary, A12: 43
 primary, A14: 46
 primary, A15: 43
 secondary, A12: 50
 secondary, A14: 50
 secondary, A15: 70
Slow air bleed
 primary, A12: 220
 primary, A14: 170
 primary, A15: 100
 secondary, A12: 100
 secondary, A14: 100
 secondary, A15: 100
Power jet
 A12: 60
 A14: 60
 A15: 40
Japan Market Specfications
