Fast Idle Control Device was fitted to Datsuns with factory-fitted Aircon. This means 1979-up models with air conditioning. The FICD raises the idle speed automatically when A/C is ON to respond to the increaesed load.
Setting
Fast Idle Actuator
- Clearance 'C' should be more than 3mm, Engine fully warm, A/C off.
- Start engine and set correct warm idle speed (650 RPM in 'D')
- Turn A/C ON, in 'N' and adjust engine speed to 800 RPM.
- FICD adjusting screw
- Lever 'A'
- Lever 'B'
- Cable lock screw
North America
B310
1979 A14 & A15 models had optional A/C.
Idle Setting
A14/A14 Manual Transmission
- A/C OFF: 700 rpm
- A/C ON: 800 rpm
A14/A14 Automatic Transmission
- A/C OFF: 650 rpm in "D"
- A/C ON: 800 rpm in "N"
